Aftermarket Gauges in Original Facia
13 replies to this topic
#1 Savvas
Savvas
  • 73 posts
  • Name:Sav
  • Car:73 LJ 2 Door
Posted 06 March 2020 - 06:00 PM
Just thought I'd share what I did with my gauges for my LJ
I still wanted that original look but with the engine swap I wanted all electric gauges.
I only had a facia. So I bought some brackets off of Benjamin ([email protected]) he has said he was happy to link his email but would need a few orders before he could make up a new batch. They needed only slight adjusting for the smaller brackets as well as some very minor grinding on a few of the gauge holes to fit.
I used the VDO Vision series gauges to closely match the original.
The brackets are designed to fit narva 14mm pilot lights. 2 for the top and one for the bottom.
The brackets are designed for the 85mm gauge and Ben provides a document which details how to fit those. I already had the 80mm gauges so I had to make some tabs. They sit out a bit but I couldn't be bothered making my tabs space them back.
I also used some ebay special pilot lights for the engine management and high beam indicator lights.
You could use the same principle with any 52mm/85mm gauge series although the thickness of the gauge bezel may affect fitment.
If this is in the wrong section feel mods please delete.43d32763ead617bf6f8e1ec69cddee7c.jpg3f19c0bc7e42c2b130fdc2f8754a7de2.jpg
Sent from my SM-G975F using Tapatalk
#2 jpxu1
jpxu1
  • 570 posts
Posted 06 March 2020 - 07:57 PM
That's an LC fascia you have used. For a modern factory look, it's pretty sweet  :buttrock:  :tongue4:
(The factory gauges for LJ had the Temp/Fuel, Volt/Oil  in opposite positions- the Temp/Fuel is correct for LC though- not that it matters in your application.)
I reckon it makes sense to have the two important gauges -Temp & Oil - on the same side though, just my thoughts.
JPXU1  :D
Edited by jpxu1, 06 March 2020 - 08:07 PM.
#3 Savvas
Savvas
  • 73 posts
  • Name:Sav
  • Car:73 LJ 2 Door
Posted 06 March 2020 - 08:12 PM
I realised after that I had them the wrong way round. Will be changing it before I install it in the car haha
#4 S pack
  • 15,691 posts
Posted 06 March 2020 - 09:41 PM
Do you have all the lower mounting brackets for the LC instrument panel? You will need them to fit that dash in your LJ.
#5 Savvas
Savvas
  • 73 posts
  • Name:Sav
  • Car:73 LJ 2 Door
Posted 06 March 2020 - 09:44 PM
No I do not. I will now be on the hunt for a set
#6 _LONA-CK_
_LONA-CK_
Posted 07 March 2020 - 07:14 AM
no need to hunt I have heaps give me a call 0478847765
cheers gong
#7 Savvas
Savvas
  • 73 posts
  • Name:Sav
  • Car:73 LJ 2 Door
Posted 07 March 2020 - 10:20 AM
Does anyone need some spare lenses
Brand new repro ones from rares.
#8 gad05
gad05
  • 421 posts
  • Name:Graham
  • Car:73 lj 2 door , 74 lj sedan.
Posted 10 March 2020 - 10:26 AM
Nice job with the gauges Sav.
Could you list the part numbers you used, looking to do the same conversion very soon.
Cheers Graham.
#9 Savvas
Savvas
  • 73 posts
  • Name:Sav
  • Car:73 LJ 2 Door
Posted 10 March 2020 - 11:58 AM
Cheers Graham.
I haven't got part numbers but I'll post a bunch of links later
#10 yel327
  • 13,599 posts
Posted 10 March 2020 - 12:09 PM
Here is a fuel sender converter if you need one. Will work with later MRA units too if you modify your tank for an EFI engine for example.
http://www.yogisinc....od/prd17091.htm
#11 Savvas
Savvas
  • 73 posts
  • Name:Sav
  • Car:73 LJ 2 Door
Posted 10 March 2020 - 04:33 PM
That's a good link. So basically that module will convert my signal from the original xu1 style sender (30 ohm?) And I can convert it to read properly on the VDO gauge?
Very cool!
#12 yel327
  • 13,599 posts
Posted 10 March 2020 - 05:51 PM
Basically yes. There are cheaper versions that are harder to setup too on Aussie EBay for about $80, but do the same job once they are setup.
I’m using mine to convert the signal from the VY MRA I had fitted to the GTS’s tank, to the HK fuel gauge. From memory the VY MRA is 40-250 and the HK dash is 0-30. I like the low fuel level switch too, will be a good reminder tool. I remember running out of fuel twice in my ‘57 Chev due to the vagaries of the gauge on the dash.
#13 Savvas
Savvas
  • 73 posts
  • Name:Sav
  • Car:73 LJ 2 Door
Posted 10 March 2020 - 08:09 PM
Cheers Graham.
Thanks Graham
I used a factory facia
The mounting brackets for the gauges are from Benjamin (email in the first post)
Gauges are the VDO Vision series. 52mm I think for the small ones and 80mm for the larger ones (the brackets are designed to fit 85mm gauges, this seller can supply all the gauges at the specific size you want.)
https://www.ebay.com...tm/321699139112
The lights for the indicators and brake light are narva 14mm pilot lights.
https://www.ebay.com...tm/301819854291
https://www.ebay.com...tm/291627013201
The engine light and high beam indicators I just got these cheap ebay ones, they are small and are black when they aren't lit up. (they have all different symbols available)
https://www.ebay.com...tm/401379080698
#14 gad05
gad05
  • 421 posts
  • Name:Graham
Posted 11 March 2020 - 10:37 AM
Thanks Sav.
