Engine Bay Guard Seams
19 replies to this topic
#1 _LH4ME_
_LH4ME_
Posted 03 November 2020 - 10:04 PM
Hi all.
Doing a bit of work to the engine bay and like the look i have seen on some cars where they appear to join the inner guard to the chassis rail. Can anyone tell me if there are any issues with flexibility or paint cracking if they are joined?
Also, are they welding them together or using a sandable/paintable seam sealer?
Appreciate any input.
#2 Shiney005
  • 9,536 posts
  • Car:Toyota Mirai
Posted 04 November 2020 - 12:03 PM
Got any pictures of what you have seen?
#3 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 04 November 2020 - 12:29 PM
I see little to no benefit stich welding the seams. Plenty of chance of warping something. I will be seam sealing and painting over mine no welding.
#4 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 04 November 2020 - 07:54 PM
Here's mine, smoothed and welded, done a lot of years ago now. It's showing signs of movement near the welded corner with minor cracks in the paint.
The car has been drag raced for many years with roughly 480HP, left front in the air with near standard suspension, so its working hard to do this.
#5 _LH4ME_
_LH4ME_
Posted 04 November 2020 - 09:25 PM
Thanks for the relies fellas. Yep that is exactly what im talking about thanks mick in Oz. Looks very tidy with that seam covered. So would you say that a flexible seam sealer would be a better option than welding?
#6 _LH4ME_
_LH4ME_
Posted 04 November 2020 - 09:28 PM
Toranamat69, will you be using something similar to the Sika seam sealer? Would you do this after epoxy primer when you are using a bit of body filler on other areas of the engine bay?
#7 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 04 November 2020 - 10:54 PM
Hi LH, yeah I reckon something like seam sealer. There is a worths product too.
I'm doing the metal work then getting my car done from there at a shop. I'll most likely pay them to do it.
I recon the ultimate would be 2 pac primer everywhere then seam seal then sand and prime those bits again so they are perfect.
#8 Shiney005
  • 9,536 posts
  • Car:Toyota Mirai
Posted 05 November 2020 - 02:53 PM
Here's mine,
What is under your brake booster there Mick? Line locker?
#9 Cook
Cook
  • 1,526 posts
Posted 05 November 2020 - 08:38 PM
Hi LH4ME. Don't take it from me as knowledgeable but I had mine seem welded, mainly to ensure no independant movement between the inner guard and chassis, then die grinded then skimmed with filler and primed/painted as per the rest of the engine bay. From my limited use of seem sealer I would be interested to see how you get it smooth enough to paint over. Also how well will paint adhere to it long term.  Cheers Ron
#10 Bigfella237
Posted 05 November 2020 - 10:02 PM
Electric vacuum pump, Laurie.
I prefer the seams myself...
#11 Shiney005
  • 9,536 posts
  • Car:Toyota Mirai
Posted 06 November 2020 - 07:49 AM
You have shedloads of threads devoted to your hatch Cook, but not a thread on the whole build where we can see some overall progress. Looking at that engine bay picture above, I for one would love to see some photos of the whole car.  :spoton:
#12 Cook
Cook
  • 1,526 posts
Posted 06 November 2020 - 11:20 AM
Thanks Laurie.  I haven't done a build thread as the bulk of the work is/has been done by those more experienced and knowledgeable than I.  To be honest I don't have a decent photo of the whole car as I only concentrate on one aspect at a time (not great at multi-tasking lol). I am contemplating doing a run through once the car is complete and pass on my experiences.  FWIW I can tell you the colour is Azzuro Thetis.  I'll send through a recent pic of the engine bay when I can get it uploaded from my phone.  Cheers Ron
#13 Cook
Cook
  • 1,526 posts
Posted 06 November 2020 - 11:40 AM
Here we go. Cheers Ron
#14 Shiney005
  • 9,536 posts
  • Car:Toyota Mirai
Posted 06 November 2020 - 01:21 PM
Very nice!!!
#15 _LH4ME_
_LH4ME_
Posted 07 November 2020 - 09:23 PM
Thanks for the replys fellas. Both very nice engine bays. I hope mine will look half as good as those.
#16 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 09 November 2020 - 09:22 PM
Yup Vacuum Pump, Hella UP28 series.
I think even with seam sealer it'll crack the paint if its got a good amount of HP or you have a big right boot.
I like the clean welded seam, but I feel left open is likely best if its driven in anger often.
#17 _LH4ME_
_LH4ME_
Posted 15 November 2020 - 09:27 PM
Just an update on this.
I ended up applying the Sika 227 with caulking gun and then brushed down with thinners to smooth it out because the old finger dipped in thinners method didnt work too well.
It sanded pretty well with a wet 360 grit but some imperfections have shown up after high build was laid down.
Ill tidy them up and then i reckon it will come up okay with colour.
It is pretty fiddly and messy because that sealant is so damned sticky.
#18 _LH4ME_
_LH4ME_
Posted 15 November 2020 - 09:33 PM
Some photos of the imperfections. They werent too obvious before the high build
#19 _LH4ME_
_LH4ME_
Posted 22 November 2020 - 03:38 PM
Just want to do another update for those of you thinking of doing this mod.
Sanded the imperfections and hit it again with hi build. Its come up good this time.
In conclusion, the Sika 227 seam sealer has worked well. It is a bit messy so you will need thinners when applying to smooth and clean up on the run.
It sands okay - not quickly, but dont leave too much excess if possible.
It sets quickly without sagging and You can paint over it without a problem.
#20 jeffblanco
jeffblanco
  • 379 posts
  • Name:Mando
Posted 24 November 2020 - 09:18 PM
Hi Guy's,
this is what my engine bay looks like.
Not smoothed over completely but tidied up.
Painter should start in about a weeks time.
Attached File  DSCN0560.jpg   100.62K   5 downloads
Attached File  DSCN0563.jpg   111.29K   4 downloads
Attached File  DSCN0562.jpg   69.25K   2 downloads
Attached File  DSCN0561.jpg   136.89K   3 downloads
Regards Mando.
