L34 versus AX9 - visual differences
15 replies to this topic
#1 _Four_Cylinder_Fan_
_Four_Cylinder_Fan_
Posted 05 December 2020 - 10:46 AM
Hi I'm new to the wonderfull world of Toranas so this topic may have been covered before.
What are the obvious VISUAL differences between the L34 and the A9X four door?
Until recently I didn't know about the A9X four door, I only knew about the A9X hatchback.
It seems the last part of any Torana model that gets touched by modifiers is the external body, grille and lights.
Even if the mechanicals have been changed the external appearance is still the best way to identify what model a Torana is!
Regards from Melbourne.
#2 _Lazarus_
_Lazarus_
Posted 05 December 2020 - 11:07 AM
They were options so basically one looked like an LH SL/R 5000 with flares and one looked like an LX SL/R 5000 with flares.
#3 yel327
  • 13,633 posts
Posted 05 December 2020 - 11:29 AM
Bonnet scoop.
#4 mandytory
mandytory
  • 101 posts
  • Name:peter
  • Car:lh sedan gpac, uc hatch
Posted 05 December 2020 - 11:52 AM
Also with flares fitted they deleted the side panel and sill blackout paint . On A9x no side slr5000 painted in black stencil cut out.
#5 arrimar
arrimar
  • 3,134 posts
Posted 05 December 2020 - 04:03 PM
A9X is the one you can see behind in your rear view mirror.
L34 is the one you just see the back of way ahead in the distance.
#6 yel327
  • 13,633 posts
Posted 05 December 2020 - 05:08 PM
Clever.
#7 hanra
  • 10,968 posts
Posted 05 December 2020 - 08:26 PM
Both had round headlights.
#8 unclefestal34s
unclefestal34s
  • 1,123 posts
Posted 05 December 2020 - 08:57 PM
L34 put the A9X on the map with its factory engine modifications,..A9X came with a full pollution stock engine same as the HZ Statesman,..in race trim the A9X used the L34 Engine...
#9 S pack
  • 15,721 posts
Posted 05 December 2020 - 09:34 PM
So did the 1900cc LH Torana.
#10 u1 71
u1 71
  • 477 posts
  • Name:peter
  • Car:torana
Posted 05 December 2020 - 09:40 PM
The Torana Lh L34 was the last of the factory built muscle car
#11 S pack
  • 15,721 posts
Posted 05 December 2020 - 10:30 PM
L34 was a variant of the 5 litre 8VD69.
A9X was an evolution. The first evolution of the 8VD69 A9X used the L34 flairs on all corners. The second evolution of the 8VD69 A9X continued to use the L34 flairs on the front wheels but used wider A9X specific flairs on the rear wheels.
Edited by S pack, 05 December 2020 - 10:31 PM.
#12 yel327
  • 13,633 posts
Posted 06 December 2020 - 06:02 AM
The VK Group A is no less worthy of words like that than the LH is.
#13 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 06 December 2020 - 06:37 AM
VN Group A for me.
#14 VIXL34s
VIXL34s
  • 177 posts
  • Name:jeff
  • Car:2x L34s,+ HZ GTS, A9X HATCH.A9X SEDAN
Posted 06 December 2020 - 12:13 PM
Hello if you wish to get really into it there is over 100 different changes in an A9x to a standard Lx. Black outs were different between the two. L34 only had small slr5000 stencil on rear spoiler & front gaurds,, a9x has large stencil right across rear stencil. More differences than i can type. Good luck Jeff
#15 myss427
myss427
  • 1,636 posts
Posted 08 December 2020 - 01:59 PM
The A9X basically fixed all the weaknesses of the L34, the L34 had the performance but a weak drive train, the A9X changed the brakes, gearbox, diff and suspension points to improved the handling and reliability, plus a 2 door back for racing with a lightweight shell as a bonus.
#16 Shiney005
  • 9,584 posts
  • Car:Toyota Mirai
Posted 09 December 2020 - 11:41 AM
A9X. (Bonnet should be satin, not gloss, and this early build car has the L34 rear flares.)
Attached File  1977-holden-lx-torana-a9x-sedan.jpg   167.69K   6 downloads
Attached File  1977-holden-lx-torana-a9x-sedan (2).jpg   165.34K   6 downloads
L34
Attached File  MCM 2009 (4)small.jpg   363.53K   6 downloads
Attached File  Autorama 2019 maybe Bob Byrnes (4).jpg   60.91K   6 downloads
Edited by Shiney005, 09 December 2020 - 11:42 AM.
