Electronic Ignition Conversion 202
13 replies to this topic
#1 _johnm_
_johnm_
Posted 18 May 2020 - 08:18 AM
Hi, Can anyone recommend a reliable Electronic ignition conversion for a 202 Red motor, tired of changing points.
#2 yel327
  • 13,655 posts
Posted 18 May 2020 - 08:42 AM
Get a dizzy and coil from a VC-VK (not EFI) or WB. Bolt it in with new leads and right plugs for the engine and head. Just have to bridge the pink and yellow wires at the ignition switch.
Given how old they are would be worth getting the dizzy rebuilt and get it graphed to suit your engine at the same time.
If you can’t get an original coil you have to buy an aftermarket one and make up a bracket for it.
Here you go
https://www.ebay.com...5sAAOSwPyRelXBD
You can buy Chevy HEI ones (coil in cap) cheap too that you can change springs in yourself but they are cheap
Edited by yel327, 18 May 2020 - 08:43 AM.
#3 originalglenn
originalglenn
  • 594 posts
Posted 18 May 2020 - 09:27 AM
http://www.gmh-toran...olden-6-how-to/
#4 yel327
  • 13,655 posts
Posted 18 May 2020 - 09:45 AM
Here is one ready to go. There are cheaper ones on EBay too
https://www.ebay.com...noAAOSwGSZep2Y1
#5 hanra
  • 10,983 posts
Posted 18 May 2020 - 10:32 AM
Pertronix module fitted to your existing dizzy.
#6 Ice
  • 15,204 posts
Posted 18 May 2020 - 02:04 PM
Procomp mmm dont know about them
Buy the Bosch one problem solved
#7 yel327
  • 13,655 posts
Posted 18 May 2020 - 02:40 PM
I agree Gene. It is just an example of GM HEI ones modified ready to go.
#8 RallyRed
  • 8,155 posts
Posted 18 May 2020 - 07:00 PM
Hi,
Over the last few years Iv'e tried the Chinese "Bosch"...no good, bearings flogged out super quickly.
Now using a Scorcher, which I bought out of Melbourne. Think they actually make them there. No issues, and good local tech. line.
Edited by RallyRed, 18 May 2020 - 07:01 PM.
#9 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
  • Car:1971 LC 4 door
Posted 18 May 2020 - 07:14 PM
Hi
I found a LC/LJ with a GTR dash and GTR tacko that the early VC/VB electronic ignition operated the tacko better than the later VK one would. The needle didn’t seen to jump around.
#10 rodomo
  • 18,039 posts
Posted 18 May 2020 - 11:40 PM
VK EFI had the same type of dissy as VC/VH/WB. It was the VK carby job that had the weirdo dissy with the pick-up off the flywheel.
The VK EFI dissy has stronger advance springs suited better to hi-comp.
#11 N/A-PWR
  • 9,639 posts
Posted 08 November 2020 - 02:03 PM
Hi,
I just was looking at the Scorcher today, and found this thread:
Attached File  rs=w_600,h_600 (1).png   263.45K   5 downloads
https://performancei...-253-slash-308
Attached File  rs=w_600,h_600 (1).jpeg   17.53K   4 downloads
https://performancei...igh-energy-coil
$400 for Dizzy and $95 for coil to 15,000rpm,
and they set it up to your engine spec's and fuel type  :spoton:
#12 yel327
  • 13,655 posts
Posted 08 November 2020 - 02:59 PM
Correct, I should have typed (EFI) not (not EFI).
#13 N/A-PWR
  • 9,639 posts
Posted 08 November 2020 - 03:17 PM
We need to find a NOS one  :spoton:
#14 N/A-PWR
  • 9,639 posts
Posted 08 November 2020 - 03:50 PM
Reproduction WB/VK Dizzy:
https://www.ebay.com...E-/162275749301
Wonder if the copy has the stronger advance spring as Rob suggests ?
