* * * * * 1 votes
Hawks Torana dream lives on
402 replies to this topic
#326 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 18 October 2022 - 08:35 AM
Yeah you can use resistance to check the gauges.
But not really necessary.
Why make something simple harder?
You can do a couple of things with the fusible link.
But first you need to find the size of the wire it feeds.
If I get time today I will go and measure some stuff.
If you want to keep the link in its existing location, then going a size or 2 down in wire size will do the trick.
Perhaps even 3 sizes down.
But you would probably be better off running a wire direct to the battery rather than the starter, then you can get a plug in fusible link.
The advantage is that it is easier to replace than the wire. Sometimes the wire will fail without showing any external indication.
Rob
#327 hawk
hawk
  • 2,183 posts
  • Name:steve
  • Car:UC Torana
Posted 19 October 2022 - 04:29 PM
Thanks, ended up purchasing an inline midi 60 amp fusible link.
Got my new temp sensor for the motor Tridon TTS033 and the gauge still won't move even when the motor is hot.
Dead gauge or wrong sensor?
#328 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 20 October 2022 - 08:44 AM
Make sure the sensor is for a gauge and not an idiot light.
There have been issues with people using thread tape to put the sensor in as well.
The outside of the sensor needs a good earth if its a single pin type
Rob
Edited by Rockoz, 20 October 2022 - 08:46 AM.
#329 hawk
hawk
  • 2,183 posts
  • Name:steve
  • Car:UC Torana
Posted 20 October 2022 - 03:17 PM
Looks like they supplied the wrong one... Again.
In other news, my Dad just purchased his new project. Heath should recognise this car. It's pretty Bad rust wise but does come with a lot of the sections to fix it.
Attached File  Screenshot_20221020-161315_Messenger.jpg   103.34K   8 downloads
#330 Heath
  • 18,385 posts
Posted 20 October 2022 - 04:51 PM
Yep, David's car.
Didn't realise it was for sale. It was a tidy (although certainly not perfect), quite original car back in my P plate days. A fairly long time has passed since, though, and it doesn't look like it has had such a pampered life since...
Still, that is great news.
#331 hawk
hawk
  • 2,183 posts
  • Name:steve
  • Car:UC Torana
Posted 20 October 2022 - 09:20 PM
It's been sitting outside the majority of the last 10 years. Still a very original car although a little worse for wear.
Rear end is pretty rusty, front is really clean. guards, nosecone, radiator support and drivers floor are rust free.
front windows frames, passengers floor, plenum, rear windows, parcel shelf, inners below the parcel shelf, both quarters, both tail light buckets and boot floor all need repairs.
Worst of it is drivers side rear window area. Inner skins also rusty and passengers side tail light bucket is help in with hopes and dreams.
#332 hawk
hawk
  • 2,183 posts
  • Name:steve
  • Car:UC Torana
Posted 21 October 2022 - 07:44 PM
A few photos of what Dad is going to have to deal with. will probably need a bit of advice around the parcel shelf repairs and roof at the door jams.
Actually suprised how solid the floors are considering.
Attached File  20221021_191220.jpg   510.25K   7 downloads
Attached File  20221021_122810.jpg   114.92K   3 downloads
Attached File  20221021_191308.jpg   621.62K   3 downloads
Attached File  20221021_191407.jpg   129.61K   3 downloads
Attached File  20221021_191423.jpg   120.59K   5 downloads
Attached File  20221021_191508.jpg   423.66K   4 downloads
And a few more.
Attached File  20221021_191523.jpg   103.22K   4 downloads
Attached File  Screenshot_20221016-203907_Samsung Internet.jpg   53.67K   5 downloads
Attached File  Screenshot_20221016-204031_Samsung Internet.jpg   55.83K   7 downloads
#333 hawk
hawk
  • 2,183 posts
  • Name:steve
  • Car:UC Torana
Posted 09 December 2022 - 09:34 PM
Haven't done much to the UC lately other than drive it. I ended up buying a sports cluster to try and solve my Dash issues.
The oil pressure gauge is buggered and the fuel gauge still doesn't work. Looks like I need to pull the tank and check over the sender at some point.
Attached File  20221019_171135.jpg   166.1K   4 downloads
I also spent a couple of days rewiring the engine loom. its not perfect although is definitely a lot nicer than it was before.
Recieved these wheels as a gift. 17x7 and 17x8 genuine 3 piece simmons with Bridgestone potenza 225 on the rear and continental 215 up front.
Pretty good fit although not sold on the look yet. Might need to go a bit lower to sit where I want it.
