LJ POWER STEER
17 replies to this topic
#1 _DrBill_
_DrBill_
Posted 17 September 2020 - 11:24 PM
I have recently completed an electric power steer column for my LJ rally car. It will bolt into any LJ without any modification to the car. It is speed sensitive with maximum torque  at low speed and zero torque at high speed. Plugs into back of fuse box, plus 1 x earth and 1 x battery connection.
This represents a significant change in the way the car drives and allows the use of short, neutral Ackerman steering arms, that reduce lock to lock down to 2.25 turns.
This car also runs HSR Mikuni Flatslide carbs and I am looking for an LJ XU1 manifold to replace the the Redline manifold that I am using.
I would be happy to build another column for a member and swap it for a manifold.
#2 _Romper_
_Romper_
Posted 01 October 2020 - 09:40 AM
Hi mate what steering rack are you using with the Electric power steering ?
#3 _DrBill_
_DrBill_
Posted 07 October 2020 - 05:58 PM
LJ rack, LJ Column, LX style short steering arms.
#4 _Romper_
_Romper_
Posted 11 October 2020 - 07:46 PM
Got any pics of the electric steering unit connected to the column ?
#5 _DrBill_
_DrBill_
Posted 12 October 2020 - 10:41 PM
yes but I am struggling to upload them
#6 _DrBill_
_DrBill_
Posted 04 November 2020 - 11:58 AM
Attached File  IMG_0217.jpg   153.98K   33 downloadsAttached File  IMG_0218.jpg   267.56K   30 downloadsAttached File  IMG_0219.jpg   294.41K   23 downloads
#7 _Romper_
_Romper_
Posted 25 November 2020 - 11:17 PM
looks great, what rack mods have you done to make it a power steering rack ?
#8 _DrBill_
_DrBill_
Posted 26 November 2020 - 09:58 PM
No rack mod required, the column does all the work. At low speed (parking) you only need 1 finger to turn the wheel. I have machined up some short straight steering arms to reduce the number of turns from lock to lock.
I will download some more pics if it helps.
#9 Torrieman
Torrieman
  • 5 posts
  • Name:rob whitbread
  • Car:LC Torana
Posted 14 March 2022 - 04:36 PM
What electric power steering unit did you use. I’ve got an lc with a 5 litre and 7” rims which makes it very hard to steer
#10 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 31 March 2022 - 01:07 PM
does any have contact details
or anybody else that does this
thanks albert
#11 nanbar
nanbar
  • 140 posts
  • Name:Nando Barbanera
  • Car:LC 2 door V8
Posted 20 August 2023 - 10:50 PM
My LC with a 4.2 is also hard to steer, wouldn't mind this set up for mine.
#12 S pack
  • 15,725 posts
Posted 21 August 2023 - 07:05 AM
Have a chat with these blokes. I reckon they will be the mob that DrBill fella bought his electric power steering unit from.
https://www.ultimate...eering-columns/
#13 nanbar
nanbar
  • 140 posts
  • Car:LC 2 door V8
Posted 21 August 2023 - 07:08 PM
Thanks heaps for that
#14 salxu1
salxu1
  • 129 posts
Posted 22 August 2023 - 07:53 PM
The power steering unit is an early Suzuki Ignis
#15 nanbar
nanbar
  • 140 posts
  • Car:LC 2 door V8
Posted 18 December 2023 - 06:31 PM
If you dont mind me asking DrBill, what did that power steering set up cost you?
#16 nanbar
nanbar
  • 140 posts
  • Car:LC 2 door V8
Posted 18 December 2023 - 06:40 PM
The video on their website of the electric power steering being fitted to a Nissan Skyline with an LS motor in it shows it needing steering column mods. DrBill says no mods were required to his LJ, might be a different unit.
#17 S pack
  • 15,725 posts
Posted 18 December 2023 - 06:53 PM
Nando, if you read what Dr Bill said, he said no mods to the car and no mods to the steering rack. The electric PS unit is intergrated into the steering column so the steering column is the component that needs all the mods.
#18 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 19 December 2023 - 09:06 AM
thats right Dave
when doing it you also need the section of shaft either  side of the motor
to weld to the original shaft
recently did one on a 53 chev
