Is it 2807236?
Did the A9X have a different number?
What does the distributor with part number 9938994 suit?
I have searched other posts however they mainly cover LH SLR.
Posted 02 May 2021 - 10:57 AM
Posted 02 May 2021 - 12:06 PM
It is the Bosch number you are looking for. LX 5.0L with ADR27A lists the same as HX as 9 230 063 825. HZ does change from HX to 9 230 063 835. Most A9X got HZ engines, not sure if they changed to the HZ dizzy or not. It is not listed as a change in the LX Features Manual amendment for A9X though.
That 9 230 063 801 is for HJ Holden and Statesman and also for LH after HJ release and early LX.
9938994 is the ADR27A 5.0L distributor for HX and LX, it will be 9 230 063 825.
I'll see if I have an ADR27A one, would be happy to swap with you as my HJ Premier is missing its proper dizzy, it had a Scorcher on it when I bought it and now has the wrong one.
Posted 02 May 2021 - 02:14 PM
Posted 02 May 2021 - 02:19 PM
Posted 02 May 2021 - 07:11 PM
Posted 03 May 2021 - 11:32 AM
Just out of interest, what are the numbers on those earlier distributors?
Posted 03 May 2021 - 12:02 PM
Posted 03 May 2021 - 12:08 PM
Nah, not worth the trouble, I thought you might still have them handy!
Posted 03 May 2021 - 04:55 PM
Posted 03 May 2021 - 05:58 PM
I've been goggling what I can on the Bosch part numbers, (with a number something like "9 230 063 800") various sources say:
The first digit is apparently the factory / manufacture location ("0" seems to be Germany, "1" must be somewhere else in Europe, and I'm guessing "9" must be Australia).
The second number "230" (and apparently "231") seems to designate it's a distributor.
The third number specifies the points plate fitted (which determines the points / condensor set used). Holden 6 cylinder red motors are mostly all "062" and red V8's are "063". However I did see a picture of a very early prototype Holden V8 distributor with an "060" points plate in it (unless it was a mis-stamp)? I know the twin-point L34 distributor was custom built by Repco but I'd be interested to know what points plate was used, unless it was custom made too?
And the fourth number is the distributor model (I think). This seems to incorporate things like the type of advance mechanism (vacuum and/or mechanical) as well as the weights fitted.
At first I thought that the first digit in the last group seemed to indicate the number of cam lobes (6 cyl dizzies start with a "6" and V8 dizzies start with an "8") but then I found an electronic dizzy from a 6 cylinder Commodore that started with a "7" so guessing it's just a model number after all?
Posted 03 May 2021 - 06:14 PM
Edited by hanra, 03 May 2021 - 06:21 PM.
Posted 04 May 2021 - 08:59 AM
The body on the L34 dizzy has the same numbers as Brads, with the exception of the sideways 324. Mine is 421.
The points plates are custom made with no numbers.
Mine 1.JPG 169.08K 5 downloads
Mine 2.JPG 175.55K 4 downloads
Mine 3.JPG 260.13K 5 downloads
Mine 4.JPG 296.92K 3 downloads
Posted 04 May 2021 - 09:09 AM
The numbers in the parts book all match up.
Posted 04 May 2021 - 09:26 AM
Posted 04 May 2021 - 10:25 AM
Posted 04 May 2021 - 10:30 AM
~ makes me think it’s a time/date code of sorts.
"421" could possibly be 1st February 1974, which would be about right for an L34 distributor giving Repco time to do their mods.
21 couldn't be a week number as that's too late for L34 production, I guess it may just be a batch number?
Brad's dizzy has "324" stamped on it. Is yours likely to be made in Feb '73. Brad (if it's original)?
Posted 04 May 2021 - 10:34 AM
Mine is not original. My car had a Mallory twin point in it when I got it. I think I actually bought that dizzy off dattoman.
Edited by hanra, 04 May 2021 - 10:35 AM.
Posted 04 May 2021 - 04:23 PM
1st number is the year, second & third number is the month
421 = 1974 January
324 = 1973 April
25 = May
26 = June
27 = July
28 = August
29 = September
30 = October
31 = November
32 = December
The following calendar year the January code resets to 21.
Posted 04 May 2021 - 04:43 PM
I should have twigged to this before. I was calling 9 230 063 801 (part number 2807236) a HJ distributor. It is actually HT-HJ, LH and early LX 308/5.0L. 800 is 253/4.2 for the same period.
So they are I believe:
9 230 063 800 HT-HJ, LH, early LX 253/4.2
9 230 063 801 HT-HJ, LH, early LX 253/4.2
9 230 063 824 HX, ADR27A LX 4.2
9 230 063 825 HX, ADR27A LX 4.2
9 230 063 834 HZ, VB 4.2 (probably late LX after HX release too)
9 230 063 835 HZ, VB 5.0 (ditto for late LX)
Not sure if there are any others in this period. The Bedford V8's were HEI dizzys.
Edited by yel327, 04 May 2021 - 04:50 PM.
Posted 08 May 2021 - 07:35 PM
I was just looking for something else and ran across these pics in the service manual, I never realised how much difference there is between a 253 and a 308...
Posted 09 May 2021 - 12:56 PM
Why would that be?
Posted 09 May 2021 - 01:28 PM
