V8 turbo LH-LX Photos
#26
Posted 01 October 2006 - 02:40 AM
do you need one of those blow through carby's?
i dont know if this was mentioned but do you need a turbo cam or anything??
Evan...
#27
Posted 01 October 2006 - 06:53 PM
let us know how ya setups go , as would like to know the relyability of this, ive always herd that carby turbo's are a bit dodgy.
Evan...
#28
_chief_
Posted 07 October 2006 - 11:31 PM
#29
Posted 10 October 2006 - 10:59 PM
is there much performance differance if you dont have a cooler? weekend driving im talking about.
hows is your setup going stock??
Evan..
#30
_stock_
Posted 10 October 2006 - 11:17 PM
#31
Posted 11 October 2006 - 12:20 AM
that torana above doesnt really need a IC, I am pretty sure its running on methanol.all of these drag cars dont have front mounts, this would be much easier to do, than all that screwing arround with a cooler.
Evan..
what CR are you expecting with that piston/rod combo stock?
#32
_stock_
Posted 11 October 2006 - 08:51 PM
Should be around 8.0-8.2:1 there abouts. i think i will be looking at a 75-100 shot of nos to help spool off the line,as it will probabilly be a bit doughy off boost.
#33
Posted 11 October 2006 - 09:49 PM
#34
Posted 15 October 2006 - 07:33 PM
what are the pro's and cons of having one or not?
Regards
Evan...
#35
Posted 15 October 2006 - 08:06 PM
Pro's:
abillity more power
less chance of detonation
Cons:
costs money (all horsepower costs money)
can be hard to package/ fit in to your car
added piping and coplexity
added weight.
in my opinion, the pro's far outweigh the cons.
there are more types of intercooling than just the front mount air to air IC, you can also have a water to air IC and meth/water injection
#36
Posted 16 October 2006 - 09:56 PM
sounds good
what do you call high boost?
i can see ya point about it having more pro's than cons. the biggest pro is that bit about not wanting detonation. can be nasty.
Regards
Evan..
#37
Posted 16 October 2006 - 10:22 PM
#38
_stock_
Posted 18 October 2006 - 08:42 PM
is that with a 5.7 chev rod? what pistons exactly?
yeah rods are 5.7 comp height is 39mm dish is 21cc. just put some photos on, heres the link:- http://wall1096.myph.../view_album.php. the pics of the pistons are of x rods with acl standard pistons and my new set up of LJ chev rods, closed & honed, centres aligned, new 3/8 rod bolts, set up for full floating pins and TRW 4.030 BLOWER PISTONS, double circlips. the collectors are stainless 1.5in 4 into 1. the turbo is a GT42.
#39
Posted 18 October 2006 - 09:06 PM
#40
Posted 19 October 2006 - 08:17 AM
308 Rod 5.622"
350 piston pin height 1.560"
308 piston pin height 1.690"
Therefore the SBC combo will sit down the bore 0.052" further than the 308 combo.
Bear in mind that the SBC rod is wider than the 308 rod at the big end. This would require attention before the rods could bolt up to the crank.
#41
Posted 19 October 2006 - 09:37 AM
#42
Posted 19 October 2006 - 06:45 PM
there's the link,looks pretty crazy, says he's running 2psi.
Evan....
#43
_spud_
Posted 19 October 2006 - 07:21 PM
#44
Posted 19 October 2006 - 07:33 PM
#45
_chevy_253_torana_
Posted 19 October 2006 - 09:29 PM
check dis siht out! http://cgi.ebay.com....1QQcmdZViewItem
#46
_coupe202_
Posted 19 October 2006 - 10:16 PM
Makka 8 psi is std boost in alot of cases any more than 12 psi i would think of running an inner cooler or water injection.
#47
Posted 19 October 2006 - 10:24 PM
If he only ever runs 2psi then there's substancially less wear on the motor, if he wants to keep it nice, tame and reliable then that's the way to go.waste of time for the amount of work thats go into the car.
And if he wants to whack some full slicks on for the drags or take it to the dyno with a crowd for the weekend, he can put the boost up and appreciate all the work that's gone into the car.
I'm building a bit of a hotty 202 for my LX, that doesn't mean I'm gonna be driving it like a race car just because it has more power than from the factory. It doesn't mean it's a waste of time
#48
_chevy_253_torana_
Posted 19 October 2006 - 11:17 PM
#49
_torana_
#50
_stock_
Posted 01 November 2006 - 08:17 PM
i just wondering if you would know what rpm and boost the lj rods will stand up to? they have been resized to suit holden crank and for floating pins. havent had them shot peened as some engine builders like to do it and some don't. whats your thoughts?
