LCGTR 2 barrel stromberg
36 replies to this topic
#1 Indy Orange
Indy Orange
  • 2,946 posts
  • Name:Paul
Posted 03 January 2021 - 03:13 PM
Hi all, well it’s one step forward and two back , I received my carburettor back from the reconditioning place and thought it would be ready to bolt on , I soon realised it is missing the dash pot and associated bracket to hold it on and by the looks could also be missing some bushes . Anyone know where I could find the missing bits? Thanks Paul.
This is how it should be.
#2 RallyRed
  • 8,150 posts
Posted 03 January 2021 - 03:39 PM
Hi Paul,
This may have some bits?
PM me if you like. No dramas if no interest. I think I was advised previously that it is non LC GTR WW?? .
Col
#3 Indy Orange
Indy Orange
  • 2,946 posts
  • Name:Paul
Posted 03 January 2021 - 03:40 PM
And this under the dash! Do I need this as well?
#4 Indy Orange
Indy Orange
  • 2,946 posts
  • Name:Paul
Posted 03 January 2021 - 03:54 PM
Hi Col , the carby was set up for a manual choke at some point .I think I need these bits.
Edited by Indy Orange, 03 January 2021 - 03:55 PM.
#5 Indy Orange
Indy Orange
  • 2,946 posts
  • Name:Paul
Posted 03 January 2021 - 07:14 PM
Anyone know about these carburettors?If someone has an original set up , a few pics would be really helpful, thanks Paul.
Edited by Indy Orange, 03 January 2021 - 07:20 PM.
#6 torana?
torana?
  • 95 posts
Posted 03 January 2021 - 07:24 PM
I think this is the rubber bush you need https://www.rarespar...e-hk-ht-hg-186s
Edited by torana?, 03 January 2021 - 07:28 PM.
#7 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 03 January 2021 - 07:28 PM
I’ve got half a dozen here, mostly off 253 and 302. Will drag them out in the morning if I remember.
#8 Indy Orange
Indy Orange
  • 2,946 posts
  • Name:Paul
Posted 03 January 2021 - 07:59 PM
thanks mate I'll look into that.Thanks Clay. I can't think of another Holden that shares the same 2 barrel stromberg with auto choke.
#9 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 03 January 2021 - 09:11 PM
Hi Paul, for that price he should have given you a complete Carbie.
I could unpack mine and take pics if required.
Marty
#10 Indy Orange
Indy Orange
  • 2,946 posts
  • Name:Paul
Posted 03 January 2021 - 09:47 PM
Marty
I know Marty ,pics would be great thanks mate.
#11 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 03 January 2021 - 10:54 PM
All 253 ran auto choke WW/WW2 Stromberg
#12 Ice
  • 15,202 posts
Posted 03 January 2021 - 11:00 PM
Gee we thru away a bucket load of strommies no one wanted them
now we need them
#13 yel327
  • 13,643 posts
Posted 04 January 2021 - 07:53 AM
As above, every 253/4.2 from the first engines through to the end of HZ and VB had an auto choke WW Stromberg. Except for the Hurricane, or the few that had an Email 2BBL carb.
Agree Gene, we all chucked them and the manifolds they were on in the alloy scrap pile.
#14 claysummers
claysummers
  • 3,638 posts
  • Name:Clay
Posted 04 January 2021 - 08:50 AM
Hi Paul, my cards all seem to have somewhat different choke set up. As stated they are generally off v8 engines. Some photos in any case.
Clay 3a9382b687c868b464df397099ad4294.jpg634732abd50412b1fda73ab41f091433.jpg27a8ce8ba130714a0753f7cb0b039836.jpgfb44ab69a7f8cdba42464daab0a681d1.jpgb209a25b084e73030a7a4f617058e0e4.jpg26832f0ca1ab9a944879766e67da2511.jpgda9e66ba796db9ab9bbd1737895c1491.jpg0aea3544b68d6f74ba00e89a7b09ef0a.jpge88d5eb05721d80d65f55a81b1a05c3a.jpg
#15 Indy Orange
Indy Orange
  • 2,946 posts
  • Name:Paul
Posted 04 January 2021 - 01:03 PM
Thanks for the pics Clay , it all helps .
I think the early 2 barrel strombergs may have had the metal throttle damper dash pot and bracket which is what I’m missing.
The HR HK 186s could have had the same set up but I’m not sure on that.
Edited by Indy Orange, 04 January 2021 - 01:05 PM.
#16 yel327
  • 13,643 posts
Posted 04 January 2021 - 01:30 PM
Little bit expensive but a whole 186S HK engine for $2000:
https://www.gumtree....opytopasteboard
#17 Indy Orange
Indy Orange
  • 2,946 posts
  • Name:Paul
Posted 04 January 2021 - 01:47 PM
And probably missing the throttle damper and bracket , because everyone got rid of them in favour of the manual set up!😢
Edited by Indy Orange, 04 January 2021 - 01:48 PM.
#18 Indy Orange
Indy Orange
  • 2,946 posts
  • Name:Paul
Posted 04 January 2021 - 07:57 PM
If anyone has these carby bits and willing to
Part with please let me know!
#19 S pack
  • 15,726 posts
Posted 04 January 2021 - 09:02 PM
The throttle damper (dashpot) that your carby is missing is not part of the auto choke system.
#20 rodomo
  • 18,038 posts
Posted 04 January 2021 - 09:10 PM
Yes. The diaphragm pictured is to pull the choke off if you nailed it while still cold.
#21 Indy Orange
Indy Orange
  • 2,946 posts
  • Name:Paul
Posted 04 January 2021 - 10:07 PM
Righto ,but with a manual choke you wouldn't need it.
#22 S pack
  • 15,726 posts
Posted 04 January 2021 - 10:14 PM
The throttle damper is an anti-stall device. It is there to soften the closure of the throttle valves in the case of the throttle being allowed to snap shut.
#23 rodomo
  • 18,038 posts
Posted 04 January 2021 - 10:21 PM
Yes to maintain RPM on gear changes..........................Did autos have them?  :huh:
#24 S pack
  • 15,726 posts
Posted 04 January 2021 - 11:20 PM
A quick check of the LH Torana cattledog shows no mention of the throttle damper assy on manual or auto 4.2litre engines.
Perhaps this was only req'd on the high output big banger 6cyl  'S' engines. ^_^
#25 Indy Orange
Indy Orange
  • 2,946 posts
  • Name:Paul
Posted 04 January 2021 - 11:24 PM
Is this for LCGTR?
