Hawks Torana dream lives on
#126
Posted 04 February 2021 - 06:16 PM
#127
Posted 04 February 2021 - 06:29 PM
#128
Posted 05 February 2021 - 07:43 PM
Thanks again for the advice everyone. the .6 wire worked a treat on the sheet metal and it was almost impossible to blow through after it was set in the right spot.
Test fitted a 245/60/14 I had laying around for the a few years. fits under the guard really well. Will need to roll the lip though.
#129
Posted 06 February 2021 - 04:58 AM
#130
Posted 06 February 2021 - 01:45 PM
Moving faster will help flatten the weld.
Its a bugger to do sometimes.
Just keep welding and grinding until there are no holes.
Use a disc not a flapper to cut the welds down, and be careful to not cut down the steel around the weld.
No point having a 1.2mm weld on 0.4 of surrounding tin.
Rob
#131
Posted 06 February 2021 - 06:41 PM
#132
Posted 06 February 2021 - 07:17 PM
Then I welded up the other crack. Yes I drilled the ends of it before welding. It was a prick of a spot the welder doesnt like being used upside down. figured the welds came up good enough after a bit of work. The fact the rail was bent inwards there made it a lot harder.
I then fitted the K frame for the last time. It was a lot harder to line up this time. Think I did it a bit different to last time and the was the issue.
Still undecided if I will straighten the drivers side rail where the gearbox mounts or not.
Next up I'll tackle the seat mount crack. might test fit the motor and box roughly to see if the extractors will fit with the sway bar.
Edited by hawk, 06 February 2021 - 07:19 PM.
#133
Posted 07 February 2021 - 03:03 PM
#134
Posted 08 February 2021 - 09:09 AM
Great stuff Steve.
#135
Posted 09 February 2021 - 06:50 PM
whoever has worked on it previously had drilled a hole between the lock nut and rack end. Then they proceeded to smash a dowel pin in there damaging the threads on both ends. Had to put it in a bench vice and reef on it to undo it which did more damage.
#136
Posted 10 February 2021 - 05:42 AM
That pin is normal, you drill them out to disassemble.
#137
Posted 10 February 2021 - 08:20 AM
Yep as Warren said-I've seen worse don't stress.
Edited by 308 Sunbird, 10 February 2021 - 08:20 AM.
#138
Posted 10 February 2021 - 08:22 AM
I will at least need new lock nuts and to tap the run a die over it.
What size die do I need?
#139
Posted 10 February 2021 - 09:12 AM
Can you just use an appropriately sized needle file to clean up the damage in that thread?
A die to suit will be probably be an expensive exercise.
#140
Posted 10 February 2021 - 11:05 AM
#142
Posted 10 February 2021 - 07:42 PM
Started the seat mount repair tonight. removed the bracket, welded up the cracks. Primed with weld through primer and then ran out of mig gas.
I think I thinned out the steel in that area a bit too much in areas. Tried not too.
#143
Posted 14 February 2021 - 05:11 PM
Its still far from perfect, its something I will redo at a later date. Dad did the welding on this one and the penetrative all round was a lot better.
It looks a bit rough but I decided to leave a fair bit of weld in some areas I didn't want to thin out too much.
Part of the issue was I changed from a mixed gas to straight argon as its all they had available on the day. I'll deffinitly be going back to the mixed bottle this time as I'm out of gas again.
#144
Posted 14 February 2021 - 07:36 PM
early Holden nut
#145
Posted 15 February 2021 - 05:24 AM
What size gas cylinder are you using? You seem to be using a lot of gas.
#146
Posted 15 February 2021 - 10:13 AM
I have found with weld through primer that you need to start the weld on an untreated section.
Normally I would fill a hole by starting in the centre and going wider as I progress.
I have found with the weld through that starting on the edge, weld straight to centre, then working out from there is required.
Or, weld straight across and do one half of the hole, then move to the other half.
Rob
#147
Posted 15 February 2021 - 10:58 AM
early Holden nut
#148
Posted 15 February 2021 - 12:41 PM
#149
Posted 15 February 2021 - 01:26 PM
early Holden nut
Edited by claysummers, 15 February 2021 - 01:26 PM.
#150
Posted 15 February 2021 - 06:11 PM
