Any ideas where this spring is from?
5 replies to this topic
#1 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 19 December 2021 - 04:46 PM
Found it in the driver footwell after a drive ... the ignition switch now seems not right but i don't recall there being such a spring inside it ...
Edited by Lima31, 19 December 2021 - 04:47 PM.
#2 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 818 posts
  • Name:JASO
Posted 19 December 2021 - 05:00 PM
Brake light switch?. Can you measure? Also that plastic lug is it part of where the spring came from too maybe?
Edited by 73SUNBURSTEXYOUWON, 19 December 2021 - 05:02 PM.
#3 S pack
  • 15,668 posts
Posted 19 December 2021 - 05:07 PM
It's the spring out of the electrical ignition switch mounted to the steering column. The end of the plastic housing has broken away and the spring has fallen out.
It is the spring that makes the key automatically return from the crank position to the ON position.
#4 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 818 posts
  • Name:JASO
Posted 19 December 2021 - 05:39 PM
http://www.gmh-toran...build +ignition
#5 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 19 December 2021 - 11:49 PM
Ah indeed it was. I guess 47 year old plastic has its limits after all ...
#6 Shiney005
  • 9,479 posts
  • Car:Toyota Mirai
Posted 20 December 2021 - 08:41 AM
It is for parts like these that have me kicking myself every day for tossing old Torana bodies on the tip in the 80's and early 90's.
Edited by Shiney005, 20 December 2021 - 08:41 AM.
