A9X Questions,,, Hella H4 headlights / Drivers seat
60 replies to this topic
#26 jaselx
jaselx
  • 46 posts
  • Name:J
  • Car:SS hatch
Posted 13 August 2020 - 08:56 PM
http://www.gmh-toran...uster/?p=318121
#27 jaselx
jaselx
  • 46 posts
  • Name:J
  • Car:SS hatch
Posted 13 August 2020 - 09:00 PM
See the above posts from 2008, I previously had a UC Torana and now have 76 LX Hatch. The Seats (both drivers and passengers) where firmer in the UC meaning you sat higher. Both seats where the same so I don't think wear to the drivers seat was the difference.
#28 yel327
  • 13,610 posts
Posted 13 August 2020 - 09:30 PM
Which of the option codes that make up A9X means the seats are different? As far as I am aware none of them have anything to do with seats? As far as I am aware:
A9X = A22, L31, JM8, UL5, D72, V5B G70 (later replaced by GU4), TT5 (D69 only), M21, QDA, and DL7 (D77 only). Plus UL5 and V5B.
The only options were: MC7, D50, V5G (D77 only), G70, V5J (D77 only).
The other "options" associated with the cars were mandatory and/or standard options: A8F, A8G, V5B, XS6, XT4.
The wheels must have been like HK where if you optioned a certain tyre you got a certain wheel with it.
If there is a difference it must be hidden in parts not as an option buildup.
#29 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 15 August 2020 - 10:53 AM
XS6 : Reclining Buckets
QDA : Tyre DR70H14 Steel Radial ( Goodyear : Grand Rally's )
#30 Bigfella237
Posted 15 August 2020 - 12:49 PM
Yes, but every Torana except those with a bench seat got the "XS6" RPO, there would had to have been something on the broadcast sheet to tell the guy on the line to grab a different seat for an A9X?
It's box #24 on the build sheet but I've only ever seen two A9X build sheets, one was hand written with "No" in that box and the other had "RCR" but I suspect that sheet is a fake so that may be unreliable.
EDIT: Looking at a couple of HX & HZ build sheets, they also have the "XS6" RPO and "RCR" in box #24
I'm not arguing with you, I believe there was a different foam cushion, I'm just saying that they wouldn't have trusted whoever happened to be on the production line that day to fit a different seat without being instructed to do so.
Edited by Bigfella237, 15 August 2020 - 12:53 PM.
#31 yel327
  • 13,610 posts
Posted 15 August 2020 - 02:41 PM
XS6 was part of every 77 body style regardless of it being a Torana or a Sunbird, as it was with 2 door Torana sedan and Holden coupes, that is why it was a mandatory option, just like A8F, A8G and XT4 (V5B shouldn't be listed in A9X mandatory options in post 28, that is my stuff-up).
As I said it if it is even fact it may well be a post-production modification hidden in parts detail. If it was spacers or something like that easy to do post production like when the flares etc were done.
#32 Kevrev
Kevrev
  • 420 posts
  • Name:Kevin
  • Car:73 LJ GTR, 77 LX SS 253 Manual
Posted 27 August 2020 - 08:18 PM
I just looked at my lx sales brochure printed Feb 76 and there is no mention of halogen lights as std or optional equipment. Photo of the SS headlight looks to be flat front halogen however.
Yes I always thought it was strange that Holden didn't seem to be promoting a feature like Halogen lights in their brochures. Nor do any of the car tests I've seen from when the LX Toranas were released make any mention of Halogens.
I did, however after a lot of digging around find this feature on the release of the Hatchback in the Feb 76 edition of the GMH People magazine.
Edited by Kevrev, 27 August 2020 - 08:19 PM.
#33 Ando
Ando
  • 527 posts
  • Car:6/'76 L32 SS white & black. 9/'76 L31 SS gold. 5/'77 L31 SS Chamois. 3/'79 UC SL Deluxe hatch.
Posted 28 August 2020 - 06:02 PM
I was of the thought that sometime in 1977, the H4 headlight option became 'standard fitment" for SS, SLR 5000 & A9X.
Edited by Ando, 28 August 2020 - 06:06 PM.
#34 Kevrev
Kevrev
  • 420 posts
  • Name:Kevin
Posted 28 August 2020 - 07:52 PM
SS always had Quartz Halogen lights fitted, as did A9X both sedan and hatch.
SLR/5000 did not have Halogen lights fitted as standard pre A9X, if they had the A9X sedans would not all have had the TT5 Quartz Halogen option listed.
