V8 turbo LH-LX Photos
#76
_stock_
Posted 17 January 2007 - 04:46 PM
#77
_stock_
Posted 23 January 2007 - 09:34 PM
Edited by stock, 23 January 2007 - 09:37 PM.
#78
_pro386_
Posted 23 January 2007 - 09:48 PM
#79
_stock_
Posted 23 January 2007 - 09:58 PM
Good choice in fuel system stock. i've got the same but i have the A2000 fuel pump. Is your pump the A1000?
Yeah boss its a A1000. for the time being im not going to need any bigger, good for about 1000hp with blow-thur setup.
#80
_stock_
Posted 01 February 2007 - 08:34 PM
i have been playing around will plumber her up im now using stock 185i factory extractors reversed. i was going to use a cast manifold on the drivers side like jakes torana but know using the vr extractor on both sides. im using a vn engine mount and moving the the mount back a bit. i also going to run the dump pipe down the front of the engine and under the sub frame. the passenger side hads had the flange cut off so i can mod the pipes. you also have to space the alt out and get a triple crank pulley. we had to heat up the heater box and massage so it would fit, it looks a bit crappy at the moment but with a bit of filler will look sweet.
#81
Posted 01 February 2007 - 10:46 PM
Evan
#82
_stock_
Posted 02 February 2007 - 08:39 PM
looking awesum stock!!, keep the pics coming!, thats one big turbo you have there!!!
Evan
Thanks mate!
well i have decided to go to a stroker crank (355), so if anyone is interested in my 308 & chev rods let me know. im going to the stroker cause im aiming for 600+ rwhp and the standard crank and rods want take it. does anyone how if you have to have ANDRA license to run 10's plus at calder.
Edited by stock, 02 February 2007 - 08:40 PM.
#83
Posted 03 February 2007 - 07:46 AM
You will need an ANDRA license and a tech inspection to run 10's anywhere (except maybe Heathcote).does anyone how if you have to have ANDRA license to run 10's plus at calder.
#84
Posted 03 February 2007 - 09:42 AM
spot on, You dont need anything at Heathcote, although I think they prefer that the faster cars are ANDRA tech inspectedYou will need an ANDRA license and a tech inspection to run 10's anywhere (except maybe Heathcote).does anyone how if you have to have ANDRA license to run 10's plus at calder.
#85
_stock_
Posted 27 March 2007 - 10:22 PM
#86
_stock_
Posted 15 June 2007 - 07:41 PM
Ps i think this one is for struggler, im looking for a spot to connect my parachute. i was thinking i would to mount it to the tow bar without the input part? thanks
Edited by stock, 15 June 2007 - 07:49 PM.
#87
Posted 16 June 2007 - 01:45 PM
That will work fine.I think this one is for struggler, im looking for a spot to connect my parachute. i was thinking i would to mount it to the tow bar without the input part? thanks
Is that normal exhaust tube you are using to plumb that turbo?
#88
_stock_
Posted 16 June 2007 - 06:09 PM
The headers are stainless and the cross over pipe is mild steel for the moment. what did you use?
#89
Posted 20 July 2007 - 01:56 PM
How much did the "eagle crank and scat h beam rods" set you back oh the blower pistons too.
Looking at going down a similar path to you, so got a keen eye on you!
What block are you using???
Where did you get your Gt42 from, and its specs? A.r etc
These are obviously a good match for a 308/355??
#90
Posted 20 July 2007 - 07:14 PM
Steam pipe (4 or 5mm).
#91
_stock_
Posted 20 July 2007 - 08:06 PM
where did you get the steam pipe from?
#92
_stock_
Posted 20 July 2007 - 08:22 PM
the rods and crank cost about $1000. i had to sell my old pistons off because the comp height was too tall. im going to get a set of jps pretty cheap so all is good. i just picked up a brand new virgin vs block. i picked up the 42 on ebay. it has a .72 cold side and a 1.01 hot side. im getting my chute and a set of gauges next week. i dont have much left to get, thank Christ.looking good stock
#93
_jap-xu1_
Posted 20 July 2007 - 09:47 PM
im doing a 355 t51r single turbo kit for a customer atm.
Edited by jap-xu1, 20 July 2007 - 09:48 PM.
#94
I got mine at Blackwoods but I have since found it cheaper at almost any metal merchant. It used to be sold under the name of Red Roo and mandrel bends are available and cheap.Steam pipe (4 or 5mm).
#95
_moot_
Posted 21 July 2007 - 09:31 AM
#96
_stock_
Posted 21 July 2007 - 10:08 AM
yeah you have to shorten the safety catch a bit. i can just get my fingers in to unlatch it. that is with a 600*300*100 cooler. you also have to sand down some of the back out of the grill and recess it into the nosecone. hope this helpshave you guys tried to fit intercoolers yet? with the bonnet latch?
#97
_moot_
Posted 21 July 2007 - 02:08 PM
#98
Posted 21 July 2007 - 06:47 PM
#99
Posted 22 July 2007 - 08:05 PM
#100
_stock_
Posted 01 August 2007 - 06:24 PM
