LJ Correct speedo cable route
Posted 09 June 2020 - 10:38 PM
Just checking someone can share a diagram showing the correct LJ speedo cable route?
Posted 10 June 2020 - 09:43 AM
Hi Ben not sure if LC the same but put it this way you don't get it right you will be buying a few as i did as i wasn't sure what way it went either and broke a few.
Has to go thru this from memory and out a hole at end.
Some will correct me if i'm wrong
Thanks Wayne for pic
Wayne.jpg 435.24K 14 downloads
Posted 10 June 2020 - 10:43 AM
That's correct. The speedo cable is routed down through that hole in the steering column support. At the instrument panel end ensure the speedo cable runs between the plenum panel and/or windscreen demister plastic air duct and the main wiring harness.
Posted 10 June 2020 - 12:18 PM
Posted 10 June 2020 - 01:35 PM
Thru that hole Ben heading down then to left to the floor
Posted 10 June 2020 - 07:51 PM
Posted 10 June 2020 - 08:09 PM
Ok many thanks! I get why the short cut was taken around the column. I did one around 20 years ago so a bit vague now but was pretty sure it went through the column support, but I seem to think I put it through from the firewall side and up through the column support to the dash though. Are you saying feed from top (dash end) down through firewall to gearbox is the best way?
Can only be installed one way because of the firewall grommet pre-installed on the cable and that is from the engine bay through the firewall and up through the hole in the column support.
Posted 10 June 2020 - 09:29 PM
