Mods for V8 install
#101
Posted 21 March 2021 - 06:43 PM
https://www.gumtree....opytopasteboard
#103
Posted 24 March 2021 - 11:33 AM
I just got back from there. It is a 1967 327 275hp powerglide engine (so small journal) and intake to suit, but the fuelie heads are gone. It has 1972-ish 76cc heads on it, basically as fitted to a HQ. Same ports and valves as a fuelie just 76cc chambers rather than 64cc. No good for that engine as it would be about 8.5:1 compression - exactly the same basic engine as a 2nd type GTS327 engine just all different casting numbers. Would be a good engine to hone and put new rings and bearings in but needs better heads.
I bought the 307 he had advertised.
#104
Posted 24 March 2021 - 11:43 AM
Still don't know If I can fit it, Better try to find the right engineer first.
#105
Posted 24 March 2021 - 12:04 PM
Would it be worth buying or would you have bought it already.
How much would good used heads (fuelies) go for ?
#106
Posted 24 March 2021 - 12:41 PM
You’ll buy 462 or 291 or 186 fuelies for less than $500, I picked up some 292’s for $200, but 041’s will cost you $1000’s as GTS350M owners want them. Not worth the hassle today, by the time you reco them with new valves, springs and hardened seats you’ll be up for $1000 plus the heads cost. Best to buy aftermarket alloys, less than $2000 for a pair ready to go that would be perfect for a 327:
https://www.ebay.com...LsAAOSwXSpgRlM3
BTW, that 327 can be made into a 302 easily and cheaply. Just need a 283 crankshaft. Plus rebuild of course with new pistons with the 302 pin height.
Edited by yel327, 24 March 2021 - 12:43 PM.
#107
Posted 24 March 2021 - 04:09 PM
Would you get away with just saying 302 cubes or would engine numbers say it's 327 block?
#108
Posted 24 March 2021 - 04:38 PM
The engine number tells you what it was used for, this was HF from memory (VxxxxHF) where the xxxx is the MM/DD of assembly which is 275hp 327 Powerglide 1966-67. Plus it had a partial VIN on it which identifies the car it was from.
I don't think that would stop you working with an Engineer and showing him it was built as a 302 though. People do it all the time with 386, 660, 388, 010 etc large journal blocks - they can be 302, 327, or 350 or stroked to 377.
#109
Posted 24 March 2021 - 08:02 PM
#110
Posted 25 March 2021 - 09:23 PM
Those 327 sell like hot cakes.
#111
Posted 25 March 2021 - 09:48 PM
You’d be far better off buying a good running one of the right capacity to please your Engineer. One will turn up. There is always a steady stream of good 283’s as people pull them out of imported Chevys and upgrade to bigger. Rebuilding one does add up, especially if you can’t do it yourself.
#112
Posted 26 March 2021 - 10:12 AM
#113
Posted 26 March 2021 - 04:59 PM
I could of bought a 307 with powerglide in better condition out of a HT for $2000. Makes this 283 a pricey deal.
#114
Posted 26 March 2021 - 05:39 PM
#116
Posted 29 May 2021 - 05:33 PM
I found a nice 202 efi with auto trans but need to ship it from Wollongong to Campbelltown not too far, any ideas about transport ?
#117
Posted 29 May 2021 - 06:19 PM
#118
Posted 29 May 2021 - 06:47 PM
#119
Posted 29 May 2021 - 10:47 PM
Unless I find an engine next door I give up, I don't even have a tow bar.
#120
Posted 30 May 2021 - 08:18 AM
#121
Posted 30 May 2021 - 08:51 AM
#122
Posted 10 September 2021 - 08:42 AM
early Holden nut
#123
Posted 10 September 2021 - 05:27 PM
What was vk efi 202 going to set you back?
Did it come with lc/j sump & correct engine brackets?
#124
Posted 10 September 2021 - 07:07 PM
$700, all standard vk and looked pristine.
#125
Posted 10 September 2021 - 07:14 PM
early Holden nut
