M15 3sp all synchromesh 6 cylinder
63 replies to this topic
#1 claysummers
claysummers
  • 3,615 posts
  • Name:Clay
Posted 03 September 2021 - 05:20 PM
I got hold of a couple of boxes to muck around with. Word is many of them have been used in speedway amcar? etc. mainly in second and eventually blown up.
early Holden nut
#2 claysummers
claysummers
  • 3,615 posts
  • Name:Clay
Posted 03 September 2021 - 05:30 PM
This one was $250 from Ben at Auto Salvage Recyclers less at Lonsdale. A201 no ribs. Told it was from HQ. Must have been an early one.
early Holden nut
#3 claysummers
claysummers
  • 3,615 posts
  • Name:Clay
Posted 03 September 2021 - 06:00 PM
Funnily when I was at the wreckers there was a woman in front of me talking about torana she got that had an M15 behind old 179. Bit of a dirty mouth with young son along side. No offence madam if you read this.
She was putting an auto in and had posted the manual on gumtree for $1000.
Makes Ben's prices look pretty good. He's getting me a dust cover for $25. I left one of these boxes out of my HX van in a shed when I moved out about 1983.
Please view this ad:
Holden 3 Speed on the floor manual gear box with clutch ect,
https://www.gumtree....roid_VIP_sticky
Price: $1,000
Download the application from the Google Play Store.
https://tinyurl.com/n4b7djy
early Holden nut
#4 Zook
Zook
  • 1,536 posts
Posted 03 September 2021 - 07:28 PM
$1000. Is that what 3 speeds are worth? I've got one, $1000 to a good home.
#5 claysummers
claysummers
  • 3,615 posts
  • Name:Clay
Posted 03 September 2021 - 07:39 PM
Tell her she's dreaming. Some CUB will "snap it up".
early Holden nut
#6 Ice
  • 15,198 posts
Posted 03 September 2021 - 08:35 PM
I doubt that very much
#7 rodomo
  • 18,035 posts
Posted 03 September 2021 - 10:15 PM
I reckon they were probably in late HK's?
#8 claysummers
claysummers
  • 3,615 posts
  • Name:Clay
Posted 03 September 2021 - 10:25 PM
They were an option from HK on, though this would have meant a different steering column, due to the different shift pattern at the box. Standard fitment from HT, as the crash box was phased out end of HK.
#9 rodomo
  • 18,035 posts
Posted 03 September 2021 - 10:27 PM
That box without the ribs would probably fetch good money to the right buyer. Probably had the reverse screw front seal too.
#10 claysummers
claysummers
  • 3,615 posts
  • Name:Clay
Posted 03 September 2021 - 10:43 PM
Thanks Rob.
Ben priced the box at $150. $100for bell housing, bolts and fork. $25 dust cover.
Common practice seems to have been to use a modified 4spd shifter, simply welding up 4th gear position. Column shift and Speco after market floor shifts both have a reputation of jamming, as did the old rat trap mechanical clutch. I would run FE to EK master and slave, with adapter bracket to bolt the slave to the two rat trap mounting holes. Same as hydraulic clutch conversion for M20 Australian 4spd.
#11 rodomo
  • 18,035 posts
Posted 04 September 2021 - 12:19 AM
3 speed extension housing doesn't have the boss's for the shifter mounting bolts.
The after market ones I have seen use the 2 top bolts on the extension housing.
CF Bedford had a 3 speed but I don't know what that shifter looked like?
Edited by rodomo, 04 September 2021 - 12:21 AM.
#12 S pack
  • 15,716 posts
Posted 04 September 2021 - 07:24 AM
All 3spd boxes had the oil slinger on the input shaft until late in 1973.
#13 S pack
  • 15,716 posts
Posted 04 September 2021 - 07:28 AM
Thanks Rob.
Weld up the reverse gate and disable the reverse lever. 1st becomes reverse, 2nd = 1st, 3rd = 2nd and 4th = 3rd.
