I went for a temp switch in the thermostat housing switching a relay. A lot easier to set up and there is a good range of switches at differant temp ratings available. If you do not have any where to put the temp switch a 1/8 ntp tap and the correct drill will fix it
Same here.
This solution is quite neat, whereas in my opinion those Davies C. units look like a home make kit or something.
Some things I found out when doing mine -
Bosch seems to have a good range of these sensors.
Note the 1/8NPT comment above...the sensors are a TAPER thread, i.e. a normal tap of that size won't do it. Need a TAPER tap.
As we are in 2021, there seems to be a big selection of sensors with metric threads too, however these seem to be in the 12mm + sizes and you may not find somewhere to drill and tap a hole that big?
Most switches are NOT adjustable, so think about what temp you want to switch at?
There seems to be supply chain issues as well, where a sensor may appear in the catalogue, but only Singapore seems to have any.
That is just my experience, may differ depending on where you are.
Edited by RallyRed, 10 October 2021 - 07:55 AM.
