Hi all, has anybody fitted the Mackay A1202 bush with the thicker wall inner tube listed by Mackay as heavy duty to the rear trailing arms ( instead of 1121 ) and also to the front and rear lower control arm bushes ( usually only fitted to front bush of the lower control arm on the UC and L34) thinking about fitting to LH SLR Torana with UC control arms on the front end and LH trailing arms on rear to to have a bit stiffer bushes without going to nolathane, cheers.
No replies to this topic
Also tagged with one or more of these keywords: suspension, bushes
Holden Tech →
Suspension & Steering →
Suspension BushesStarted by dacastle , 12 Jun 2022 ![]() |
Holden Tech →
Rear Spring Upper RetainersStarted by dacastle , 13 Apr 2022 ![]() |
Members Area →
Non Torana Projects & Plans →
Suspension Guru's Help with Anti Squat for Street RodStarted by mick_in_oz , 19 Feb 2020 ![]() |
Holden Tech →
sway bar for rear lh lx with nine inchStarted by _torriemick_ , 16 Jan 2019 ![]() |
Holden Tech →
Rubber or Other Front end BushesStarted by _1ARC_ , 07 May 2018 ![]() |
