V8 turbo LH-LX Photos
104 replies to this topic
#1 _stock_
_stock_
Posted 31 August 2006 - 07:00 PM
Im starting a lx v8 single turbo project and am wondering if any one has any pics of engine bay layouts.
Thanks :spoton:
Edited by stock, 31 August 2006 - 07:01 PM.
#2 Heath
  • 18,385 posts
Posted 31 August 2006 - 07:27 PM
I've got the same thing planned, but not for a few more years.
Got a few photos that I found interesting, although some of them don't really tell you heaps about the setup. Enjoy
https://cache.gmh-to...ms/v505/Hezath/
Interested in seeing what other people come up with as well
#3 _stock_
_stock_
Posted 31 August 2006 - 07:39 PM
Thanks heaps mate. i like the twin gas setup arrangement. thats how i was going to setup. thanks again
#4 Heath
  • 18,385 posts
Posted 31 August 2006 - 07:48 PM
Awesome, if you do decide to go ahead with it, show us lots of photos and talk about any problems etc you have along the way.
#5 _stock_
_stock_
Posted 31 August 2006 - 07:56 PM
yeah already started (just) try and get some photos together and start a tread.
#6 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 31 August 2006 - 08:59 PM
Check the pics in this thread.......... http://www.gmh-toran...topic=7793&st=0
#7 J-Rod
J-Rod
  • 189 posts
Posted 31 August 2006 - 11:13 PM
i think street machine are running a story on doing this.. Might be worth a look
#8 _stock_
_stock_
Posted 01 September 2006 - 12:31 AM
yeah i have been reading stage write in street machine by the way does any one have the august issue, im after the number and name bob kotmel uses to modify his carby. Thanks
#9 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 01 September 2006 - 07:58 AM
Jakes Performance - Canberra 02 6255 4545
#10 _Yella SLuR_
_Yella SLuR_
Posted 01 September 2006 - 08:06 AM
Was considering doing this, may still do it, but to a Rover 3.5L V8 to keep it under 6.0L with 1.7 forced induction multiplier. Best set up I saw was to use two left standard V8 CI headers, allows plumbing to pass back round the front of the engine, or to fit the V8 CI headers to opposite sides.
Just an idea, NFI if it works or not.
EDIT: Oh, must work, that's how it is done on the engine in Struggler's post, CI manifolds to opposite sides.
Edited by Yella SLuR, 01 September 2006 - 08:09 AM.
#11 _jimjet61_
_jimjet61_
Posted 01 September 2006 - 10:31 AM
Kinda like the look of the set-up that struggler posted, can you imagine trying to change the plugs on the others!!! Have to be one of those backyard rescue jobby's, where you go away for a weekend and come back and it's all done for you.
#12 _Yella SLuR_
_Yella SLuR_
Posted 01 September 2006 - 11:06 AM
^ quiet chuckle. I'm sure No. 7 is still a biatch.
#13 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 01 September 2006 - 11:49 AM
so Im not the only one planning on doing this then? If I handt of crashed the torry, I would have probably started by now!
If your after any Turbo information have a look on http://www.turbomustangs.com/smf/
#14 _stock_
_stock_
Posted 01 September 2006 - 12:14 PM
Thanks mate. :clap: . the setup struggler showed is how im doing it but with vn heads. also thanks to everyone for the pics.
#15 _stock_
_stock_
Posted 02 September 2006 - 02:57 PM
hey struggler what car was the bracket setup for the alternator from?
Edited by stock, 02 September 2006 - 02:58 PM.
#16 _MAWLER_
_MAWLER_
Posted 02 September 2006 - 04:12 PM
Mate I'd love to do it also, then again I'd like to do lots of things. But I'll reckon I'll save the forced induction not for a 5 litre but 5.7 (read VX Clubsport)
Peace,
#17 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 02 September 2006 - 04:25 PM
I made that myself. A bolt went straight thru to the head, made a support bracket to suit and redrilled the adjuster. Obviously required a shorter belt.
#18 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 02 September 2006 - 04:33 PM
I was originally looking at doing a 308, but now I have started planning for a chev, its so much cheaper/easier to set one of them up for forced induction
#19 _Passage_GT_
_Passage_GT_
Posted 07 September 2006 - 02:36 AM
not sure if you guys have seen this before
it's a really old article on a guy doin twin turbo setup on his torana, hits 193mph!!
apologies if it's been posted on the forums before, i'm new:)
also a few pics of my brothers lj xu1 replica on there also
http://s44.photobuck...mgAnch=imgAnch2
http://s44.photobuck...mgAnch=imgAnch1
#20 GML-31
Posted 07 September 2006 - 06:48 AM
your brothers car looks very nice.
#21 Heath
  • 18,385 posts
Posted 07 September 2006 - 03:47 PM
It has been posted here Passage, but don't worry; I'm sure a lot of people wouldn't have seen it the first time :D
#22 _stock_
_stock_
Posted 15 September 2006 - 08:58 PM
i have started the pipe setup and decided to set it up the the old 80's kits. i have plumbed the right bank cast manifold to the left from the outlet and come out the front of the left cast manifold(cut/drill a hole). my question is what size pipe should i use from the front of the manifold to the turbo. have at the moment 2in outside dia and 1.84 inside dia but i am thinking that it is a bit to small and restrictive. my other option is to use 2.5in outside and 2.35 inside dia the only problem is that i dont want to lost to much air speed. also the hole in the manifold is bigger than the inside dia because of the angle of the hole. any help would be great thanks!
#23 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 18 September 2006 - 02:10 PM
the crossover (between the 2 exhaust manifolds) pipe should be around 2.25 to 2.5 inch
#24 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 19 September 2006 - 12:56 PM
Mine was the 50mm OD steam pipe. Keep the exhaust gas speed up !!!
A 2" pipe from either side of the engine to the turbo will easily support 600hp.
#25 TerrA LX
Posted 26 September 2006 - 02:36 AM
i love the setup with the cross over pipe from the right bank and joining on the left, it makes it look so simple im thinking of doing it myself.
