CK Xu1
235 replies to this topic
#51 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 23 November 2021 - 10:39 AM
Attached File  post-8884-0-53105200-1625089922.jpg   77.65K   7 downloads
#52 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 23 November 2021 - 12:23 PM
To be eligible a manufacturer was required to build and sell a minimum of 200 " BASICALLY IDENTICAL UNITS "
Attached File  post-8884-0-64101600-1612470834 (3).jpg   53.51K   4 downloads
#53 LCK186
LCK186
  • 383 posts
  • Car:71 CK
Posted 23 November 2021 - 09:34 PM
hi  s pack I agree with u  regarding  diff ratios    1st 200  cars  homoligated  with  3.36 and 3.08 centres        im still unsure why gmh built 300 71 ck xu1 toranas  does anybody actually know          ford produced 300 xy gtho falcons       chrysler produced  300 plus e 38 chargers   some one out there must know
#54 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 23 November 2021 - 10:20 PM
The first 200 " BASICALLY IDENTICAL " 1971 CK's were fitted with the 3.36 diff ratio.
Attached File  LC100 (2).jpg   36.69K   2 downloads
The final 100 1971 CK's were fitted with the 3.08 diff ratio.
#55 S pack
  • 15,717 posts
Posted 24 November 2021 - 06:19 AM
Attached File  Motivated reasoning.png   10.32K   4 downloads
Edited by S pack, 24 November 2021 - 06:19 AM.
#56 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 24 November 2021 - 11:07 AM
Attached File  DSCN0012 (3).JPG   207.87K   3 downloads
Personally, I still much prefer the 1972 version as it tends to simplify things. " Fit 1 ratio to 200 cars & 100 for the other " Much, much simpler to understand.........
#57 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 24 November 2021 - 11:24 AM
Quote "Now all you need to do is explain why they were required to build a minimum of 300......"
I don't NEED to explain anything to you.
Thank F##k
#58 Rockoz
Rockoz
  • 4,029 posts
  • Name:Rob
Posted 24 November 2021 - 11:26 AM
What this tells me is that there was a required minimum.
If they only built the required minimum, then half of them had to have one of the ratios.
If they produced more than the minimum, then they still only had to have the same number of cars with one of the ratios.
If the minimum was 200, then 100 would have to have the alternative ratio.
If they produced 300, then they still only needed 100 of the alternative ratio.
Rob
#59 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 24 November 2021 - 12:34 PM
Rob
Attached File  post-1815-0-25585600-1637633428.jpg   53.51K   1 downloads
200 " BASICALLY IDENTICAL UNITS " all fitted with the 3.36 diff ratio
#60 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 24 November 2021 - 02:03 PM
Attached File  post-1815-0-10820100-1637627769_LI.jpg   867.01K   5 downloads
and Rob the 100 + 100 never applied to the Australian 200 basically identical units......
#61 Rockoz
Rockoz
  • 4,029 posts
  • Name:Rob
Posted 24 November 2021 - 08:57 PM
Thought it would have been understood that the number was just a number, not referencing any particular requirements.
The numbers I used were just example numbers.
Change them to 20 and 10 if you want, the intent is the same.
Rob
#62 S pack
  • 15,717 posts
Posted 25 November 2021 - 06:35 AM
And you still cannot understand it!
How many LJ GTR XU1 did GMH build that were fitted with 3.08:1 ratio rear axles?
Edited by S pack, 25 November 2021 - 06:38 AM.
#63 LCK186
LCK186
  • 383 posts
  • Car:71 CK
Posted 25 November 2021 - 09:59 AM
s pack  hi as far as I was told all lj xu1 toranas came out with the 3.36 lsd    it is possible that country xu1 cars had the dealers to fit the 3.08 lsd for highway travelling
#64 WhiteA9XS
WhiteA9XS
  • 1,646 posts
  • Name:Shaun
  • Car:LJ LX
Posted 25 November 2021 - 01:46 PM
 spoke to two drivers of the day in XU1,s today and told this also noted in log books although some of the books ratios inc LC are noted as VARIOUS .