Attached File  20221209_144239.jpg   140.2K   5 downloads
Attached File  20221209_144248.jpg   148.88K   4 downloads
I've pulled the stainless trims off the boot lid and from around the tail lights. Hopefully tomorrow I can get the rivet holes welded up. I'm not sure about the badges yet as I'm considering a rear spoiler.
Also been thinking a lot about the driveline and what to do with it. Thoughts are to either work the 202,drop in a holden V8 or go RB30. Not really interested in an LS as I'm not a fan of them.
I have a 5 speed toyota box lined up to go behind the 202 eventually, could it be used behind a V8 too with the correct belhousing?
Still planning the skyline diff, at this stage I'll probably use the one out of Dads as he is going back to a banjo for rego purposes. it's already torana pattern and LSD centre. As his car is an LH will I get away with just doing the top mounts or am I better off using the spare housing I have and leaving the other one to suit the LH?
#334 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 10 December 2022 - 08:09 AM
Looking at the pic of the oil gauge, I reckon you have an idiot light sender instead of a gauge sender.
Pull the wire off the sender and see what happens.
Rob
#335 Statler
  • 6,314 posts
Posted 10 December 2022 - 12:56 PM
Personally i would leave them on.
It's one of those things that were only on the 'Torana' & not the Sunbird.
#336 rexy
rexy
  • 3,739 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 10 December 2022 - 05:05 PM
Wheels look good!
I think the rebadged smooth look suits the UC.
#337 hawk
hawk
  • 2,183 posts
  • Name:steve
  • Car:UC Torana
Posted 10 December 2022 - 05:26 PM
Well its a bit late now haha.When the car was repaired back in the day, they replaced the welded studs with rivets and I believe some of my water in the boot issues are coming from there.
Swapped on the spare boot lid.
Attached File  20221210_140310.jpg   292.31K   5 downloads
And fitted the Venetians he didn't want.
Attached File  20221210_150652.jpg   270.28K   7 downloads
Rivets in the body that need addressing
Attached File  20221210_143448.jpg   167.73K   5 downloads
Rivets removed from the boot lid.
Attached File  20221210_143505.jpg   251.88K   5 downloads
Welded up and bare metalled on top
Attached File  20221210_171641.jpg   269.94K   5 downloads
Attached File  20221210_172028.jpg   200.21K   5 downloads
There was a lot of surface rust under the paint and bog that will need treating and a few dents to fill.
On another note, I thing the LH style torana badge on the boot lid looks really good on the car.
Rockoz, It has the correct sender for the oil gauge, pretty sure that image was with it disconnected from the sensor.
#338 rexy
rexy
  • 3,739 posts
  • Name:Rexy
Posted 13 December 2022 - 10:25 AM
“DE badged”
#339 hawk
hawk
  • 2,183 posts
  • Name:steve
  • Car:UC Torana
Posted 26 December 2022 - 07:13 PM
Got the Rear spoiler holes drilled. As I haven't mounted one thike this before I was pretty worried about getting in all lined up properly. Got there in the end and it lines up well enough. Still need to drill the access holes for the studs though.
Attached File  20221220_174949.jpg   222.87K   3 downloads
Attached File  20221221_161113.jpg   231.89K   3 downloads
rust converted, I'm not sure if this look right or not but after applying this converted is looked like surface rust on the bare metal.
Attached File  20221226_122934.jpg   138.14K   4 downloads
Etch primed top and bottom.
Attached File  20221226_154610.jpg   37.33K   3 downloads
#340 hawk
hawk
  • 2,183 posts
  • Name:steve
  • Car:UC Torana
Posted 08 February 2023 - 07:25 PM
Slowly working away on the boot lid.
It was a pain to fit up but got there in the end. Being a rares spoiler, it was a pretty average fit and still has ripples along the back edge that I'll just have to deal with.
Test fitment
Attached File  20230128_140504.jpg   342.76K   3 downloads
Attached File  20230208_150746.jpg   750.75K   3 downloads
Underside in colour
#341 hawk
hawk
  • 2,183 posts
  • Name:steve
  • Car:UC Torana
Posted 08 February 2023 - 07:32 PM
The top side straight off the gun
Attached File  20230208_175147.jpg   688.09K   6 downloads
Attached File  20230208_184420.jpg   387.29K   6 downloads
Is it worth clear coating the underside of the bootlid?
What sealant should I use around the spoiler holes?
Is it worth adding a rubber strip under the front edge to protect the boot lid paint?
As for the spoiler, I'm not sure which way to go. At this stageit will go all yellow althoughI may add blackouts or something else at a later stage.
This is how I did my last UC and I'm unsure of the body colour strip along the bottom edge.
