202 dyno drop of
36 replies to this topic
#26 basicgreen
basicgreen
  • 225 posts
  • Name:rick
Posted 17 July 2020 - 03:24 PM
yea i saw that and did not no what it was doing..and the nm also is not right think on the day it made about  348nm
first dyno made 128hp(465 carb) then on another dyno made 145hp (450carb) and more nm then went back to the first dyno with only changing diff gears from 3.36 to 3.9 and it made 132hp then changed the carb to 570 and made 145hp
so if went back to the other dyno might be different again
all the time only making to around the 5000 mark before it drops off
was done in 3rd trymatic
thats a big no for v8 will be putting on a magnuson 112 supercharger very soon just the guy doing the kit lives in Melbourne and the virus is slowing him up
it just seams like some thing is holding it back on dyno but it drives quite well
could it be the comp.. the cam said 11.1 comp minimum and i have 10.4 ??
hope you can understand all that
and thanks for your input
#27 _lawn bowls_
_lawn bowls_
Posted 17 July 2020 - 03:28 PM
usaly 3 speed autos are dyno in second gear
#28 yel327
  • 13,658 posts
Posted 17 July 2020 - 03:37 PM
Isn't the 112 a bit big for a 202? The 112 was designed for engines from about 5 litres from memory. I would have thought an M90 would be a better choice for a small engine like a 202? It is what is used on my 4.0L Hilux.
What sort of boost are you intending? I only run about 6.5psi but I also have 10:1 compression
#29 basicgreen
basicgreen
  • 225 posts
  • Name:rick
Posted 17 July 2020 - 03:59 PM
hi yea a guy was selling it and i garbed it.. it was a new one for $1250 so i garbed it.. its carb top mount
i am going to get my comp down to 9.1 and going to have 2 pulleys 12 psi and a 15 psi and will stay with the na cam.. i no it will bleed off so thats why i am thinking 15 psi
will be interesting
#30 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 27 July 2020 - 03:23 PM
May I suggest swapping it out for a bog stock LS1.
That will solve your lack of horsepower issues. :)
the LS engine is for people who want to go fast but have no money.
#31 yel327
  • 13,658 posts
Posted 27 July 2020 - 03:35 PM
I’ve been eyeing off a SBC Eaton 112 kit for SBC. The twin carb one is about $5800 in Australia. You can get a single carb version for under $5000 but they work better with dual carbs. Maybe one day!
#32 basicgreen
basicgreen
  • 225 posts
  • Name:rick
Posted 29 July 2020 - 03:37 PM
Attached File  IMG_20190515_111415 (2).jpg   188.19K   3 downloads
this is the one i am trying to get on soon i hope
$1250 cant complain
#33 yel327
  • 13,658 posts
Posted 29 July 2020 - 04:39 PM
I reckon you’ll complain when you find it’s too big for a tiny engine like a 202!
#34 Pop's-SS
Pop's-SS
    Pops
  • 4,971 posts
  • Name:Barry
Posted 30 July 2020 - 11:57 AM
Is that all you have to offfffer Terry?
Hey Rob, was you sssssstutttttering when you typed that  :dontknow:
RegardSSSSS ...... Barry
#35 basicgreen
basicgreen
  • 225 posts
  • Name:rick
Posted 30 July 2020 - 01:59 PM
this is the first time i have had anything to do with supercharges.. but dont they put 142..192..and 4/71 and 6/71 on 202s
i was thinking that 112 wont have to work hard to give me 15psi
but always learning
#36 yel327
  • 13,658 posts
Posted 30 July 2020 - 04:39 PM
I have a manifold for a 4/71 onto a Hemi 6.
Most theory I have seen for GM blowers is for say a 400ci engine you use a 6/71 for up to about 8-10psi, no point in using an 8/71. The 6/71 will do say 18psi but has to be overdriven a lot to do it and thus generates more heat, whereas an 8/71 will do that easily. So your theory is sound in theory. My concern is the size of the blower versus the size of the engine. But someone that does these all the time will give you far better advice!
#37 basicgreen
basicgreen
  • 225 posts
  • Name:rick
Posted 31 July 2020 - 03:34 PM
a hemi would love a 4/71
advice is always good
