Noise?
11 replies to this topic
#1 RallyRed
  • 8,150 posts
Posted 21 May 2021 - 08:28 PM
Got pinged the other day by the Noise meter at a track day.
96 limit, I went 97.1.
I understand it's a logarithmic scale, so 1.7 over,is more than it seems.
2 x shotgun style pipes out the side.
Never been pinged before, so assume cold/ dense air is the issue?
I dont want to change the exhaust/ muffler , for the rare issue day.
Looking to just fit 2 x 90 degree removable 90 degree down elbows, to only fit if/ when reqd.
Question - anyone had real world experience with the attenuation that pointing pipes at the ground will achieve?
#2 rodomo
  • 18,038 posts
Posted 21 May 2021 - 10:44 PM
Hoon
#3 RallyRed
  • 8,150 posts
Posted 22 May 2021 - 06:16 AM
Hoon
Thank you, I try. :D
#4 Shiney005
  • 9,604 posts
  • Car:Toyota Mirai
Posted 22 May 2021 - 08:08 AM
No real world experience, but it would have to work, especially with the higher pitched noises. It is the reason that tweeters have to be pointed at your head, while a subwoofer can hide behind the lounge. Did the officials pull you off the track for the day?
#5 RallyRed
  • 8,150 posts
Posted 22 May 2021 - 04:02 PM
Attached File  rps20210522_155947.jpg   492.14K   8 downloads
Black flagged by 2 Laurie.. the 3rd one would have seen us on the trailer.
Some chicken wire, chopped up drink cans, coupla hose clamps and all good as a temporary fix ( very temporary)
I have since also spoken to my exhaust guy who has done plenty of circuit cars, reckons the 90 degree down is a winner.  See how we go.
#6 arrimar
arrimar
  • 3,134 posts
Posted 22 May 2021 - 04:41 PM
Are the noise meters on the inside or outside of the track? Fit a lefthand set of pipes or a righthand set depending which track.
#7 RallyRed
  • 8,150 posts
Posted 22 May 2021 - 05:15 PM
Yeah, not a bad idea. The 2 tracks we run at typically, are CW & CCW, so would require swaps each time. Will put it as option 2.
Ta.
#8 UCSLE
UCSLE
  • 710 posts
  • Name:troy
  • Car:Goggomobil
Posted 22 May 2021 - 09:21 PM
put a plate in the exhaust flange with a smaller diameter hole or lots of holes drilled , works for going over the pits
#9 Ice
  • 15,202 posts
Posted 22 May 2021 - 09:45 PM
You need some old school 18 inch hot dogs  :lol:
#10 ozyozyozy
ozyozyozy
  • 950 posts
Posted 23 May 2021 - 09:11 PM
Have done that before and had friends done same thing.
We fitted a turn downs on our exhausts to help with that. Cars were still noisey but didnt ping the meter.
How much less db it affects it i cant answer.
#11 RallyRed
  • 8,150 posts
Posted 24 May 2021 - 08:48 AM
Thanks gents.
#12 Zook
Zook
  • 1,536 posts
Posted 25 May 2021 - 08:15 PM
Is that slow old prick in the black and white HSV VL (I think it is) still getting around. Was it Vodaphone?
