Speedmaster Truetrac, any good?
16 replies to this topic
#1 _74LH_
_74LH_
Posted 03 August 2020 - 07:19 PM
G'day all
Just wanted to see if anyone has had experience with the truetrac made by Speedmaster? Spoke to a diff shop today in melbourne who uses them and claimed they were a cheaper and potentially better choice over the Harrop (Eaton) supplied ones? Any truth to this?
Diff shop said they can supply the Harrop ones, at a higher cost obviously, but was insistent that the Speedmaster one was up to the task.
Just trying to stay away from junk if I'm going to be spending $$$$ on a diff and then get a dodgy LSD in it that needs to be swapped.
Any first hand experience appreciated!
#2 dron
dron
  • 132 posts
  • Name:Darren
  • Car:UC
Posted 03 August 2020 - 08:03 PM
Got one in a 31 spline 9" behind a 355 in the uc. only about 3000km but so far so good.
#3 Ice
  • 15,221 posts
Posted 03 August 2020 - 08:10 PM
Speedmaster is Procomp
Go the Harrop
#4 yel327
  • 13,790 posts
Posted 03 August 2020 - 08:30 PM
I have heard some stuff is OK, have heard the alloy heads are OK as long as you throw away the valves and springs. My problem with some of this is the adage you get what you pay for always rings true, and using cheap stuff is like playing Russian roulette. You can buy an Eaton Trutrac on EBay delivered for under $900, Speedmaster one is about $600. $300 is cheap Insurance when you are spending $2500+ on a diff.
#5 dattoman
Posted 03 August 2020 - 08:47 PM
G'day all
Whats the actual diff you're using ?
#6 _74LH_
_74LH_
Posted 03 August 2020 - 08:54 PM
So im deciding between a BW78 and a 9inch, am leaning towards BW at this stage (31 spline) and the shop that I spoke to today recommended BW for my application
#7 tsn007
tsn007
  • 1,022 posts
  • Name:Tony
  • Car:LX hatch, LX sedan
Posted 04 August 2020 - 08:01 PM
i actually worked there for a month, and can say that the Speedmaster Torque worm LSD's are quite good and pricing at trade level was quite reasonable and good profit could be made
the centres are assembled in house by a very reputable and experience diff builder
Also, there are some big very well known shops buying heaps of these centres and selling to the public
#8 _74LH_
_74LH_
Posted 04 August 2020 - 09:34 PM
Where did you work? Where are the LSDs made and assembled?
#9 tsn007
tsn007
  • 1,022 posts
  • Name:Tony
Posted 05 August 2020 - 06:43 AM
 Smeaton Grange NSW
https://www.atracingworld.com.au/
made in China
centres are assembled inhouse
#10 ozyozyozy
ozyozyozy
  • 953 posts
Posted 05 August 2020 - 10:06 PM
A number of the harrop truetracs are not off the shelf eatons, they have been tweeked and played with to make them better than the standard ones, thats the pro
The con, pain to deal with company. Know they had big issues with stock recently, dont know if it extended to bw diff parts.
What they tell you for time availability and what they supply are 2 very different things.
#11 ls2lxhatch
  • 5,335 posts
Posted 06 August 2020 - 07:43 PM
If you are considering a BW78 then have a look at the KAAZ.
#12 dattoman
Posted 06 August 2020 - 09:22 PM
Do they do a 31 spline ?
Thought only Harrop did
#13 ls2lxhatch
  • 5,335 posts
Posted 08 August 2020 - 06:43 PM
I am not aware of a 31 spline version of the KAAZ.
If I had to choose between a 31 spline Torsen/Truetrac and a 28 spline KAAZ I would take the KAAZ.
The KAAZ will lock and supply equal power to both wheels. The Torsen does not lock, the Torsen typically has a 2.5:1 torque bias (roughly 70/30). This means around 70% of the torque is delivered to the wheel with the most traction.
#14 skap
skap
  • 1,143 posts
  • Name:Skap
  • Car:Mighty VN
Posted 07 March 2022 - 06:33 PM
How did you go with this one 74LH?
I am needing a centre and gears for a BW M78, 28 spline.
does not appear to be any Eaton in stock,all back order.
my diff guy actually recommended the Speedmaster (which brought me to this thread)... but putting anything procomp in a car, all be it a dirty VN, just doesn't sit well with me...
the Kaaz sounds good, but very pricey around $1,600.
Must say, i would go the 9" if I could start again... I thought the BW was going to be a much cheaper alternative.
#15 dattoman
Posted 07 March 2022 - 08:40 PM
VN should be an M75
Regardless the centres fit
Try Motospecs
They also distribute the Eatons
#16 skap
skap
  • 1,143 posts
  • Name:Skap
  • Car:Mighty VN
Posted 07 March 2022 - 10:13 PM
Thanks Neil.
Ended up finding an Eaton this evening, so went with it. :)
#17 Statler
  • 6,332 posts
Posted 08 March 2022 - 12:46 PM
My diff guy warned me about the Chinese Trutraks.
Matter of fact he was changing yet another broken one out when i went to ask him about them.
I bought a Eaton on his recommendation.
