The SL project
311 replies to this topic
#51 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
  • Car:LJ 2 door, UC hatch
Posted 31 December 2019 - 09:51 AM
The fuel system set up I'm using is : The drop tank has a swirl pot inside it that feeds to an electric lift pump mounted in line with the tank, that feeds a hi volume fuel pump I'm mounting in the boot area and then off to the fuel rail and a return to the tank from the fuel reg in the engine bay. The great thing about the Brown Davis tank is that it fits a standard fuel level sender.
  • Attached File  751.jpg   207.84K   12 downloads
  • Attached File  016.jpg   281.83K   11 downloads
  • Attached File  015.jpg   309.57K   12 downloads
  • Attached File  013.jpg   304.47K   9 downloads
#52 CI 0308
CI 0308
  • 736 posts
  • Car:77 LX SS, VX SS
Posted 31 December 2019 - 12:13 PM
Nice work Brother. I had forgotten all about that Blue 4 cylinder LH until you mentioned it. Sheet that was a long while ago. Keep them pics coming and hopefully she has a lick of colour in the not too distant future.
Sent from my SM-A520F using Tapatalk
#53 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 01 January 2020 - 02:26 PM
I have reduced the size of the heater fan duct to make room for fuel lines and internal wired the fan motor, all this info I owe to the many build projets like dirtbag and Burty. I really want to limit the wiring in the engine bay so I internal wired the wiper motor and shaved the terminal block.
  • Attached File  734.jpg   312.83K   10 downloads
  • Attached File  1180.jpg   91.02K   10 downloads
  • Attached File  1182.jpg   93.39K   11 downloads
  • Attached File  1181.jpg   88.95K   10 downloads
#54 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 01 January 2020 - 02:41 PM
The LS1 is a standard engine that had 70,000 when got it. Before installing it I replaced the oil pump, front seal and harmonic balancer (I went 10% reduced size) I also replaced the water pump and power steering pump had the injectors serviced and new plugs. The gear box got new fly wheel, clutch, pressure plate, bearing and a remote bleeder fitting. The theme for the engine is alloy, black and shiny. I have used as much braided line as I could for the build including the heater hoses
  • Attached File  043.jpg   101.55K   10 downloads
  • Attached File  044.jpg   104.39K   9 downloads
  • Attached File  045.jpg   96.69K   8 downloads
  • Attached File  011.jpg   85.06K   8 downloads
#55 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 01 January 2020 - 02:45 PM
Unsure what engineering rules Tassie has but i had no choice but to run a factory style manifold on mine. I would have loved to have done what you have done, great work mate :buttrock:
#56 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 01 January 2020 - 02:46 PM
I wanted an old school look for the engine bay so I chose a Victor Jr EFI manifold and Holly throttle body with Edelbrock fuel rail and coil pack covers. Nice Gary
  • Attached File  1213.jpg   137.4K   9 downloads
  • Attached File  062.jpg   173.25K   10 downloads
  • Attached File  1214.jpg   124.02K   8 downloads
  • Attached File  1216.jpg   107.29K   10 downloads
  • Attached File  014.jpg   277.76K   9 downloads
#57 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 01 January 2020 - 02:52 PM
The clutch reservoir is mounted on a bracket next to the brake reservoir . The master cylinder mounts above the steering column and direct connects to the pedal (sounds simple doesn't it)
  • Attached File  954.jpg   350.09K   10 downloads
  • Attached File  956.jpg   207.03K   13 downloads
#58 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 01 January 2020 - 02:56 PM
The diff is from Chris's differential service and is a 9' standard length housing with 31 spline axles with tru trac 3:5 gears. The springs are Lovells heavy duty lowered. I took them to the local spring works and had them squeezed another 20mm
  • Attached File  030.jpg   354.18K   9 downloads
  • Attached File  031.jpg   230.65K   9 downloads
  • Attached File  019.jpg   320.71K   9 downloads
Edited by Ricky Bobby, 01 January 2020 - 03:00 PM.
#59 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 01 January 2020 - 03:07 PM
The brakes are from hoppers and are 290mm twin pot fronts and VR Disc and drum rears. That ort to do it. The brake booster is a duel diagram and the master cylinder is for an AU Ford I think. I had my first go at running new brake lines to keep them out of the engine bay.
