308 Block Pattern
9 replies to this topic
#1 hanra
  • 10,936 posts
Posted 07 August 2020 - 09:39 AM
What block pattern have I got here? To suit an Aussie 4 speed and Trimatic gearbox? This would be classed as Trimatic/Aussie pattern and not Turbo?
#2 Bigfella237
Posted 07 August 2020 - 09:44 AM
That's a QT prefix Trimatic pattern 308 block with a K92 date code!
#3 Bigfella237
Posted 07 August 2020 - 09:49 AM
Just for comparison, this is a Turbo Hydro (aka Chevy) bolt pattern 308 block...
The location of the two upper bolt holes is a dead giveaway, however the dowel pins are also about half a hole different.
#4 rexy
rexy
  • 3,715 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 07 August 2020 - 10:00 AM
That block is also one of the few that can’t be redrilled to turbo pattern as there isn’t enough metal around the dowel to shift it.
#5 hanra
  • 10,936 posts
Posted 07 August 2020 - 10:03 AM
Hahahahha, I managed to find my original post about this.... Doh!
#6 yel327
  • 13,598 posts
Posted 07 August 2020 - 10:10 AM
As Rexy says it is an early one, 1969-1974. The first half of red V8 blocks look that way except L34 and F5000 blocks and they cannot be re-machined to TH auto pattern, they are all manual/Holden/Powerglide/Trimatic. The engine prefix will be 308H, 308N, QT, 11QT, HT or NT.
#7 hanra
  • 10,936 posts
Posted 07 August 2020 - 10:58 AM
Cheers. Yeah a mate was thinking of slipping it into his HG prem which is currently a 253. So I guess its even period correct then.
#8 yel327
  • 13,598 posts
Posted 07 August 2020 - 11:11 AM
Not that it matters, if it’s not original to the Premier it doesn’t matter what it is unless it is a later engine forcing later emissions onto the car, like a VL block can.
#9 hanra
  • 10,936 posts
Posted 07 August 2020 - 11:12 AM
Yeah his 253 is original. He was going to put it aside somewhere safe.
#10 yel327
  • 13,598 posts
Posted 07 August 2020 - 11:37 AM
Good move. Use that one. Get the benefits of a bigger engine and no-one cares if it breaks!
