Choke setup on triple HS6 SU's
38 replies to this topic
#26 Bruiser
Bruiser
  • 861 posts
  • Name:Bruce
Posted 08 August 2023 - 08:44 PM
The xu1 cable would have to work better than any other cable, being correctly jetted and calibrated to a 202.
Even your bored out 179 should be close enough for it to work pretty well
I believe harry firth himself chose the best examples from the hopper on the line
for superior choke pulling performance
The rare spares replacement ones must be the best, though
Don’t they say you get what you pay for??
Big idea happened right then
Might give mine the big dose of the graphite powder
might make it easier to use
Sometimes being a goon pays off after all
#27 claysummers
claysummers
  • 3,629 posts
  • Name:Clay
Posted 08 August 2023 - 09:47 PM
Ideally the centre cable would be full length or centre screw is trying to clamp two wires. Thinking about a bell crank setup to reduce the pull.
#28 yel327
  • 13,633 posts
Posted 09 August 2023 - 06:55 AM
With a bored out 179 wouldn't Clay be better off with a choke cable of an LC XU1?
#29 S pack
  • 15,721 posts
Posted 09 August 2023 - 08:26 AM
LC same as LJ exc silver circle on knob face and outer conduit white instead of black.
#30 yel327
  • 13,633 posts
Posted 09 August 2023 - 08:29 AM
Missed the point. Re-read Bruce's post at top of page.
#31 S pack
  • 15,721 posts
Posted 09 August 2023 - 08:31 AM
Yes better if choke cable is one piece through to centre carb but 2 piece should still work if cable clamp screw at junction block is tight.
I think operating the SU choke is always going to give more resistance esp with three carbs.
The cable isn't just pulling the fast idle cam it is also activating the lever that pulls the jet assy down to enrich the micture.
#32 S pack
  • 15,721 posts
Posted 09 August 2023 - 08:35 AM
Quote "The xu1 cable would have to work better than any other cable, being correctly jetted and calibrated to a 202"
I don't see the relevance, it is just a length of wire inside a casing.
#33 Bruiser
Bruiser
  • 861 posts
  • Name:Bruce
Posted 09 August 2023 - 08:38 AM
Pressing the throttle takes out the pull of the return springs while pulling out the choke so I’ve read
Makes sense, but buggered if I can feel any difference
#34 Bruiser
Bruiser
  • 861 posts
  • Name:Bruce
Posted 09 August 2023 - 09:04 AM
Invented this attractively packaged masterpiece a while back
Didn’t finish it, got busy elsewhere
Dash cable goes in top hole, carb cable in middle one
The carb cable needs 1 inch of travel to fully activate choke.
Doubles dashboard knob travel, should halve the effort to pull it.
Can’t bring myself to install something so ugly under my bonnet
Could call it an experimental prototype, but I fear if I put it in, it will
end up staying there
Can’t think of how to do it better yet, so I am still putting choke on by hand
Under the bonnet for the first start of the day
Bonnet’s usually up, anyway
#35 Bruiser
Bruiser
  • 861 posts
  • Name:Bruce
Posted 09 August 2023 - 09:17 AM
Sorry Dave, about all the xu1 cable stuff
I was being bloody silly again
I was born that way and been getting worse ever since
#36 claysummers
claysummers
  • 3,629 posts
  • Name:Clay
Posted 09 August 2023 - 10:50 PM
I can't see your pic Bruce. Was me started the joke about the xu1 cable anyway.
#37 Bruiser
Bruiser
  • 861 posts
  • Name:Bruce
Posted 09 August 2023 - 11:01 PM
Haha you are also silly then
Attached File  IMG_0646.jpeg   289.59K   2 downloads
There is that pic of my fine work
Haven’t fitted the cable clamp on the near side
Edited by Bruiser, 09 August 2023 - 11:01 PM.
#38 claysummers
claysummers
  • 3,629 posts
  • Name:Clay
Posted 10 August 2023 - 07:16 AM
Thanks Bruce. I will try and make the cables as friction free as possible before I go there.
#39 ljv8
ljv8
  • 299 posts
  • Name:Steve
  • Car:LC GTR
Posted 10 August 2023 - 10:32 PM
Yeah having an LC myself with a plastic lower dash panel you have to be a bit careful with the choke operation.  It takes one hand to firmly support the panel face (so it doesn't crack) and the other to pull the choke cable.  Takes a bit of effort with the triple SU's all hooked up, but as long as your careful it works fine.  The last thing you want to do is break your "un-obtainium" LC lower control panel.  Probably less of an issue in an LJ with the metal control panel.