Attached File  20130106_143145.jpg   76.49K   6 downloads
On another note, I've finally dropped my diff off to get started on. At this stage it's just the mount change on a R31 skyline borg warner. I'll get it done bit by bit to spread the cost.
Mounts are costing $700 to get done.
Can the axles be re drilled to torana pattern? I'd rather not have to get axles made too.
#342 hawk
hawk
  • 2,183 posts
  • Name:steve
  • Car:UC Torana
Posted 12 February 2023 - 01:17 PM
Well, it's on. The spoiler still needs a couple more coats of paint and clear, but I'll do that later on.
Fitted rubber less rear bar and pulled the rubber off the front bar.
Attached File  20230209_171222.jpg   941.32K   3 downloads
Attached File  20230212_125415.jpg   1000.35K   3 downloads
and more
Attached File  20230212_125457.jpg   73.54K   3 downloads
Attached File  20230212_125441.jpg   936.96K   3 downloads
#343 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 12 February 2023 - 02:59 PM
Coming together nicely man!
#344 hawk
hawk
  • 2,183 posts
  • Name:steve
  • Car:UC Torana
Posted 16 February 2023 - 07:58 PM
Thanks to Brett (LXCHEV) I have a head unit. Picked it up off him last night and wired it in after work today. Fitted to the glovebox so the dash wouldn't need to be cut up.
Ran the constant to the back of fuse box off the horn fuse. The ignition switched power is coming from the original radio power wire.
Still yet to find somewhere that sells thick enough speaker spacers for the parcel shelf, might need to make some.
Attached File  20230216_201922.jpg   245.63K   3 downloads
#345 LXCHEV
LXCHEV
  • 3,608 posts
  • Car:'76 LX - 383 Chev
Posted 19 February 2023 - 08:00 PM
Glad to see it's already up and running mate.
For the rear speaker spacers - grab some MDF and your jigsaw, and have a bit of fun making your own!
#346 hawk
hawk
  • 2,183 posts
  • Name:steve
  • Car:UC Torana
Posted 15 March 2023 - 09:01 PM
So I have found a couple of 308's for sale. Loretta standard and well used for 3k each. One is a 77 block and the other is a 80 block.
Is 3k reasonable for a complete runner at the moment? Which one would better suit the UC? is there much of a difference between the two?
#347 yel327
  • 13,633 posts
Posted 16 March 2023 - 05:31 AM
Either should be OK as both 1977 and 1980 are ADR27A which is what the UC is. If they are totally original the 1977 one will be 9.7:1 static and the 1980 will be 9.4:1 if a red or 9.2:1 if a blue, slightly bigger dish in the pistons. A 1980 308 regardless of red or blue will have the longer valley head bolt bosses.
People ask $1000 for a standard bore 308 block, so a useable runner with all accessories is worth $3k. Have you looked at a VN-VS 5 litre? A running one of these would be similar $ but will cost more to fit as you have to swap sumps, find engine mounts etc. Plus the fuel system parts costs.
#348 hawk
hawk
  • 2,183 posts
  • Name:steve
  • Car:UC Torana
Posted 16 March 2023 - 08:03 AM
The 1980 is a blue motor, I believe. should I go the 77 because of the higher compression?
I was looking at 304's but would rather use the earlier block and keep it carbed.
#349 yel327
  • 13,633 posts
Posted 16 March 2023 - 09:44 AM
There is no real power difference between a pollution red or a 1980 blue motor. Slightly less compression along the way but those are 40+ year old parts, and any advantage either way goes as soon as the heads are off and you freshen it up. The main advantage of the blue engine is the intake, carb (with external metering rod adjustment) and HEI dizzy. But again all easily changed, and many have rotted out intakes anyway which you just replace with a KC or Performer.
If both are claimed runners see if you can borrow a pin head camera and jam down the plug holes and look at the bores. Do a compression test if you can. In the end though the first point of failure on any of these from HT through to VS was normally the camshaft and oil pump. I’ve used plenty of old 308 or 304 before, and left the pistons and bores alone, just changed bearings, oil pump, timing chain set, cam/lifters and reseated the valves. Or a combination of the above. We even once got this crappy looking 308 short for $100 that was already 60 thou and stripped to a short as the cam was buggered. We re-used the whole rotating assembly as it was other than rod bearings. Fitted an EFI cam with new lifters and a whole VP top end to it and stuck it in a WB. That thing hammered, felt like a stock 350.
#350 yel327
  • 13,633 posts
Posted 03 April 2023 - 07:42 PM
Shame this isn’t near you. Probably a cracked head.
http://www.gumtree.c...&utm_source=sms
