The SL project
311 replies to this topic
#26 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
  • Car:LJ 2 door, UC hatch
Posted 30 December 2019 - 02:34 PM
I tacked the rail on the car and checked the measurements, the lhs rail was out by 10mm as well which didn't help things. The doors need the usual repairs and I was sick of drilling spot welds.
  • Attached File  149.jpg   335.39K   14 downloads
  • Attached File  254.jpg   242.55K   11 downloads
  • Attached File  255.jpg   251.85K   11 downloads
  • Attached File  256.jpg   263.29K   11 downloads
  • Attached File  258.jpg   231.97K   11 downloads
  • Attached File  259.jpg   249.72K   11 downloads
  • Attached File  260.jpg   243.6K   11 downloads
#27 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 30 December 2019 - 02:37 PM
  • Attached File  262.jpg   276.27K   10 downloads
  • Attached File  266.jpg   271.52K   12 downloads
  • Attached File  270.jpg   265.09K   11 downloads
  • Attached File  273.jpg   210.89K   10 downloads
#28 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 30 December 2019 - 02:42 PM
It was when I flipped the door over, I flipped
  • Attached File  277.jpg   230.94K   10 downloads
  • Attached File  278.jpg   246.77K   11 downloads
  • Attached File  279.jpg   284.88K   13 downloads
  • Attached File  280.jpg   281.57K   10 downloads
  • Attached File  196.jpg   99.62K   9 downloads
  • Attached File  197.jpg   199.45K   12 downloads
  • Attached File  200.jpg   97.13K   10 downloads
  • Attached File  205.jpg   149.31K   9 downloads
#29 claysummers
claysummers
  • 3,629 posts
  • Name:Clay
Posted 30 December 2019 - 02:59 PM
Yuk.
Good on you for taking that on.
#30 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 30 December 2019 - 03:04 PM
I stripped the K frame cleaned it up, painted it in 2 pack and fitted the new rubbers. I am using CRS parts for mounting the drive line and sump. I will also install their chassis strengthening kit. I went with power steering from Axis Truck repairs to keep with the pro tour feel. Really nice piece of gear !!!
Then put it all together for a test fit, chubby time
  • Attached File  210.jpg   289.48K   10 downloads
  • Attached File  187.jpg   255.09K   9 downloads
  • Attached File  211.jpg   352.86K   9 downloads
  • Attached File  213.jpg   255.86K   10 downloads
  • Attached File  216.jpg   308.54K   9 downloads
  • Attached File  222.jpg   215.75K   10 downloads
  • Attached File  223.jpg   226.43K   12 downloads
  • Attached File  237.jpg   266.25K   17 downloads
  • Attached File  226.jpg   342.51K   10 downloads
  • Attached File  227.jpg   335.5K   11 downloads
#31 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 30 December 2019 - 03:59 PM
The good news is that the hatch and the LH bonnet where better than I hoped.
  • Attached File  888.jpg   327.95K   10 downloads
  • Attached File  889.jpg   291.35K   10 downloads
  • Attached File  899.jpg   310.56K   10 downloads
  • Attached File  900.jpg   307.91K   11 downloads
#32 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 30 December 2019 - 04:23 PM
I want to make it a show quality car so I smoothed the inner guards and relocated the K frame access  points. ( engineer is cool with that )
  • Attached File  024.jpg   260.23K   9 downloads
  • Attached File  002.jpg   325.15K   10 downloads
  • Attached File  004.jpg   317.6K   9 downloads
  • Attached File  006.jpg   229.85K   9 downloads
  • Attached File  008.jpg   289.67K   9 downloads
  • Attached File  009.jpg   248K   9 downloads
  • Attached File  010.jpg   254.65K   10 downloads
#33 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 30 December 2019 - 04:25 PM
  • Attached File  026.jpg   223.64K   9 downloads
  • Attached File  027.jpg   240.37K   9 downloads
  • Attached File  036.jpg   239.07K   10 downloads
  • Attached File  037.jpg   251.59K   10 downloads
#34 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 30 December 2019 - 04:29 PM
  • Attached File  029.jpg   382.07K   8 downloads
  • Attached File  030.jpg   192.83K   8 downloads
  • Attached File  032.jpg   267.16K   8 downloads
#35 Cook
Cook
  • 1,529 posts
Posted 30 December 2019 - 05:17 PM
I like your work Harvey, you obviously know what you are doing.  I must admit though, I wouldn't have had the heart to carve up the LH.  Cheers Ron
#36 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 30 December 2019 - 06:16 PM
I know what you mean Ron, not my prouldest day I can tell you not much was wasted and it may help a few more cars hit the road.
#37 Ice
  • 15,200 posts
Posted 30 December 2019 - 06:32 PM
Fully admire your work and motivation Harvey I'm keeping an eye on this build
#38 yel327
  • 13,630 posts
Posted 30 December 2019 - 06:46 PM
I wouldn’t think twice, no different to cutting up a HK sedan to fix up a HG coupe and making the HG look like a HT. I still have a couple of HK sedans with good bodies set to be donors for coupes.
#39 rexy
rexy
  • 3,737 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 30 December 2019 - 07:57 PM
The one downside to relocating the K frame access is that it will be much easier for water and debris to enter the rail. Have you thought of making some sort of sealed cover?