Edited by S pack, 04 September 2021 - 07:31 AM.
#14 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 04 September 2021 - 08:14 AM
Yep that's what I did on my old HQ race car and used a 4 speed extension housing. Nicer shifter and better position than the Speco ones everyone was using.
#15 S pack
  • 15,716 posts
Posted 04 September 2021 - 08:31 AM
My brother had one of these speco shifters in his LJ 4dr.
Attached File  Screenshot 2021-09-04 at 08-29-23 Holden speco 3 speed shifter fj fc ek eh hr hk ht hg hq Auto Body parts Gumtree Australia....png   480.19K   6 downloads
Edited by S pack, 04 September 2021 - 08:32 AM.
#16 claysummers
claysummers
  • 3,615 posts
  • Name:Clay
Posted 04 September 2021 - 08:59 AM
Thanks fellas. Actually I’m planning on using column shift. The early one won’t work though, as it is a different action to the crash boxes, pre HK. Chap named Roger Harding in Melbourne does a conversion. I would usually take this sort of task on myself but not this time. https://www.earlyhol...lumn-shift-kit/
He has a lot of good stuff at fair prices.
#17 RallyRed
  • 8,136 posts
Posted 04 September 2021 - 12:01 PM
This thread has stayed well on topic.
Thus...has anyone ever seen/ purchased what it todays terms be called a " rip shifter" for an Aussie 4 speed?.
I know the poor old syncros may not deal with it very well, but just askin'.
Ta
#18 UCSLE
UCSLE
  • 708 posts
  • Name:troy
  • Car:Goggomobil
Posted 05 September 2021 - 02:30 PM
How did you get that to work ? there is no bearing retainer on the 4 speed housing
#19 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 06 September 2021 - 09:58 AM
Buggered if I remember the fine details Troy that was over 30 years ago  :D
I don't recall it being very complicated- 4 speed extension housing, shifter,
cut the hole in the 4 speed position. If there was more involved I cant recall
and the scrutineer that sealed the box may have cracked it.
#20 rodomo
  • 18,035 posts
Posted 06 September 2021 - 10:48 PM
I read this this arvo and thought? That's not right. So I looked in the LJ parts book and 3 spd all synchro and 4 spd aussie share the same part number for the bearing housing. The bearing slides into the bearing housing then the housing/bearing assy slides into the back of the casings and the extension housing locates both on 3 and 4 speed.
Tech tip: The circlip thickness/wear and the extension housing gasket thickness are critical for output shaft movement which can cause jumping out of gear problems.............................As well as the input shaft gaskets, circlips etc.
These boxes aren't getting any newer so pick parts wisely.   ;)
#21 claysummers
claysummers
  • 3,615 posts
  • Name:Clay
Posted 06 September 2021 - 10:55 PM
Thanks Rob. Will do.
#22 S pack
  • 15,716 posts
Posted 06 September 2021 - 11:20 PM
Maybe you'll want to recheck those numbers Rob.
From the LJ catalogue.
Bearing Adaptor 3spd RH & LH drive - 7433998
Bearing Adaptor 4spd RH drive         - 2813513
#23 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 07 September 2021 - 10:32 AM
the cf bedford had that setup shifter on a 3 speed
probably still have parts of it in the shed
#24 UCSLE
UCSLE
  • 708 posts
  • Name:troy
  • Car:Goggomobil
Posted 07 September 2021 - 11:26 AM
I haven't looked into this properly yet but is this what stops the bearing falling out the back of the box ? ( where the arrow is in pic)
  • Attached File  3s.JPG   130.52K   6 downloads
#25 rodomo
  • 18,035 posts
Posted 07 September 2021 - 10:03 PM
Yes, well, what an absolute brain fart that was? I had memories..........sweet memories..............but clearly wrong.
I looked up both boxes in the parts book then referred to the section.
Sadly, I went to the back of the section which related to Tri-Matic and stated "all models"
I have enrolled myself into an advanced parts book reading course for those with Alzheimer's  :fool:
