Turbo to Trimatic pattern
17 replies to this topic
#1 _JJ21_
_JJ21_
Posted 29 July 2020 - 11:30 AM
Hi again,
Couldnt find any recent posts so asking a question please....
Whats the best option atm for bolting up M21 to turbo pattern block?
Drilling and tapping? (If so, whos the go to in Perth).
Using adaptor plate? (how good are they? And who would you buy from?) And does any modification need doing to crossmember/tailshaft?
Or, i thought i have seen manufactured bellhousings specifically for this?
Appreciate any form of help, thanks.
Edited by JJ21, 29 July 2020 - 11:33 AM.
#2 Bigfella237
Posted 29 July 2020 - 11:51 AM
G'day Jason,
I wouldn't drill & tap myself, if the dowel pins were in the same spot between the two patterns then I'd say yes, but having to move the dowel pins half a hole as well can lead to trouble unless you dial-in the bellhousing again properly.
Adapter plates also have drawbacks, having everything spaced backward can lead to balance and alignment issues too.
An adapter bellhousing is definitely my choice, there are a few different companies that make them but one of the more common is "Dellow Conversions" in Sydney who have been making them since the 70's.. They're pretty common and quite often come up second-hand on gumtree / ebay / etc.
#3 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 29 July 2020 - 11:59 AM
Good advice above ^^
#4 _JJ21_
_JJ21_
Hi Bigfella, alright cool mate thanks for that.
Maybe thats what i seen advertised sometime ago, kinda knew i shouldve grabbed it, was in Perth too.
#5 _JJ21_
_JJ21_
Posted 29 July 2020 - 12:02 PM
Was also looking at cable clutch. I know theres plenty of chat about that, which sometimes can get your head spinning.
But wondering if these Dellow bellhousings suit running cable?
Its late LX 8/77
#6 yel327
  • 13,658 posts
Posted 29 July 2020 - 12:37 PM
Just be careful which bellhousing you buy as some clutch mech setups mount off the bellhousing bolts using special bolts. Some of the aftermarket housings use longer bolts, also the bolts move for SBC pattern.
Full cable clutch can be a problem as there are no V8 UC clutch pedals do you have to modify a 6cyl or Starfire one.
There is a guy in Sydney who redrills the blocks for less than $300 but it is done off the crankshaft so it is hard from Perth.
#7 _JJ21_
_JJ21_
Posted 29 July 2020 - 12:57 PM
Hi mate, yes those cable clutch mount brackets (seen on Ebay) were what i was thinking of using, thats why i posed the question
#8 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
  • Car:1971 LC 4 door
Posted 29 July 2020 - 06:24 PM
It’s been tried many times the 4 speed conversion to Trimatic pattern
Success rate is very low
Dazm
#9 yel327
  • 13,658 posts
Posted 29 July 2020 - 06:50 PM
Have a look at this CRS bellhousing. They are a multi fit so suit TH or 4spd block. See how the the bottom bolts are far longer? Really screw up the standard Torana V8 and HX to mid 1978 HZ both with half cable, half rat-trap mechs. Works OK with HT-HJ or mid HZ-WB setups.
In a Torana might be worth investing in a hydraulic setup?
https://www.rodshop....ll-housing.html
https://www.rodshop....rsion-1340.html
Edited by yel327, 29 July 2020 - 06:53 PM.
#10 Ice
  • 15,204 posts
Posted 29 July 2020 - 07:47 PM
Dazm
Not if you use the right parts
#11 dattoman
  • 16,487 posts
Posted 29 July 2020 - 08:19 PM
CRS and Dellow will be your main culprits for a bellhousing to bolt straight up
There were some from Seton Engineering too... but I've never seen one
I just bought a bellhousing from Dellow for another project... $800 by the time it landed here in Perth
And that's just a bare housing... nothing with it
Should be here in a week or 2
I have this CRS bellhousing to put turbo block to aussie 4 speed
But its not the later style cable setup and has no fork etc...I was going to use a hydraulic system so didn't care
Shop it around and keep your eye out... one might pop up eventually
If you want to get it redrilled you'll have to strip the engine and take it to someone like Gardiner Engineering in Welshpool for him to do
Attached File  turbo to ausie.jpg   239.15K   2 downloads
Attached File  t to oz.jpg   126.08K   3 downloads
#12 _JJ21_
_JJ21_
Posted 29 July 2020 - 10:14 PM
Thanks everyone for your response. I will keep my eye out for bellhousing or possibly chase down a trimatic engine maybe
#13 Statler
  • 6,318 posts
Posted 30 July 2020 - 10:22 AM
Place a WTB post on the torana / kingswood / commodore FB Groups & i'm sure you will find one. Plenty of guys with T-5's will have them gathering dust somewhere . lol
Modifying a clutch pedal for cable is simple if you can weld .
I don't think spacers & manuals mix .
There is also 'Aussie 4-speeds' who were advertising their re-co services . Might be worth a call .
Try and get the inspection cover with it if you can .
#14 yel327
  • 13,658 posts
Posted 30 July 2020 - 11:19 AM
Doesn’t have to be Trimatic. Any manual HT through to VL 308/304 will do.
But if you can’t get the block redrilled locally, far better converting to a hydraulic clutch and just buy a Chev to Aussie 3/4spd bellhousing either new or used. I think GMH may have even made them, but not for local use. Some of the South African HK through to HX had Chev type 6cyl engines with Aussie 3spd, just not sure if they were 6cyl or V8 boxes. Chevrolet gearboxes like Saginaw, Muncie, T10 etc sit somewhere between Aussie 3/4spd input shaft lengths do not sure which way they went with them.
#15 Bigfella237
Posted 30 July 2020 - 08:13 PM
I wouldn't go to the trouble of swapping blocks, and it's getting hard to find a decent 308 block these days.
How set are you on the Aussie 4 speed?
For the cost of the bellhousing (a brand new one anyway) you might find a whole T5 gearbox out of a VN-onward Commodore V8 that will bolt straight up to your TH block. You will still need to convert to a cable clutch, and maybe swap the extension housings if you don't want to cut the tunnel, but they would probably handle the same amount of abuse as an M21 (which isn't a lot really).
#16 _JJ21_
_JJ21_
Posted 31 July 2020 - 09:52 AM
Thankyou evrrybody for your posts....
This is how i am now thinking!
The car is a tagged L32 SLR, originally manual, but had trimatic fitted at some stage. So rather than build the sad 253 (put it aside) i would build up 308 and back to manual.
I have rebuilt turbo pattern engine and was thinking of fitting that, however after these posts i am thinking might be easier to just rebuild trimatic pattern engine and leave it as auto....
So not having to worry about bellhousings, clutch pedals, clutch actuation etc
Keeping it simple! And apart from being auto not manual still fairly standard
#17 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 31 July 2020 - 10:02 AM
fitting a t5 would mean lifting the tunnel a couple of inches
#18 _JJ21_
_JJ21_
Posted 31 July 2020 - 10:11 AM
Hi mate, yeah and its not what i want to be doing.
I want to keep this simple and as unmodified as possible