#40 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 30 December 2019 - 08:17 PM
Yes Rexy I'll weld 5mm flat either side of the access holes then drill and tap them and make a cover plate to add strength and to plug the holes.
#41 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 30 December 2019 - 09:47 PM
 I cleaned up the fire wall seams earlier and then etch primed the engine bay and stripped the nose cone.
  • Attached File  015.jpg   241K   11 downloads
  • Attached File  016.jpg   290.87K   10 downloads
  • Attached File  017.jpg   228.55K   9 downloads
  • Attached File  045.jpg   185.87K   10 downloads
  • Attached File  046.jpg   196.14K   10 downloads
  • Attached File  132.jpg   324.12K   8 downloads
  • Attached File  133.jpg   299.88K   8 downloads
#42 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 30 December 2019 - 09:51 PM
The front guards need panel beating but I'm leaving that to the experts. So I've done the rust repairs.
  • Attached File  128.jpg   295.9K   9 downloads
  • Attached File  129.jpg   338.51K   8 downloads
  • Attached File  130.jpg   342.3K   8 downloads
  • Attached File  131.jpg   325.64K   8 downloads
  • Attached File  141.jpg   330.13K   9 downloads
  • Attached File  143.jpg   257.37K   8 downloads
#43 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 30 December 2019 - 10:01 PM
With most of the external covered i needed to look at the tunnel for the gear box. It was important for me to have a centre console they complete the look of the interior so I found one that I will restore and used it to guide me with how much of the tunnel cut.
  • Attached File  219.jpg   117.19K   8 downloads
  • Attached File  220.jpg   271.49K   8 downloads
  • Attached File  228.jpg   276.16K   8 downloads
  • Attached File  304.jpg   311.22K   8 downloads
  • Attached File  305.jpg   258.74K   12 downloads
  • Attached File  306.jpg   252.48K   8 downloads
  • Attached File  307.jpg   248.28K   8 downloads
#44 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 30 December 2019 - 10:04 PM
  • Attached File  308.jpg   194.92K   8 downloads
  • Attached File  320.jpg   278.66K   8 downloads
  • Attached File  322.jpg   269.67K   9 downloads
  • Attached File  326.jpg   257.35K   11 downloads
  • Attached File  327.jpg   254.12K   8 downloads
  • Attached File  328.jpg   259.23K   9 downloads
  • Attached File  329.jpg   250.39K   8 downloads
#45 Ice
  • 15,200 posts
Posted 30 December 2019 - 10:09 PM
Wow you're fab work is outstanding
#46 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 31 December 2019 - 09:10 AM
Hi Ice, Thanks for that. When I said I wanted the SL style it is with exceptions. I will be installing a drop tank (that arse needs the right undies)  a bonnet scoop and the dash will be silver. Think of it as a fully optioned SL. I will be mounting the battery in the boot it will fit where the spare wheel depression would have been.
  • Attached File  026.jpg   104K   8 downloads
  • Attached File  298.jpg   281.3K   8 downloads
  • Attached File  299.jpg   285.15K   7 downloads
  • Attached File  300.jpg   199.29K   7 downloads
  • Attached File  302.jpg   242.49K   8 downloads
  • Attached File  303.jpg   263.79K   9 downloads
#47 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 31 December 2019 - 09:15 AM
I have repaired the plenum chamber and then sealed the welds with mastic and any other pin holes and remade the fan entry port
  • Attached File  075.jpg   268.3K   8 downloads
  • Attached File  076.jpg   179.04K   8 downloads
  • Attached File  077.jpg   240.94K   9 downloads
  • Attached File  309.jpg   281.11K   8 downloads
  • Attached File  312.jpg   226.28K   8 downloads
  • Attached File  313.jpg   278.74K   8 downloads
#48 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 31 December 2019 - 09:17 AM
  • Attached File  315.jpg   204.02K   8 downloads
  • Attached File  314.jpg   235.64K   8 downloads
  • Attached File  318.jpg   239.37K   8 downloads
  • Attached File  319.jpg   245.4K   8 downloads
  • Attached File  345.jpg   148.63K   8 downloads
#49 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 31 December 2019 - 09:27 AM
And finally after a couple of years cutting drilling and welding I could cover the car in a 2 pac thick etch primer. It won't see any paint for a while, I'll continue to built the car until it starts drives and stops, Then I'll strip it for paint.
  • Attached File  161.jpg   300.57K   9 downloads
  • Attached File  195.jpg   282.94K   8 downloads
  • Attached File  332.jpg   295.59K   8 downloads
  • Attached File  335.jpg   212.81K   8 downloads
  • Attached File  336.jpg   210.43K   8 downloads
  • Attached File  337.jpg   277.32K   8 downloads
#50 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 31 December 2019 - 09:41 AM
I put the car on a rotisserie to prep and paint the underside. I painted the rails gloss black and sound dead flec over the floor pan then fitted the chassis strengthening kit, It when in easy and is very well made. Now is the time to bolt on some fun.
  • Attached File  662.jpg   285.17K   8 downloads
  • Attached File  663.jpg   278.35K   8 downloads
  • Attached File  722.jpg   202.81K   8 downloads
  • Attached File  727.jpg   151.32K   8 downloads
  • Attached File  732.jpg   323.92K   8 downloads
