chrome plating - Gold Coast/Brisbane area
17 replies to this topic
#1 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 28 August 2020 - 06:07 PM
The front and rear bars on my LJ need re-chroming as they appear to be the originals as they were covered in green speckles when I got the car. Anyone had any experience with Queensland Chrome Plating. Got quoted $600 per bar (with no repairs needed). Cost doesn't worry me just can't afford to have them stuff up my original bars as they are hard to find these days? Not keen to have to send them interstate as that sounds like a recipe for a bent/dented bar upon return.
Not sure what happened there? Just wanted to know if anyone has any experience with Queensland Chrome Plating (Brisbane) as they quoted me $600 per bar (without repairs).
#2 S pack
  • 15,717 posts
Posted 28 August 2020 - 06:19 PM
Edited by S pack, 28 August 2020 - 06:19 PM.
#3 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 28 August 2020 - 06:23 PM
Hi Mark, $600 is about the cost here in WA too. Very expensive to rechrome bars compared to buying new ones.
Original bars are easy to find and cheap due to most people buying repro's.
Marty
#4 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 28 August 2020 - 06:57 PM
Thanks Marty. Yeh it did sound on the expensive side to me but then I've had no experience with chroming stuff since the early 80's
#5 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 28 August 2020 - 07:34 PM
Rocker cover's are over $300 to do & bars are $1,000 each in melbourne now, if it's a good quality job for $600 each, you're probably doing pretty well i reckon. You can spend a crazy amount of time prepping surfaces for plating & painting.
#6 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 29 August 2020 - 08:06 AM
Hi, if you want a comparison quote also try pacific plating too.
http://pacificplating.net/about/
I have had stuff done there, with good results for both my cars,
also my mate was extremely happy too with the results from pacific plating (as he was not happy with quality from wizard chrome)
#7 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 29 August 2020 - 08:44 AM
Ok thanks for the advice. Pacific plating might be the go.
#8 S pack
  • 15,717 posts
Posted 29 August 2020 - 09:05 AM
Pacific Plating are at 1283 Kingsford Smith Dr, Pinkenba QLD 4008
#9 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 29 August 2020 - 11:03 AM
My LJ left mirror arm was an absolut pig, but John at Pacific Plating got the job done.
#10 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 29 August 2020 - 11:23 AM
Correction above, Tony at Pacific Plating, Johns his surname....🙂
#11 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 29 August 2020 - 04:05 PM
I wouldn't send someone i hated to wizard chrome, they're f@cking useless.
#12 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 29 August 2020 - 04:29 PM
Gary, you are totally correct there.
My mate used em - close to him, as they were northside brisbane, but soon found out not a good result.. ☹
#13 Ice
  • 15,200 posts
Posted 29 August 2020 - 04:31 PM
That mirror stem is impressive not many places know how to do them right
#14 _macdou_
_macdou_
Posted 31 August 2020 - 06:53 PM
How much did they slug you for that mirror ? 😬
#15 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 31 August 2020 - 08:45 PM
I think from memory to Rechrome that left Arm was quoted at about $85... and it took about 3 goes for the acid copper to take to the shitty looking die cast surface....so for the amount of time spent by Pacific Plating, it was worth every bit.
#16 S pack
  • 15,717 posts
Posted 31 August 2020 - 09:00 PM
Apparently the problem with plating pot metal is impurities in the metal cause the new plating to blister.
Herston plating had 3 goes at the old mans FC hood ornament before it came out OK.
#17 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 31 August 2020 - 09:04 PM
And Ken, just lookin back through my file photos. That left arm i got Rechromed 3 years ago. And i still havnt fitted it to the door yet....
I was chasing a mirror pad for it, of which i have now, as i bought some repro's off Marty (the sally report)
Cheers...
Jaso
#18 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 31 August 2020 - 09:13 PM
Thanks Dave...
Yep - Pacific Plating got that left arm as best they could...eventually i will adorne the door with the said ornament...LOL
