186 rebuild, Oracle advice
#451
Posted 02 August 2023 - 11:54 PM
#452
Posted 06 August 2023 - 05:38 PM
Need to plug the manifold heat water outlets. For tidiness I want to run my heater outflow to the lower thermostat housing which runs through passages in the head and block to the water pump inlet. I will tap and plug the water pump barb and top barb on the thermostat housing. For the heater outlet I want to run 1/2" copper from the firewall, in between the inlet and exhaust manifolds to the bottom barb. Plan was to use a tube nut and flare into a female base fitting tapped in to the bottom thermo housing inlet, but I'm having trouble sourcing a female fitting. Plumbing ones have too big a threaded end to fit in the housing barb. I was told fridge fittings may work but haven't sourced anything yet.
#453
Posted 10 August 2023 - 07:56 PM
Just
Probably fit the battery back in there minus the big ol’ box now. Need to recess the corner of the firewall about 15mm to fit filters, which will help with clearance to the rear linkage as well.
I wonder if there is any issue with tipping the rear fuel bowl over as it is very close to the header. They can be canted to an extent, I assume to sit level, depending on manifold used.
#454
Posted 10 August 2023 - 11:44 PM
#455
Posted 12 August 2023 - 11:49 AM
#456
Posted 26 August 2023 - 12:59 PM
#457
Posted 26 August 2023 - 05:37 PM
We’re you a plumber in a previous life?
#458
Posted 26 August 2023 - 08:23 PM
#459
Posted 26 August 2023 - 10:32 PM
What you have is 1/4"NPT to #6JIC(hydraulic fittings) also known as -6AN in the USA etc.
Looks good.
#460
Posted 27 August 2023 - 10:00 AM
#461
Posted 02 September 2023 - 06:33 PM
Sent from my SM-N986B using Tapatalk
#462
Posted 02 September 2023 - 06:41 PM
I was a plumbers best man. There are only two rules in plumbing. Apart from that it is a black art. My fitter mate Brett helped me out with the fittings and thread tap. The alloy housing was on a 161 i bought of a guy really cheap. Had new extractors and WW2 induction and EH sump.
#463
Posted 02 September 2023 - 06:55 PM
Finally kicked in the guts but I should have replaced the manifold gasket as a matter of course. Couldn’t get it to idle below 1200rpm. Bit of heater hose stethoscope I can hear what sounds like sucking on the front pots, so sprayed on some ether and the revs pick up. I have a nice gasket I got together with the one that is on there from one of you when I built the engine, which I didn’t bother changing when I fit the X2 setup. Should be more risk averse I suppose….
#464
Posted 02 September 2023 - 07:28 PM
#465
Posted 02 September 2023 - 09:37 PM
#466
Posted 03 September 2023 - 04:25 PM
#467
Posted 03 September 2023 - 04:26 PM
Is there an open vacuum port somewhere?
Rob
#468
Posted 03 September 2023 - 04:55 PM
#469
Posted 03 September 2023 - 05:01 PM
Did you tighten from the centre out?
Might just need an extra half turn somewhere too.
Rob
#470
Posted 03 September 2023 - 07:44 PM
#471
Posted 03 September 2023 - 07:50 PM
Ne’er had this problem with the coarse brass nuts on the factory bendix stromberg manifolds.
#472
Posted 04 September 2023 - 08:12 AM
If you don't resolve it Clay try sitting the manifold face(s) on a flat surface with something that will act as a witness material, basically do the same job as bearing blue does. It could be as simple as whiteboard marker with some paper on the flat surface. Just in case there is a twist or similar not quite flat face on the intake. Is the gasket used one of those old-fashioned fibre core with dimpled steel face? Or those pink extractor type gaskets?
#473
Posted 04 September 2023 - 08:38 AM
#474
Posted 06 September 2023 - 12:13 PM
Nothing obvious, but dressed with a file ready for reinstall.
Edited by claysummers, 06 September 2023 - 12:13 PM.
#475
Posted 06 September 2023 - 01:31 PM
