LX Brake Pedal
19 replies to this topic
#1 HNSGEQ
HNSGEQ
  • 41 posts
  • Name:George Hatzi
  • Car:LX Torana
Posted 21 September 2021 - 03:12 PM
Hi All,
I'm hoping someone can help with some pics of the pin position of an LH brake pedal v's the pin position of an LX brake pedal.
I've read through a couple of posts which state the measurement but they don't describe where the measurements are taken from, eg from the top of the pedal to the centre of the pin, or from the centre of the pedal bolt to the centre of the pin etc.
So, if someone had a few pics it would be really helpful because my LX brake pedal was from a 4 wheel drum car so assume the pin position is in the wrong place for a booster with an angled end, which is the booster I'll be using in my car.
If someone could help me identify the right pin position, that would be great.
Thank you,
George
#2 hanra
  • 10,936 posts
Posted 21 September 2021 - 03:41 PM
Pin position? I didn’t think there was anything special about the brake pedals?
This is my set from my LH.
#3 rexy
rexy
  • 3,715 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 21 September 2021 - 03:44 PM
If all else fails assemble the pedal you have and the booster and see whether or not you need to change anything and if you do you will know exactly where to modify the pedal.
Do you already have a booster?
LH different to LX.
#4 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 21 September 2021 - 04:40 PM
Lh and early LX different to late LX and UC. I can measure late LX to suit bent booster rod. That's what I use and it's out of car at the moment.
#5 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 21 September 2021 - 10:02 PM
Late LX brake pedal to suit bent push rod. 73mm centre of pin to centre of pivot bolt.
#6 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 21 September 2021 - 10:14 PM
Actually, I just found the early LX straight rod one I swapped out many moons ago. It is 63mm centre of pin to centre of pivot bolt.
#7 HNSGEQ
HNSGEQ
  • 41 posts
  • Name:George Hatzi
  • Car:LX Torana
Posted 22 September 2021 - 10:11 AM
Thanks all
@Toranamat69 - this is perfect. Exactly what I need.
I am putting a bent rod booster in my car so need a pedal which is 73mm centre to centre.
Thank you!!
#8 hanra
  • 10,936 posts
Posted 23 September 2021 - 03:04 PM
Any help?
#9 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 23 September 2021 - 04:38 PM
Looks like a bit of parralex error where the ruler is against the pivot to me
#10 HNSGEQ
HNSGEQ
  • 41 posts
  • Name:George Hatzi
  • Car:LX Torana
Posted 24 September 2021 - 08:46 AM
I'm looking for an LX pedal so 73mm is what I need.
Thanks guys......
#11 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 25 September 2021 - 07:29 AM
You can buy new pins on eBay and modify an early pedal. You may have to weld up original hole as the 2 holes would be pretty much touching if you drill the lower hole at 73mm. You may even be able to reuse the original pin if undamaged when removing and not worn.
#12 HNSGEQ
HNSGEQ
  • 41 posts
  • Name:George Hatzi
  • Car:LX Torana
Posted 29 September 2021 - 09:33 AM
Yep, I've thought about that but would prefer to buy a pedal if I can find one otherwise will do.
Cheers....
#13 Heath
  • 18,378 posts
Posted 29 September 2021 - 01:06 PM
Sorry for a slightly off topic post here... but I guess these brake pedals generally have some kind of pin on them.
Does anyone have a photo of this?
Is it just a split pin?
I can't find one for my own car but if it's a split pin that's easy of course.
#14 Cook
Cook
  • 1,525 posts
Posted 29 September 2021 - 02:03 PM
Hi Heath.  I don't know if mine is right but I just have a split pin with a washer behind it. Cheers Ron
#15 hanra
  • 10,936 posts
Posted 29 September 2021 - 03:06 PM
I seem to recall an R clip.
#16 76lxhatch
  • 7,202 posts
Posted 29 September 2021 - 03:07 PM
^ Yes I believe it was an R clip.
The pin will push out easy enough, then just drill/weld a new hole, no need to buy anything
#17 hanra
  • 10,936 posts
Posted 29 September 2021 - 03:14 PM
Or not?
Edited by hanra, 29 September 2021 - 03:15 PM.
#18 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 29 September 2021 - 05:48 PM
Yep only ever seen split pins in these.
#19 Heath
  • 18,378 posts
Posted 30 September 2021 - 09:35 AM
Cool.
Ahhh... do they need to have that return spring? I have not installed one of those, lol.
#20 Bigfella237
Posted 30 September 2021 - 10:04 AM
I think the return spring is there mainly to counteract the spring inside the brake light switch (IE. to make sure that the pedal depresses the switch when released).
You might find your brake lights flickering or just plain staying on without it.
It probably helps stop the pedal rattling when unloaded too!