 LCXU1  3.36 and 3.08 ratios were the only ratios homologated
 LJXU1 3.90 , 3.55 and 2.78 added ratios were homologated in January 1972 commencement of the LJ
 Interesting to note these 72  LJ,s were delivered to some race drivers in Nov Dec 1971 but had to be kept under wraps .
#65 LCK186
LCK186
  • 383 posts
  • Car:71 CK
Posted 26 November 2021 - 06:15 AM
hi      round 2 has ended    round 3   the bell has rang    question   in the  xu1 toranas  I was informed moons ago that the 3.08 lsd were factory fitted  to 10 to 15 Adelaide cars approx.      and  5 or so cars in the brissi built approx.      can any forum member shed some light on this
#66 meanmachine72
meanmachine72
  • 2,036 posts
  • Name:Jono
Posted 26 November 2021 - 10:40 AM
thats right Shaun..only 2 ratios in LC series..both ratios 3.36 and 3.08 where homologated with the very first 200 xu-1 in 1970, no need to re-homologate again for the 300 CK xu-1s in 1971 as its all ready been done in 1970, as for Rockys claim the first 200 CK cars where 3.36 is also another false claim as thats not the case as there where 3.08 ratios in first 200 as well thus being not identical at all..its all to see if he was good enough to fact check with vin disc before he quoted the 200 identical units....
Edited by meanmachine72, 26 November 2021 - 10:41 AM.
#67 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
 LJ XU1 3.90 , 3.55 and 2.78 added ratios were homologated in January 1972 commencement of the LJ
Attached File  thumbnail__20171201_122022 (2).jpg   152.77K   7 downloads
How many cars would it take to complete amendment 6/6V ? Rob ?
#68 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 26 November 2021 - 12:50 PM
hi im not smoking any weed guys      lets see if members  join in and give some input
Attached File  post-1815-0-00278100-1624577940.jpg   66.29K   5 downloads
#69 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 26 November 2021 - 07:07 PM
Attached File  731-1-1_LI.jpg   949.93K   5 downloads
#70 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 27 November 2021 - 10:44 AM
Attached File  identical (2)_LI.jpg   1.06MB   13 downloads
DING, DING
#71 Zook
Zook
  • 1,536 posts
Posted 27 November 2021 - 06:06 PM
I couldn't understand the question but my CK was Brisbane built.
#72 LCK186
LCK186
  • 383 posts
  • Car:71 CK
Posted 27 November 2021 - 07:51 PM
zook hi    I cant figure out why   u couldnt understand my simple question      what part didn't u get regarding the 3.08 lsd in the brissi or Adelaide cars       may be its because I don't use full stops       as for your ck xu1 what colour was it   as there were 2 ck xu1 toranas in act    and I knew both owners  u were not 1 of them     so what colour was it
#73 FLY_AGAIN_XU-1
FLY_AGAIN_XU-1
  • Banned
  • 1,653 posts
Posted 01 December 2021 - 08:52 AM
and my simple question.....
#74 Zook
Zook
  • 1,536 posts
Posted 01 December 2021 - 06:38 PM
... as there were 2 ck xu1 toranas in act and I knew both owners u were not 1 of them so what colour was it
Hi. Yes. Unfortunately for you, you don't know as much as you think you do.
Edit. I'm sorry, but I had to come back. Nothing makes me laugh more than illiterate clowns like you claiming to know...well....stuff. It was advertised in the Trading Post. I kept the ad.
Edited by Zook, 01 December 2021 - 06:47 PM.
#75 jjtheboss
jjtheboss
  • 35 posts
  • Name:jj the boss
  • Car:lj xu1
Posted 01 December 2021 - 06:43 PM
ROUND FIVE WILL BE A KNOCK OUT .
IF YOU HAVE  THE DETAILS  ON THE ADEL AND BRIS CARS  AND HISTORY ON THEM .
YOU ARE TALKING  ABOUT A UNICORN THESE CARS ARE LIKE GOLD THAT ALL I AM SAYING .
AND THEY DONT EXIST IN COMPLETE FORM .
AND ONLY A  FEW IN COMPLETE CONDITION .......
CHEERS
