VN Block roller lifter oil hole height.
6 replies to this topic
#1 tcrulz
tcrulz
  • 3 posts
Posted 31 August 2021 - 04:53 PM
Hi legends. Read all about the issues of the exposed oil hole on Hydraulic roller lifters in a VN 304 Block but can't find out if the same problem exist with Solid roller lifters. Very confused as to what lifters will work in a VN block without having to bush lifter bores. Anyone used Morel 5343? Thanks for any help cos I'm desperate.
#2 RedTaxi
RedTaxi
  • 64 posts
  • Name:Glen
  • Car:LX hatch
Posted 01 September 2021 - 10:32 AM
I just test fitted my new crane ultra pro solid roller lifters (pn 24570-16) in a VN block on my crane solid roller cam. At full lobe lift of .400" (.640" at valve) the lifter oil hole is about 2-3mm down the lifter bore. S well covered. Don't know about Morel. I went with the latest cranes mostly because they have a tiny oil feed down through the lifter body to the bearing. Also Crane have a long history with Holden and make make products specifically for Holden V8's.
#3 rexy
rexy
  • 3,740 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 02 September 2021 - 12:13 AM
The old crane hyd roller lifters wouldn’t work in a VT block so we ended up using factory ones.
Was a long time ago though so hopefully the product has improved.
Factory ones still going strong 17 years later.
#4 Shiney005
  • 9,609 posts
  • Car:Toyota Mirai
Posted 02 September 2021 - 10:44 AM
The lifter bores in the VT blocks were cast different to the earlier ones weren't they?
#5 rexy
rexy
  • 3,740 posts
  • Name:Rexy
Posted 02 September 2021 - 02:43 PM
Possibly. The oiling holes were uncovered with a relatively mild cam with .359 inch lobe lift.
#6 tcrulz
tcrulz
  • 3 posts
Posted 02 September 2021 - 05:02 PM
Thanks for the help gents. :clappin:  I was thinking the solid lifters wouldn't need oil pressure to 'pump' up, so the only oiling it needs is to lubricate the roller on the lifter.
All the information I can find is only for Hydraulic roller lifters. Plenty of good brand solid roller lifters out there (and Hydraulic also) for sale just need to know if they work in a VN type block.  For once in a 'blue moon' driving car Crane are excessively expensive and rebushing lifter bores in a 30 year old block, is out of the question.
#7 warrenm
warrenm
  • 2,118 posts
  • Car:1972 LJ Torana
Posted 02 September 2021 - 11:30 PM
You also need the oil to go through the lifter, then pushrod to reach the valve train for lubrication.
