Yours are the same as the ones I am talking about, Clay. The bendy part is the long side with the 4 holes in.
They don’t take much to bend them sideways a bit.
909ADF58-3275-4F42-B124-8675261E012F.jpeg 239.11K
10 downloads
Nice?? Thanks, klevliend
If you Are talking about the black gadget the cable rides in, that was an attempt to
Improve on the off idle throttle response being too sudden and almost violent
I found I couldn’t roll off gently from a standstill and ended up with aching ankles and shins trying to
baby the pedal so much. Found that elliptical thing on some little Hyundai-ish car.
It’s like having a long link to the hex shaft to start with, and it gets shorter as it approaches full throttle.
Sort of gears the system down initially. Looks a bit ugly, and it’s a subtle difference but works pretty well.
Along with some smarty pants changes to the rod geometry, I can crawl off the mark now without
too much trouble.
The other weird bit is for adjusting the idle with a master screw, got sick of re-adjusting the idle with the 3
carb screws and the synchronising tool each time I buggered with the timing.
The alloy bit with spring and screw is a lump hacked off an old ruined Holley baseplate
All these start out life as an experimental prototype to be remade later nicely
but usually end up staying put once working acceptably heheh
The bodgy bracket is mounted to the bodgy throttle cable bracket which is mounted to hole #3
in the hex shaft bracket. Because of the strongish master return spring, it flexed all over the place.
The brassy 90degree rose joint pedestal mount (or whatever the hell they are called) bracket flexed too.
981E5B18-A402-466A-B0EE-FA7E856B6757.png 35.57K
10 downloads
These buggers - hex shaft rose joint bracket?
Enter one brace from manifold to throttle cable bracket. Not too bad now.
Good fun, eh?
Good thing you are a crack problem solver and all round clever feller Clay
