186 rebuild, Oracle advice
#526
Posted 11 October 2023 - 04:45 PM
#527
Posted 11 October 2023 - 05:24 PM
Doesn't sound too drastic to me Clay. But I have no idea what red 6's work like with compression and octane. You are on the right Forum though for the answers!
#528
Posted 11 October 2023 - 08:09 PM
Rough figures based on the factory chamber volumes,
I get:
Open
Static 8.0 Dynamic 7.7
Closed
Static 8.9 Dynamic 8.5
I would think 8.5:1 dynamic would be OK on 91 or certainly 94. I suppose the fuel pump diaphragm and plastic floats in the SUs would handle E10 ok?
If so I might see about getting the small chamber head smikked up a bit.
Clay, I reckon you'll be fine running 91 with 8.5:1 compression. Back in the later 80's when Ron Richards rebuilt my 202 he set the compression at 9.9:1 because LRP (Lead Replacement Petrol) was only 96 octane.
To run compression higher than than 10.1:1 he said I would need to add octane booster to the fuel and I didn't want to have to bother with that.
I've got the timing set to run on 98 but I have run 95 in the 202 without any hint of pinging.
You would want to be careful running E10 in an older car that has a fuel tank and carburettor/s vented to atmosphere. E10 is hygroscopic.
Edited by S pack, 11 October 2023 - 08:15 PM.
#529
Posted 11 October 2023 - 08:48 PM
Thanks Dave. Makes sense, alcohol being hygroscopic. I'm always using metho to dry bare metal. It absorbs any water and the whole lot evaporates.Clay, I reckon you'll be fine running 91 with 8.5:1 compression. Back in the later 80's when Ron Richards rebuilt my 202 he set the compression at 9.9:1 because LRP (Lead Replacement Petrol) was only 96 octane.
#530
Posted 12 October 2023 - 08:58 PM
Quite right Bruce, bit less duration, bit more lift. The head can stay on there for the present. I do need to get some stiffer pushrods though.How did he describe the way that cam would operate powerwise , Clay?
It’s a bit smaller than the one you had in there
What is your compression as it sits now?
What number did he recommend?
Did you speak to any of the other guys for a second or third opinion?
Sorry, that’s 4 questions
#531
Posted 13 October 2023 - 08:02 AM
The smaller duration and the resulting smaller overlap
would have to increase your cranking and lower rpm band
compression numbers anyway over what you had before.
Hopefully you’ll end up with an even snappier and more responsive motor
in the rev range you want to use
#532
Posted 13 October 2023 - 08:55 AM
#533
Posted 16 October 2023 - 08:25 PM
Edited by claysummers, 16 October 2023 - 08:30 PM.
#534
Posted 19 October 2023 - 06:12 PM
I've been casting around looking for a cylinder pressurisation fitting to hold the valves in place while I change the springs, but all th ones I've seen don't have enough reach to start the thread in the plug hole.
#535
Posted 19 October 2023 - 11:06 PM
#536
Posted 20 October 2023 - 03:08 AM
Bloody flu has left me with this cough keeping me awake from the early hours.
#537
Posted 20 October 2023 - 07:04 AM
Came with 4 threaded adaptors, not one of them reached the threads in the head
#538
Posted 20 October 2023 - 08:33 AM
#539
Posted 20 October 2023 - 05:55 PM
#540
Posted 21 October 2023 - 08:45 AM
Sounds like you are having fun with the flu.
Ive been using senega and ammonia mixture for years and it usually keeps the flu away, but if I use it too late, I rarely have more than 2 days crook.
It is a cheap cough medicine available at every chemist.
It tastes like crap, but tit works
Rob
#541
Posted 21 October 2023 - 10:52 AM
Bruce I don't do rum mate....
#542
Posted 21 October 2023 - 03:09 PM
Edited by claysummers, 21 October 2023 - 03:10 PM.
#543
Posted 25 October 2023 - 08:01 PM
Th3 word on the flywheel @nd clutch is that being billet chromoly it will be perfectly balanced, and the clutch at worst needs to have shouldered bolts to centre correctly. I don’t know if anyone has heard of these?
#544
Posted 25 October 2023 - 08:21 PM
Standard. The shoulder as you call it is the shank of the bolt which doubles as a dowel.
#545
Posted 25 October 2023 - 08:39 PM
Here's one I prepared earlier
Edited by rodomo, 25 October 2023 - 08:40 PM.
#546
Posted 25 October 2023 - 09:26 PM
#547
Posted 27 October 2023 - 03:36 PM
The std bolts attaching the pressure plate to the flywheel are "shouldered" bolts.
#548
Posted 27 October 2023 - 04:49 PM
#549
Posted 28 October 2023 - 05:47 PM
#550
Posted 30 November 2023 - 05:18 PM
Installing new main bearings, all clearances came up around 0.001 - 0.0015", with the notable exception of the rear main which is lucky to be 0.004".
