Wank factor for the HP
early Holden nut
Hi Clay, can i ask where you bought or who made up your twin carby fuel lines??
They look neat and trouble free.
I was mentioning them to a mate.
Thanks,
Jaso
Posted 28 November 2021 - 12:50 PM
early Holden nut
Posted 28 November 2021 - 04:04 PM
Posted 28 November 2021 - 04:27 PM
Posted 28 November 2021 - 04:30 PM
Posted 28 November 2021 - 05:29 PM
Posted 28 November 2021 - 05:46 PM
Jaso,
Thanks for the compliment mate. I bent and flared them up from a roll of 5/16” annealed copper tube from Car Parts Plus. Total outlay about $70 for T union, six tube nuts and 6metre roll of tube. I have a few bent up bits that weren’t quite right and had to redo, but still plenty of tube left over. I would have liked to run it all in the same plane with the needle and seat unions but my flaring tool requires a minimum length of pipe to flare, and the tube nuts were relatively long. This meant the T union clashed with the rocker cover so bending it down 90deg was my solution. I don’t braze and didn’t want to use hose. Yes I’m happy with it. Turned out well. Not sure how it will go when I put spacers to lift up the carbs. I may need to replace the pipe down to the pump.
I think my mate will make me up a pair of spacers to lift the jugs up so I can get proper WOT, and also to plumb the PCV. Looking at the master parts catalogue it seems they came factory with heat insulators, which would have lifted them up, but my carby guy didn’t seem to think them necessary. I think he is more of a Holley Weber guru but was local and willing and they seem to be running good although with no exhaust yet it has to sound pretty awesome right?
Posted 28 November 2021 - 06:45 PM
I'm still boggling about the .005" lash
Do you mean .005 crush?
If this is so, how much of a turn gives you .005?
.005" lash would normally be set using a .005" feeler gauge between the valve tip and rocker arm with the lifter on the base circle of the camshaft.
edit: just saw explanation/discussion about the lash in recent posts. I'll go back to my nanna nap now.
Edited by S pack, 28 November 2021 - 06:51 PM.
Posted 10 December 2021 - 09:26 AM
Posted 10 December 2021 - 02:12 PM
Posted 10 December 2021 - 03:11 PM
Posted 16 December 2021 - 09:22 PM
Posted 17 December 2021 - 05:20 PM
Posted 17 December 2021 - 05:30 PM
Edited by claysummers, 17 December 2021 - 05:32 PM.
Posted 17 December 2021 - 07:05 PM
Posted 17 December 2021 - 08:22 PM
Posted 17 December 2021 - 08:26 PM
Posted 17 December 2021 - 08:36 PM
Roller rockers are cheap and better than fatigued 50 year old pressed steel.
Then set the preload properly.
Posted 17 December 2021 - 09:10 PM
Posted 17 December 2021 - 10:06 PM
Posted 17 December 2021 - 10:15 PM
Posted 17 December 2021 - 10:43 PM
Are the spring retainers hitting the valve guides? I had a similar problem with a Holden head many years ago, after a set of guides were replaced, they were left too high. You can get new pressed metal rockers.
https://www.ebay.com...lBoCXpMQAvD_BwE
These are 1.6:1 ratio if you have the clearance.
https://www.vpw.com....rts/CRA-11802-1
Edited by warrenm, 17 December 2021 - 10:47 PM.
Posted 18 December 2021 - 12:21 AM
Posted 18 December 2021 - 05:19 AM
Hi just read your thread about a Brocken rocker issue, a similar problem happened to me, you have a 429 lift camshaft, I would check the push rods, there are 2 length sizes by memory, I removed the long ones and replaced them with the shorter ones, something to ask your mechanic,
Posted 18 December 2021 - 05:50 AM
Posted 18 December 2021 - 06:48 AM
Bruce is right about the press in studs, they should be fine as that lift is still only moderate.
The crow rollers would be fine and will bolt on no machining.
Early style head so should be the longer 9.136" push rod.
Check for coil bind, full lift and check the contact patch on the valve tip most importantly.
Then do not set up with any lash!!! Hydraulic lifters need preload on them. Find zero lash, then set the preload.
Agree Adam, if the engine builder deemed the weight of the valve springs shouldn't require pinning of the rocker studs for the std pressed rockers then they won't need pinning for roller rockers.
Go the roller rockers Clay, there is a bolt on solution to suit your application.
