Early locally built Crowns had Holden banjos in a different housing (4 link) and were F@4D pattern
If my sad old memory is correct?
The locally assembled ones did. It was the fully imported ones I was referring to.
Posted 29 June 2021 - 07:50 AM
Posted 29 June 2021 - 12:00 PM
Posted 29 June 2021 - 07:33 PM
Posted 29 June 2021 - 09:29 PM
Posted 30 June 2021 - 02:00 PM
Posted 30 June 2021 - 02:03 PM
Don't know that would bolt to Holden six Byron?Clay. This might be better! Looks like a Saginaw or “T10” 3spd maybe?
https://www.gumtree....opytopasteboard
Posted 30 June 2021 - 02:21 PM
Posted 30 June 2021 - 09:13 PM
Posted 01 July 2021 - 09:11 AM
Posted 02 July 2021 - 11:15 AM
Posted 02 July 2021 - 11:37 AM
Sorry missed this Trev.Poor crunch box didn't like the new grunty donk
Whats your next box option ?
Was your fuel pump new?
Did you put sealant on the fuel pump mounting bolts?
Had pumps leak oil out the bolt threads & from worn pivot pins.
Hopefully a simple fix & not requiring pulling the sump!
Posted 02 July 2021 - 11:59 AM
Reckon the blocks are too long to fit without moving firewall back and radiator forward. Holden 7 bearing straight six fits just. Thinking about trimatic. Meanwhile will beef up a crash box and go easy on the pedals.
They fit in HR, they were used from some time in 1967, but as you say an FE-EJ has a little less room as the engine sits back a fair bit in those. I can't find engine bay photos but here is a HT. You can see it is longer and needs a skinnier shroud but could work with electric fans in an FE-EJ. Personally I'd probably not bother, if you wanted more than 202ci fit a 283 or 307 with alloy heads. Easy fitment into HD-HR and probably with a Trimatic (easy done today with available bellhousings). A mate and I trial fitted a 308 in an FC van once, just needed minor work on the firewall seam to make it fit on HR engine mounts. Lots more frigging around for the gearbox tunnel than it was worth though. I'd still love to try a 292 in a lighter Holden though, like a cab-chassis with alloy tray or a HK-HG ute. I had a guy willing to give me a running 292 at one stage to try in my HZ Overlander as the 308 lacked torque for towing, but never bothered as a 454 was actually easier to fit with available bits than the 292 was. Still have the 454 but no Overlander anymore.
ad-assets_JCW4089834_JCW4089834-3.jpg 133.68K
11 downloads
ad-assets_JCW4089834_JCW4089834-4.jpg 126.13K
11 downloads
Edited by yel327, 02 July 2021 - 12:02 PM.
Posted 02 July 2021 - 12:14 PM
Posted 02 July 2021 - 12:55 PM
Horrid to sit in though, legs one way and arms the other! A 292 with compression upped, better cam and an aftermarket modified head with a Quadrajet and HEI would be a nice engine in a HJ cab-chassis, with a 4sp auto behind it.
Lots of cool stuff here:
Posted 14 July 2021 - 09:16 AM
Posted 14 July 2021 - 12:34 PM
Clay, this is from my EH Factory workshop manual. Hydraulic Lash Adjustment.What valve lash do others run on their adjustable hydraulic lifters?
I have always set a clean sliding 0.004” on a warm engine. Over tighten with gauge inserted, then back off until it pulls out cleanly.
I use 4thou because I don’t have a 5 in my set. Discussing with a mate the other day, he runs them with slight pre-load. No gauge. Just takes out any lash, then tightens 1/8th turn. He says hydraulic lifters should be slightly compressed. I can’t see how he can be sure he isn’t over compressing them (other than exhaust note), leading to potential for burnt valves.
Edited by 73SUNBURSTEXYOUWON, 14 July 2021 - 12:36 PM.
Posted 14 July 2021 - 01:27 PM
Posted 14 July 2021 - 05:17 PM
Posted 14 July 2021 - 05:59 PM
Posted 14 July 2021 - 06:30 PM
Posted 14 July 2021 - 06:52 PM
Posted 14 July 2021 - 06:57 PM
Posted 14 July 2021 - 07:23 PM
What will I break next? The spring will be in the sump.
early Holden nut
Posted 14 July 2021 - 07:55 PM
My brother lost the fuel pump spring and the arm on his 186.
The parts were floating around in the sump for years and never caused any problems.
Posted 14 July 2021 - 09:08 PM