#35 LCK186
LCK186
  • 373 posts
  • Car:71 CK
Posted 19 January 2022 - 08:45 PM
Hi old topic but im curious about the front seats in the a9x, compared to the slr/ slr5000/ ss hatch,  ive read what members have said, eg  foam u can use from the uc torana etc etc etc,my question is   is there a difference, I have a bet with a friend who says that there is no difference between the slr front seats and the a9x front seats, I personally think that there is a difference does any forum member know???   hopefully my way
#36 S pack
  • 15,708 posts
Posted 20 January 2022 - 06:58 AM
They all look the same to me, apart from the different trim colours.
#37 Shiney005
  • 9,547 posts
  • Car:Toyota Mirai
Posted 20 January 2022 - 10:56 AM
And once again, as Andrew mentioned above, it would have been a written instruction on the build sheets for each car. If it changed at all, it would have been a running change for all Toranas and Sunbirds at the same time. Maybe it happened with the second run of A9X's that also got the wider flares and Sunbird suspension arms?
#38 Bigfella237
Posted 20 January 2022 - 11:24 AM
Someone refresh my memory... When did driver's seat choice become free for race teams under CAMS?
The reason I ask is that the only reason GMH would go to the trouble of changing the seat cushion just for the A9X is for homologation, and if race teams were allowed to fit a proper racing seat by then there would've been no reason to do it.
Edited by Bigfella237, 20 January 2022 - 11:24 AM.
#39 S pack
  • 15,708 posts
Posted 20 January 2022 - 12:29 PM
1977 was the 1st year that a Group C car could have either one or both of the original front seats swapped out for a CAMS approved make and model of seat.
Edited by S pack, 20 January 2022 - 12:30 PM.
#40 S pack
  • 15,708 posts
Posted 20 January 2022 - 12:56 PM
I was thinking if the A9X front seat cushions were replaced it may have been in conjunction with revised suspension spring rates however it appears the A9X evolution of the 8VD69 and 8VD77 did not include suspension springs and/or any front seat revisions.
#41 S pack
  • 15,708 posts
Posted 20 January 2022 - 01:23 PM
If there was a change it would only have had to happen to all 8VD models. No special mention would have been required on the Production Broadcast Sheet as all 8VD front seats made from a particular point in time would use the same revised cushions.
#42 AbsynthHatch
AbsynthHatch
  • 736 posts
  • Name:Mark
Posted 20 January 2022 - 06:11 PM
I read somewhere a while ago that due to the height of the bonnet scope on the A9X a taller spacer was used on the front driver's seat. 10mm sticks in my mind for some reason.
Where this was installed I.e. at the factory or when the body kit were installed, I'm not sure.
Seat padding was a feature on the LX over the LH & not an A9X mod.
#43 LCK186
LCK186
  • 373 posts
  • Car:71 CK
Posted 20 January 2022 - 06:19 PM
Hi mark your almost correct,  if you go back to post 18 read what fly again states,     I believe that there was no difference in the seat padding  between  slr/ slr5000/ ss/ or the a9x
Edited by LCK186, 20 January 2022 - 06:22 PM.
#44 mandytory
mandytory
  • 101 posts
  • Name:peter
  • Car:lh sedan gpac, uc hatch
Posted 21 January 2022 - 10:35 PM
I remember reading years ago , maybe in that history of Torana magazine that the a9x seats sat higher to see over the bonnet scoop. Had forgotten all about it until reading this post.
#45 hanra
  • 10,953 posts
Posted 22 January 2022 - 07:49 AM
The hair on my head just touches the roof lining as it is…. Guess I won’t be buying an A9X anytime soon.
#46 Shiney005
  • 9,547 posts
  • Car:Toyota Mirai
Posted 22 January 2022 - 08:06 AM
Same here Brad. When wearing a helmet in the L34 it touches the roof lining.
#47 LXM21
LXM21
  • 450 posts
Posted 22 January 2022 - 11:42 AM
Re the drivers seat, extract from Motor Manual article on the A9X December 1977
#48 LXM21
LXM21
  • 450 posts
Posted 22 January 2022 - 11:44 AM
Attempted to post the article, didnt load up
#49 LXM21
LXM21
  • 450 posts
Posted 22 January 2022 - 01:42 PM
Extract shown
#50 Bigfella237
Posted 22 January 2022 - 01:56 PM
So next question... Was it simply spacers (and, I assume, longer bolts) fitted at the same time as the fibreglass bits or was it a different lower seat cushion?
