* * * * * 1 votes
GMH LX8
386 replies to this topic
#151 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 04 October 2020 - 05:48 PM
Finally fitted the mounting points on the diff for the shocks.
Folded some 5mm flat bar into a U shape and drilled a 14mm hole for the bolt to go through.
Just have to get some longer bolts now.
Also run brake lines and fitted mounting clips to hold in place firmly.
Changed where they run from inside the front chassis rail to the outside and drilled some holes to run them through at the front.
#152 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 14 October 2020 - 04:57 PM
Fitted the fuel lines most of the way through to the engine bay. Just have to save up for the expensive little fuel filters that go in line on the -8 1/2" metal hard lines now. About $460 for them and the correct fittings.
Ordered the tie bar Lutani roller lifters and comp cams valve springs from summit racing in the usa. Waiting for them to arrive now.
Then next month I can send off my cylinder heads to be CNC ported flowed and cc for comp ratio.
#153 Shiney005
  • 9,554 posts
  • Car:Toyota Mirai
Posted 15 October 2020 - 08:44 AM
How much horsepower are you looking for? The gearbox may need some work to cope with much more than standard.  It is why both of my LX8's are parked up. No second gear.
#154 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 15 October 2020 - 04:51 PM
The 4l60 box is a known weak spot and will be upgraded with heavy duty parts.
As I'm pushing for 300+kw at all 4 wheels 400+hp in old school rage. About 650 at the flywheel will do it.
That's why the comp ratio was bumped up to 11.8 to 1 and run some E85 through it's veins.
#155 Heath
  • 18,383 posts
Posted 16 October 2020 - 08:39 AM
Jesus. That's some serious grunt haha.
#156 myss427
myss427
  • 1,636 posts
Posted 16 October 2020 - 09:44 AM
Don't think your front diff will take that, read some horror stories of hotted up CTS V's that have spat the diff out of the sump, same setup used in the LX8"s.
#157 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 17 October 2020 - 06:19 PM
Only one way to find out.
But there is a few turbo and blown adventra around now so there must be a few upgrades available now.
#158 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 17 October 2020 - 06:23 PM
Well fresh out of hospital on Wednesday arvo from heart surgery and back into rebuilding parts today.
Front Brake calipers cropped a full rebuild.
Sandblasted and painted to look better than new.
Twin piston 305mm vented fronts should stop it.
#159 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 17 October 2020 - 06:35 PM
Every time I look at the specs of the 2 different cars vy adventra and the lx torana I still can't believe that I managed to get it all to fit.
1617 front wheel track down to less than 25mm more than the ls 1485mm in the a9x and then the difference in wheel base.
Wow it's been a long road.
Edited by Shtstr, 17 October 2020 - 06:36 PM.
#160 rodomo
  • 18,036 posts
Posted 17 October 2020 - 08:27 PM
You're a soldier!  :spoton:
#161 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 23 October 2020 - 04:47 PM
Finished running the fuel lines to the engine bay today.
Fitted all 1/2" metal/alloy lines with aeroflow fittings and a inline aeroflow fuel filter with a 100 micron washable filter.
Have run them on the outside of the passenger side chassis rail tobe different and through the brace at the A pillar up through the inner guard.
Also started looking at where the ECU will sit in the engine bay behind the passenger side strut tower. Will need to call on my auto electrician again to do some wiring harness mods again (shortern/remove about 18") on the engine harness.
Will need to get a drop tank custom made to suit my setup too as it will need to have 1/2" inlet and outlet plumbing and built in surge take to hold a Walbrow 525 pump or twin 460 pumps depending on fuel requirements
But it's slowly getting closer to being finished.
#162 neglectedtorana
neglectedtorana
  • 1,038 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 23 October 2020 - 07:43 PM
Great project you got there, well done on your hard work and skills making it fit.
I put my ECU in the glove box and regret not making the loom long enough to put it elsewhere like the boot, I originally thought the engine bay was the best option but the loom wasn't suitable so it ended up in the glove box. At the end I don't think it would have fitted easily in the engine bay, before you put it in the engine bay consider all the other stuff you will have to put there also and see if you have enough room for everything
#163 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 23 October 2020 - 08:41 PM
They are fitted in the engine bay area on all vy vz v8 Commodores.
By putting it behind the strut tower it is out of the way.
#164 Rockoz
Rockoz
  • 4,027 posts
  • Name:Rob
Posted 24 October 2020 - 01:39 PM
Ive been slowly setting myself up to make stand alone LS1 harnesses.
All brand new plugs and wire, with the ability to provide it with any extra length for custom installs.
Not interested in anything to do with the electronic autos at this stage, and can set them up for MAF or MAFLESS as I go.
Not sure if there would be any market for something like that though.
Will see what happens down the track I guess.
Rob
#165 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 25 October 2020 - 06:17 PM
Rob
Hi Rob.
There are a few companies that make them now.
The reason I haven't changed the harness is with the adventra setup you can't delete anything out of the system. If you do it puts the car into limp mode. It's the only ls platform that has this problem I'm led to believe.
#166 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 25 October 2020 - 06:21 PM
Well started doing the exhaust system that I've been putting off.
Running factory ls1 avalanche extractors to 100 cel cats twin 2.5 inch stainless steel system.
Spent a couple of hours making my x pipe this afternoon. Should work all right I say.
Ported the inside out to get rid of any bursts or drags inside of it.
#167 Heath
  • 18,383 posts
Posted 26 October 2020 - 04:32 PM
Very tidy.
The long burrs are invaluable hey?
#168 Rockoz
Rockoz
  • 4,027 posts
  • Name:Rob
Posted 27 October 2020 - 08:32 AM
Thats where SolarFlux is great.
It stops the crap on the inside of the welds.
Does the same sort of thing as back purging.
Have seen a couple of ads for harnesses, but each of them required you to supply them and they reworked them.
That type of thing is something I could also ad in. but I will end up getting the right plugs for autos down the line.
Just want to get the engine side done first.
Had a chat with Jeff Dellow and he is keen to help in marketing.
Rob
#169 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 27 October 2020 - 05:06 PM
Well as I'm setting out the exhaust I have made the decision to run it under the diff.
I know that people will say no but I don't care. I have 60mm clearance to the diff and 100mm to the ground with the mufflers I'm using.
#170 Shiney005
  • 9,554 posts
  • Car:Toyota Mirai
Posted 27 October 2020 - 07:53 PM
I have always done it. Never had an issue.
#171 Heath
  • 18,383 posts
Posted 28 October 2020 - 08:43 AM
I also don't think it's a bad thing. Particularly if you run no longer shock that you need, and package the exhaust accordingly. I've also done this on my hatch.
Edited by Heath, 28 October 2020 - 08:46 AM.
#172 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 28 October 2020 - 07:39 PM
Well all the exhaust is tacked together. Going to let my son tig weld it up so he can have some practice. Will be grinding it all smooth just like stainless steel hand rails.
#173 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 29 October 2020 - 09:37 AM
All tacked up and if you look closely you might see the metal fuel lines.
#174 Shiney005
  • 9,554 posts
  • Car:Toyota Mirai
Posted 29 October 2020 - 12:25 PM
Does the car have to comply with whatever noise limits were around when the VY was released?
#175 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 29 October 2020 - 03:36 PM
Not that I'm aware of. Only has to meet Torana sound noise from the era I believe.
If it to loud I can change the mufflers easily enough.
