The SL project
311 replies to this topic
#301 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
  • Car:LJ 2 door, UC hatch
Posted 21 December 2024 - 04:59 PM
I used the charcoal canister from the VZ my LS1 came from, have it mounted under the inner guard passenger side and the engineer was happy.
Very neat brake lines you have there Harvey, I think when I change boosters I might need an upgrade like that.
Hi Tom,I hadn't thought of that. Could you send me a pic of the install? I love your car and the fact you use it for what they are meant for. Well done on a fantastic build mate.
The brake lines off the master cylinder for me was get them out of the engine bay fast. The coil pack covers made that a tight squeeze. I'm really happy with how it turned out. Cheers
#302 4dabush
4dabush
  • 226 posts
  • Name:Adam
  • Car:73 LJ S
Posted 21 December 2024 - 09:38 PM
Another requirement was that the Charcoal Canister must be in the car as original. This made no sense as I had fuel injection and a throttle body, but you know make them happy.
I made this up and forwarded the photos, looks cool????
Harvey and the rest of the brains trust, if the Brown Davis tank doesn’t pass engineering, how does any droptank pass? Or how do you get engineering for them? I am having the same question from my engineer on the LJ tank which is only 15mm deeper than factory to fit internal commodore fuelpump and sender.
Next question, if you swap the tank back out and anything happens, what happens with our insurance?  Seeing as our cars are worth quite a bit, I am sure insurers would look closely at everything if the unthinkable happened and we had to make a claim?
I’m a bit stuck as I reckon it will be near impossible to get the commodore pump into the standard tank, and don’t really want to buy a new Bathurst tank to chop up.
#303 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 22 December 2024 - 07:52 AM
Thanks Harvey,
I do have pictures but unfortunately I am working through to early Jan so can't get them from my laptop until I am home.
I have the rectangular shaped VZ canister on a bracket that attaches to the internal bumper bracket, will post a pic when I am home.
#304 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 22 December 2024 - 07:55 AM
I have an aluminium drop tank that is about 90 litres, it is shallow enough that it passes the rear departure rule and was passed by the engineer. It has a VZ style pump but its been taken apart and the internal rods that act on the springs were cut and shortened so it would fit.
EFI hardware in Melbourne sell all sorts of EFU conversion equipment too, they might have a solution.
#305 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 22 December 2024 - 07:11 PM
Hi Adam, the bottom line is if it's not on your engineering certificate your insurance won't cover it. I accept the risk as its more stolen vehicle cover for me than repair damage. I'm insured by Shannons, I had the guy look over the Hatch to give me an in an insurance value and he quoted me on the spot as it was. (100k, that's the maximum they would go without it being a matching numbers car)
#306 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 26 December 2024 - 08:11 PM
Another requirement for the engineering was that I needed retractable seat belts for the rear of the car as it was considered a high performance engine. Rare Spares had what I needed, I have made a plate bracket to sit under the rear parcel shelf to secure them. I think I looks pretty good.
#307 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 26 December 2024 - 08:18 PM
The car was only just on correct rear track measurements. The engineer accepted that the original track was 1372mm plus the allowance of 25mm gave me 1397mm. I think a lot of cars are over track.
#308 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 26 December 2024 - 08:50 PM
The Engineer was now happy with the Hatch and gave me the mod plate... That lead me to the Transport department. Tough crowd to impress. Because I had removed the R.H.S. rail which had the VIN number on it, They were concerned that I was re birthing a car. I had keep the rail and top plate with the original VIN number for just this reason. After several emails and phone calls they issued me with a new VIN number. I have attached this to the under side of the R.H.S. rail. Then I needed to pass the basic inspection of general registration. None of this was for free, LOL
At the end of it all I had my name etched into the Hatch, more than worth it !!!
Edited by Ricky Bobby, 26 December 2024 - 08:51 PM.
#309 claysummers
claysummers
  • 3,629 posts
  • Name:Clay
Posted 26 December 2024 - 10:03 PM
Congratulations Harvey. Wife’s FB has a QLD mod plate from 1994. The inscription is nothing like as neat as yours.
#310 Shiney005
  • 9,578 posts
  • Car:Toyota Mirai
Posted 30 December 2024 - 10:38 AM
I've got a mod plate on my truck, and it looks like the details were scratched in by a 4 year old with a screwdriver!
#311 redtorana#3
redtorana#3
  • 105 posts
  • Car:1977 LX
Posted 31 December 2024 - 11:00 PM
Awesome build mate and some good info. Congratulations.
#312 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 23 January 2025 - 06:31 PM
Sorry it took so long Harvey,
Some pics of my VZ charcoal canister, its under the left front guard on a bit of plate attached to the bumper bracket. Sorry pics are'nt the best think these were of air con dryer rather than the canister.
Attached File  P1120897.JPG   155.12K   4 downloads
Attached File  P1120899.JPG   151.29K   3 downloads
