202 dyno drop of
36 replies to this topic
#1 basicgreen
basicgreen
  • 225 posts
  • Name:rick
Posted 10 July 2020 - 03:23 PM
hi guys i have a  202 that made 145hp on the dyno at 4700..then it just rolls of.. dyno man said might be springs getting soft more we did run it.it got less and less..had on the dyno from basically day one from build and always drops of around the 5000 mark..going to be putting supercharger on soon and have head of and going to do springs.. my question is i have had my plugs at 50tho all this time with a vk dizzy and msd street fire box and msd ss coil do you think that the plug gap was way to big.???.never thought to look into the gap when was running.. plain on running about 30 with supercharger
cheers for any advice
#2 Dr Terry
Dr Terry
  • 3,325 posts
Posted 10 July 2020 - 03:41 PM
Hard to read. The word OFF has two Fs.
Dr Terry
#3 rodomo
  • 18,040 posts
Posted 10 July 2020 - 10:21 PM
Is that all you have to offfffer Terry?
#4 _Lazarus_
_Lazarus_
Posted 10 July 2020 - 11:53 PM
So it's actually a spelling problem, not mechanical ?
#5 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 11 July 2020 - 07:48 AM
Gap is too big. Are the springs new and matched to the cam i.e seat pressure and on the nose.
Have you had your head flowed?
#6 Bigfella237
Posted 11 July 2020 - 08:14 AM
Could be any combination of about a hundred & one things!
Could be anything (or things) in the valvetrain, cam timing, ignition timing, voltage/coil/spark, fuel supply, intake/exhaust tract restrictions, temps, etc.
I assume you are watching the WBO2 readings and it's not leaning out?
Would need a ton more data and some history of the engine before anyone here could even guess what the problem might be.
It's a bit like saying "There's a funny noise in my car, what do you think it is?" :blink:
#7 basicgreen
basicgreen
  • 225 posts
  • Name:rick
Posted 11 July 2020 - 11:49 AM
thanks guys
its a 208 blue bottom efi 12 port head..has vr v6 valves witch are a bit longer so springs were to..manifold is a/speed and a 570 carb
head flowed 248hp and i must say that from 500 lift to 550 lift there was only .2 difference if i read it correctly..lost the email now
the cam is 35647 517 lift 245 dur 107 sep..10.4 comp ( a little less than i thought)
the engine was new and it seems every dyno run (4)  it seams to run OFF at about 5000
we were only doing timing and afr most of time not dynoing for every bit of horse power  $250 a shot
i am just thinking back that one thing that stayed the same was plug gap and just wondering if  that could  could have bean a cause
thanks again
#8 Zook
Zook
  • 1,536 posts
Posted 11 July 2020 - 06:46 PM
Haha, funniest thing I've read in ages. I didn't get any of it except that it could have been this Bean's fault.
#9 arrimar
arrimar
  • 3,134 posts
Posted 11 July 2020 - 07:00 PM
Is it true MSD is code for My Spark Died?
#10 Oversteer
Oversteer
  • 244 posts
  • Car:LH SLR5000
Posted 12 July 2020 - 03:13 AM
If it didn't miss fire your plug gap has nothing to do with not making power.
Likely valve train or cam timing issue if afr's and ignition curve are sensible and efi and ignition system is set-up and working correctly.
#11 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 12 July 2020 - 08:56 AM
I personally do not think the 50 thou gap is the culprit. I run 50 thou now with my JZED headed engine. It would help if you could upload a dyno curve- this will help identify the issue.
My gut says spring pressure or other valve control issue but would need to see the curve. What exhaust system are you running?
#12 basicgreen
basicgreen
  • 225 posts
  • Name:rick
Posted 12 July 2020 - 12:25 PM
Attached File  dyno fb.jpg   200.52K   6 downloads hope this works
#13 basicgreen
basicgreen
  • 225 posts
  • Name:rick
Posted 12 July 2020 - 12:35 PM
thanks guys exhaust is pacemaker with 2.5 exhaust and hooker muffler.. new pipes to go on are cae 1/58 prim
and the dur on cam is 254  not 245
will be defiantly be doing springs
thanks again
#14 _lawn bowls_
_lawn bowls_
Posted 12 July 2020 - 02:51 PM
if the cam is 254 @ 50 thats a very big cam maybe its noising over cause of not enough carby
#15 basicgreen
basicgreen
  • 225 posts
  • Name:rick
Posted 12 July 2020 - 03:42 PM
this dyno run we did back to back runs with 450 carb (132hp) then 570 brawler made 143 then gave it bit more fuel and made 145  but still rolled over
thinking probably springs like the dyno man said and what has bean said here
#16 rexy
rexy
  • 3,740 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 13 July 2020 - 10:51 AM
The dips in your power and torque curves appear to correspond to your AFR rising above 13. That early hole is going to make it shitty to drive unless it’s a strip only car.
#17 basicgreen
basicgreen
  • 225 posts
  • Name:rick
Posted 13 July 2020 - 01:19 PM
hi think the dip  is the secondaries opening
#18 rexy
rexy
  • 3,740 posts
  • Name:Rexy
Posted 13 July 2020 - 11:45 PM
Should be able to rectify.
Your graph suggests the fuel side is still part of the problem.
14:1 under full load is getting a bit close to the edge. And it’s costing you power.
#19 basicgreen
basicgreen
  • 225 posts
  • Name:rick
Posted 15 July 2020 - 02:41 PM
cheers Rexy will take it up with dyno man when i get it back on the road..( bloody virus) holding things up
#20 skap
skap
  • 1,105 posts
  • Name:Skap
  • Car:Mighty VN
Posted 16 July 2020 - 09:50 AM
May I suggest swapping it out for a bog stock LS1.
That will solve your lack of horsepower issues. :)
#21 claysummers
claysummers
  • 3,640 posts
  • Name:Clay
Posted 16 July 2020 - 02:14 PM
Black efi Holden six rated at 104kW @ 4400rpm from memory. You're getting same output at higher revs??
#22 yel327
  • 13,658 posts
Posted 16 July 2020 - 02:37 PM
This is a chassis dyno. Holden’s ratings are engine dyno but the VK is DIN so probably comparable to chassis dyno divided by loss factor.
#23 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 16 July 2020 - 03:48 PM
All those litres of capacity, all the engineering and fabrication, only to make less then a mild 202 with a strata setup. Each to their own I guess.
#24 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 16 July 2020 - 03:52 PM
I am curious with whats going on with the rpm at 140kmh- the rpm drops from 5300rpm to 3740rpm but wheel speed is increasing... looks like the run has been recorded in third gear and shifted just after 130kmh?
Am I missing something?
#25 warrenm
warrenm
  • 2,118 posts
  • Car:1972 LJ Torana
Posted 16 July 2020 - 11:20 PM
I think you're right, something odd going on.
