Nolathane or Urethane bushes?
Posted 26 August 2006 - 09:42 AM
Whats the pros & cons of each type?
Posted 26 August 2006 - 11:21 AM
_LH SL/R 5000_
Posted 26 August 2006 - 12:35 PM
_UCV80_
Posted 26 August 2006 - 01:34 PM
i used both types in my front end
people say the nolethane ones crack...??? i hope mine dont haha
Edited by ToranaZ, 26 August 2006 - 01:37 PM.
Posted 26 August 2006 - 04:02 PM
Problem was when I put the hard nolathane bushes in the trailing arms,very noisey,annoying & makes the car feel like it's metal to metal when you hit bumps.The bushes in the diff housing are std rubber so there is some give.
The car does handle better but it sucks on rough roads(sydney) & it isn't helped by having low profile tyres.
If you want to drive it regularly & don't want it to be noisey/annoying then don't put in the hardest grade bushes,especially if you have low profile tyres.
_keith1962_
Posted 26 August 2006 - 04:33 PM
street use the standard ones are better. On the other hand by the
use of the harder ones for the race track.
cheers Keith
Posted 26 August 2006 - 06:35 PM
i was advised to use rubber in either the upper OR lower and urethane in the other which is what i did!
Nolathane is definiteoly just a brand of urethane bushes, and gtrboyy is right you can get different grades!
I was advised to go to Pedders suspension ( speciafically the Liverpool in Sydney branch because they deal with a lot of race cars) as they have the knowledge of putting which hardness bushes wehre to achieve your desired ride feel and stability!
Cheers!
_SSHatch_
Posted 26 August 2006 - 06:54 PM
Best option is to go for the Nolathane in the lower arms in the rear and stick with the standard genuine bushes in the top arms.
The softer bushes in the top absorb some of the on-off throttle "knocking" better.
With the Hard bushes all through the rear the early Holdens have a tendency to tear the mount points out of the floor.
Posted 26 August 2006 - 10:51 PM
Where I stuffed up was using the hardest grade in the trailing arms thinking it would help traction,my traction problems were incorrect settings with the coil-overs.
Posted 27 August 2006 - 08:21 AM
Posted 27 August 2006 - 12:52 PM
_MRNOS_
Posted 27 August 2006 - 08:42 PM
Posted 28 August 2006 - 10:46 AM
Im pretty sure these are the ones my alignment guy recommended.
So the medium grade hardness ones might be the go.
Lots of good advice here, thanks for everyones input.
Posted 28 August 2006 - 04:03 PM
Toranamat69 would be the best one to seek advice from though,he really gets into suspension stuff if you remember his posts on the old forum & here as well.Great reading IMO.
Posted 28 August 2006 - 04:06 PM
Superpro webpage
catalogue
If you have a look at the LX catalogue printout from the webpage above, it shows the options available for comfort, sport and competition use - I stuck with 'comfort', as it is still a lot stiffer than rubber.
They grade the density of the urethane according to its application in the suspension system (stiff where it's an advantage, more compliant where it needs to be). The "Nolathane' brand is all high density (stiff), irrespective of its application.
I got a full set of superpro bushes for my hatch, custom made in black. I ordered the set through Morpowa Auto Centre, just off Milne Rd (08 8264 2077).
_fatA9X_
Posted 28 August 2006 - 06:59 PM
Posted 28 August 2006 - 10:14 PM
The guy who started Nolothane sold out and now has Noltec
They are much better in my opinion
Posted 30 August 2006 - 10:07 PM
http://www.gmh-toran...st=0#entry86050
For the Front end, I currently have polyurethane everywhere and a solid mounted UC rack but I dont like the squeaking of the polyurethane.
I have heard mixed reactions about using the poly we get locally in the upper A arm pivots. I can see the problem with them but I have never done a comparison to see if they make the handling worse or better specifically.
I have found at least one other option but I havnt tried it on the road yet.
M@
_BCR42Y_
Posted 04 October 2006 - 03:01 PM
I have heard of Noltec before would you guys recommend them for the whole front end? Or would you use a mix of rubber in certain spots.
The cars end use is going to be straight line basically....
Regards Halil.
