UC rack parts
5 replies to this topic
#1 dron
dron
  • 129 posts
  • Name:Darren
  • Car:UC
Posted 09 October 2021 - 05:49 PM
Just striped my UC steering rack as it had play on the LH bush. Got it striped and found the bush was missing! Passed inspection after I converted it to a V8 with no bush.
Even more interesting is the car has less than 80 000 KM on it and the pins look to have never been drilled out of the rack ends.
Any way in the process of striping it the hardened spacer under the top pinion bearing (Between the bearing and pinion gear) came out in 2 pices. Looks like it was cracked for some time. If anyone has the hardened washer floating around please let me know, even better if you are in adelaide.  If not I will have to get a hardened washer made and  ground to replace it (It is going to affect shimming if it is not the same as original)
#2 rodomo
  • 18,030 posts
Posted 09 October 2021 - 09:53 PM
Are you talking about the concave/convex washer?...............depending how you look at it.................. :mellow:
#3 dron
dron
  • 129 posts
  • Name:Darren
  • Car:UC
Posted 10 October 2021 - 08:27 AM
Hi
   It is a flat hardened spacer under the top pinion bearing. The inner hole has a rounded edge to clear where to sits on the top of the pinion gear. If I can not get one I will need to find a thrust bearing or possadly a striped pinion bearing and have it surface groung to fit
#4 dron
dron
  • 129 posts
  • Name:Darren
  • Car:UC
Posted 10 October 2021 - 08:41 AM
Photos are always good (hope they work this time)
Attached File  Washer 2.jpg   105.15K   4 downloadsAttached File  Washer 1.jpg   88.29K   5 downloads
Edited by dron, 10 October 2021 - 08:50 AM.
#5 rodomo
  • 18,030 posts
Posted 10 October 2021 - 09:24 PM
Ok, that bit.
#6 dron
dron
  • 129 posts
  • Name:Darren
  • Car:UC
Posted 16 October 2021 - 03:44 PM
Sorted.
I got 3 1mm washers for thrust bearings of the correct ID and ground the OD to fit, Assembled the rack with a new bush. Shimmed it to give me the correct preload as listed in  the book and all is good