  • Attached File  021.jpg   373.67K   10 downloads
  • Attached File  024.jpg   273.92K   9 downloads
  • Attached File  008.jpg   131.87K   13 downloads
  • Attached File  064.jpg   111.58K   11 downloads
#60 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 01 January 2020 - 03:21 PM
The radiator is a PWR dual chamber unit with electric fan and is made to suit LS1 into LX
  • Attached File  016.jpg   147.75K   9 downloads
  • Attached File  555.jpg   240.97K   9 downloads
  • Attached File  861.jpg   274.78K   9 downloads
  • Attached File  039.jpg   98.45K   9 downloads
  • Attached File  859.jpg   304.98K   9 downloads
#61 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 01 January 2020 - 03:27 PM
One of the most important choices for a car build is the rims, I stared looking then stopped when I saw these. They are from Canterbury Tires and are 15 x 7 and  15 x 8 with 225/50 tyres. I'm really happy with the look ( not sure on the stance yet )
  • Attached File  258.jpg   72.26K   11 downloads
  • Attached File  001.jpg   314.06K   10 downloads
  • Attached File  027.jpg   327.94K   11 downloads
  • Attached File  028.jpg   325.56K   10 downloads
#62 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 01 January 2020 - 03:36 PM
The exhaust is next. It was the only problem I had with CRS gear. The RHS extractor doesn't work with the steering and you need to install it with the engine half out of the car. I used a local frabrication place and they came up with a solution that worked They turned the extractor into a 2 piece unit with a V band joint and now it works. The exhaust is 2 1/2 inch stainless with cat converters and I had the extractors ceramic coated. The pipes had to go under the diff, not my first choice but it would mean to much fab work in that hump area. I'm still happy. I also had them make me a sump protection plate
  • Attached File  002.jpg   267.19K   17 downloads
  • Attached File  003.jpg   148.59K   12 downloads
  • Attached File  004.jpg   177.5K   12 downloads
#63 axistr
axistr
  • 1,212 posts
Posted 01 January 2020 - 03:38 PM
Great work Harvey, Good metal working skills.
#64 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 01 January 2020 - 03:42 PM
The wiring is a massive job, I didn't want the ECU, fuses and relays filling up the glove box area. So I made the call to locate it all in the back of the car where it is accessible and run the loom through the car ( 70 wires) I am an electrician so its not quite as hard as it looks
  • Attached File  007.jpg   164.61K   13 downloads
  • Attached File  009.jpg   172.84K   9 downloads
  • Attached File  067.jpg   174.62K   10 downloads
  • Attached File  068.jpg   155.73K   9 downloads
  • Attached File  0187.jpg   166.02K   11 downloads
#65 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 01 January 2020 - 03:49 PM
The stereo is pretty important for me and going with the pro tour style it need to have all the good bits. The stereo can date the interior of the the car so I went classic. It has 4 channel output, blue tooth, phone connection, 2 x aux output ( I fitted one of the aux outputs in the choke knob postion of the dash for the phone ) I added a USB charger to the console and any good SL would have a heated back window
  • Attached File  222.jpg   159.35K   9 downloads
  • Attached File  666.jpg   148.28K   9 downloads
  • Attached File  777.jpg   124.38K   9 downloads
  • Attached File  088.jpg   126.9K   9 downloads
  • Attached File  025.jpg   133.25K   10 downloads
#66 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 01 January 2020 - 03:52 PM
The interior is finished and packed away. I looks brilliant. I also found some where to put all the receipts.
  • Attached File  121.jpg   110.8K   9 downloads
  • Attached File  369.jpg   105.19K   9 downloads
  • Attached File  026.jpg   385.17K   9 downloads
#67 rodomo
  • 18,037 posts
Posted 01 January 2020 - 10:45 PM
Great work! I can't help feeling this might actually be finished? :huh:
#68 LXCHEV
LXCHEV
  • 3,607 posts
  • Car:'76 LX - 383 Chev
Posted 01 January 2020 - 11:21 PM
Sensational build - I love what you're doing with this thing.
#69 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 02 January 2020 - 09:45 AM
No such luck Rodomo, The picture history is pretty much up to where I am. I've completed about 90% of the electrics and I'm starting to fill her up with liquid I have clutch, brakes, engine oil and a coolant leak in the thermostat housing (no rubber ring). I'll fix that when the parts place opens and then turn it over for oil pressure. I hope to have it running this month. Then paint, so looking in the glass ball I'd say mid this year with a plan to have approved and registered for summernats 2021
#70 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 02 January 2020 - 10:09 AM
Just a few more pics the gauges are auto meter with a GPS speedo and it plugs into the existing harness. You just add an extra oil and coolent senders to the block.I have located the washer bottle to the inner guard It's just one I got of ebay that looked like it may fit. And the list is getting smaller
Edited by Ricky Bobby, 02 January 2020 - 10:10 AM.
#71 CI 0308
CI 0308
  • 736 posts
Posted 02 January 2020 - 10:26 AM
Haha. You havnt changed a bit. Everything sooo organised. Nice work Harv..
#72 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
Posted 02 January 2020 - 11:13 AM
Yeah you know me Tex, I had a pic of your SS and Chris's SLR at the workshop when you picked it up. I'll some how weave it into the story. Weave, weave
  • Attached File  804.jpg   234.35K   15 downloads
  • Attached File  806.jpg   277.97K   12 downloads
  • Attached File  805.jpg   292.82K   15 downloads
#73 CI 0308
CI 0308
  • 736 posts
Posted 02 January 2020 - 11:39 AM
Nice "weaving"
#74 bags
bags
  • 78 posts
Posted 02 January 2020 - 10:22 PM
Awesome build mate. Keep up the good work. Can’t wait to se progress
#75 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 04 January 2020 - 06:31 PM
Hi Harvey
So much to take in and liking the photo's
Have a query with this one though
Went the same path with mine using the fittings to the heater box
In the pic the left hand line fitting looks to be against the engine  - do you have enough clearance so with the motor movement it wont be working the heater pipes (internally)
If it is touching it would be like it being hard piped
Bastard of a spot to get to if things come loose or fracture while you are on the road
Attached File  post-53388-0-97284500-1577853544.jpg   96.69K   15 downloads
