186 rebuild, Oracle advice
#576
Posted 10 December 2023 - 11:34 AM
Would that plug of vaso need to get hot and soften up?
Would be a bastard if it didn’t unblock after getting the whole thing re-installed for starting up
I am not sure wether to be worried for you on that one or not
I did the Vaseline on the gears trick, also used an oil can to squirt as much in through the oil pressure sender
which I figured would run down into the out flowing half of the pump, wetting them more at least.
I think the teeth going backwards as they rotate might pull that oil in behind themselves as well.
Thought attempting to fill up the main gallery was a good idea, too, but it probably just went past the lifters and down
And put some more into the holes where the filter goes, but that might have just drained downwards anyway.
May have been unnecessary, but was just a why the hell not idea and it couldn’t hurt anything
Filled the filter, too.
No problems, pressure straight away
#577
Posted 10 December 2023 - 11:36 AM
#578
Posted 10 December 2023 - 03:56 PM
That's were SBC and BBC are awesome. You pull the dizzy out and replace with a battery drill driven setup that drives the oil pump. Get full oil pressure, replace the dizzy and start it.
#579
Posted 10 December 2023 - 06:17 PM
#580
Posted 12 December 2023 - 07:13 PM
#581
Posted 13 December 2023 - 11:27 AM
#582
Posted 13 December 2023 - 09:26 PM
I use an old fire extinguisher, a few litres of oil in the sump, the remainder in the extinguisher, pressurise the extinguisher, connect to the oil sender fitting, open the valve on the extinguisher, hit the starter, instant oil pressure. You can use any type of small pressure vessel that you may have laying around.
#583
Posted 01 January 2024 - 07:55 PM
#584
Posted 01 January 2024 - 08:14 PM
#585
Posted 01 January 2024 - 09:12 PM
#586
Posted 02 January 2024 - 08:12 AM
#587
Posted 02 January 2024 - 10:24 AM
#588
Posted 02 January 2024 - 10:31 AM
Yeah they changed the box design as it used to leak out and ruin clutches. Plus make a stinky mess!
#589
Posted 02 January 2024 - 06:01 PM
#590
Posted 02 January 2024 - 08:03 PM
No wonder you headed for the drive through
You deserve a couple of stouts
#591
Posted 02 January 2024 - 08:48 PM
#592
Posted 10 January 2024 - 10:52 PM
#593
Posted 12 January 2024 - 01:52 PM
Hopefully that will be it, with nothing much next oil change.
#594
Posted 12 January 2024 - 03:12 PM
#595
Posted 17 January 2024 - 04:28 PM
#596
Posted 17 January 2024 - 04:48 PM
Just out of interest Clay, why larger exhaust valves? Normally its intakes you make bigger, or are red 6's that deficient in the exhaust?
#597
Posted 17 January 2024 - 05:01 PM
#598
Posted 17 January 2024 - 05:41 PM
Cool. I was only going by what I know for SBC's. They have 1.72" intake and 1.5" exhaust for small engine, and low rpm applications. All they did was changed to 1.94" intakes and larger ports when performance was required, still kept the 1.5" exhaust valves. The only time they put larger exhaust valves in they only went to 1.6" along with an increase to 2.02" intakes. And that was only for the big solid cam, 325hp+ engines.
#599
Posted 29 January 2024 - 05:43 PM
#600
Posted 29 January 2024 - 06:38 PM
Big thumb prints........
