Mods for V8 install
#51
Posted 21 February 2021 - 11:31 AM
https://www.gumtree....opytopasteboard
#52
Posted 21 February 2021 - 02:55 PM
If a Trimatic fits a Powerglide will. But I’d use a TH350, pretty close to the same size.
no they don’t, they need trimming and tunnel need moving with a big hammer
#53
Posted 21 February 2021 - 02:57 PM
This is too dear, but this sort of stuff pops up from time to time. These make a decent engine if you can run a 327. As a factory L76 engine with the lumpy top pistons, 2.02/1.6 fuelies, solid 30-30 Duntov cam, alloy intake, baby Holley and Ramshorns these easily make 350hp. Using extractors, modern heads and modern cam they’ll go well over 400hp
hate to tell but you will pay $1000+ for a rebuilder sbc.
#54
Posted 21 February 2021 - 03:10 PM
The TH350 or the Powerglide?
#55
Posted 21 February 2021 - 03:18 PM
Not relatively unwanted stuff like 327SJ or 283 or non-Holden 307 or other oddball stuff like 305. That link I put up was just a block and crank with some used pistons and rods, the heads are mismatching small port scrap and so is the intake. Yes you’ll pay over $1000 for a large journal long motor to suit rebuild, but not for the stuff I mentioned.
#56
Posted 21 February 2021 - 05:30 PM
3spd is always better in low powered car especially something low weight will feel more fun...2spd glide feels lazy with tall gears.
Loved the trimatic behind 355 4500 stall 4.56 gear setup in vh sle.
Obviously th350 can be built stronger & torrie will rip nicely with tamer stally & gears.
*last time asked Dr Terry said should be copies on ebay.
Edited by gtrboyy, 21 February 2021 - 05:32 PM.
#57
Posted 21 February 2021 - 06:11 PM
The glide
#58
Posted 21 February 2021 - 06:41 PM
What is this book by Dr Terry called ?
I take it a turbo 400 is bigger than a th350, so harder to install.
#59
Posted 21 February 2021 - 07:07 PM
TH400 is massive compared to TH350 and Trimatic.
I’m surprised a Powerglide fouls an LC tunnel. Is it the bellhousing? They are no larger than a Trimatic in the body. I would have thought that if an Aussie 3/4speed and Trimatic fits that a ‘glide would too.
Edited by yel327, 21 February 2021 - 07:11 PM.
#60
Posted 22 February 2021 - 08:51 AM
The 60 years of Holden book is not available anywhere.
Can someone please get the info from the page with the LC - LJ weights on it.
#61
Posted 22 February 2021 - 09:14 AM
#62
Posted 22 February 2021 - 03:33 PM
email address sent.
#63
Posted 23 February 2021 - 10:21 AM
#64
Posted 24 February 2021 - 09:32 AM
How would you ship an engine from interstate ?
#65
Posted 24 February 2021 - 12:14 PM
#66
Posted 24 February 2021 - 06:10 PM
#67
Posted 24 February 2021 - 07:18 PM
Townsville is too far me to drive, plus my small sedan won't take it anyway.
#68
Posted 24 February 2021 - 07:44 PM
http://www.superchev...ine-performance
#69
Posted 24 February 2021 - 07:58 PM
#70
They put a 327 crank in it which makes it a 307 (+60 makes it 316). Using old power pack heads (which people throw away) and old school intake setup they got nearly 340hp.
None of this is relevant if you can go bigger, but if you are stuck with a baby SBC it isn’t the end of the world.
http://www.superchev...n-and-tri-power
I bought a good useable 283 with 462 fuelies, Weiand intake and Quadrajet a few months back for $400. I’m going to use it in my HK to set it all up and Engineer it. There are plenty around like it.
#71
Posted 24 February 2021 - 08:02 PM
Small timber pallet, couple of of ratchet straps, shrink wrap over that..
All good, no dramas.
Just need s fork at each end to load/ unload.
Edited by RallyRed, 24 February 2021 - 08:02 PM.
#72
Posted 07 March 2021 - 09:56 AM
There seems to be a shortage of small block chevs, well under 350 cubes at least.
Has me thinking of all other sorts of engines 308-202-186, at least with a 6 no engineering needed.
#73
Posted 07 March 2021 - 10:00 AM
#74
Posted 07 March 2021 - 10:32 AM
Looking everywhere, Trying to get something complete ready to drop in.
#75
Posted 07 March 2021 - 11:22 AM
Put up a wanted ad, for a 262/267/283/302/305/307 in running condition.
Just make sure you avoid from memory pre 1959 as they don’t have side mounts.
That new L99 is still on EBay:
https://www.ebay.com...a5-7c7748df6cd4
