Hi guys , just noticed 2 weeks ago ,when I turn my headlights on in the LX ,its on constant high beam!?, if you try click the stalk and turn them to low it doesnt , from memory theres a little switch in the Steering column that fails? .Can anyone tell me what the switch is called that I need to replace .....Cheers
High Beam constantly on!?
#1 _76SLR_
Posted 13 October 2021 - 11:31 PM
Posted 14 October 2021 - 08:41 AM
This is the switch in the column of an LX:
http://www.toranarpa...icro-switch-lx/
Pull the steering wheel off the car, and check continuity across the (momentary) switch as you pull on the lever, to see if that's the problem.
Check that the wires have not broken off it, they are only soldered on, and those wires vibrate/move around as you turn the indicators on and off, etc. I have actually had those connections fail in the past and fixed it by trimming the wires and re-soldering. That specific area is a weakness of the Torana electrical system in my opinion, but it's done so that it's compact I suppose.
It would also be possible for the latching headlight relay switch thing (located in the engine bay if it hasn't been hidden somewhere else) could have failed, but I wouldn't even look at that before checking the first area.
https://www.ebay.com...MkAAOSwu~FdQgb4
Posted 14 October 2021 - 08:42 AM
If it is in fact the switch and not the relay mate, Mick from Torana Restoration parts and accessories sells them.
Beat me to it H.
Posted 15 October 2021 - 11:39 AM
