And the small Salisbury
Edited by Bruiser, 05 June 2023 - 09:51 AM.
Posted 05 June 2023 - 09:47 AM
Posted 05 June 2023 - 10:20 AM
Other way around.
Posted 05 June 2023 - 11:54 AM
Posted 05 June 2023 - 12:00 PM
10 bolt refers to the number of bolts on the crownwheel inside, not the cover.
Posted 05 June 2023 - 03:16 PM
Posted 05 June 2023 - 04:06 PM
I can't see how they are much stronger except for the fact it'd most likely be a fine spline. The crown wheel and pinion are still supported by the same bearings in a cast iron housing. You'd imagine in a light car like an FB a fine spline banjo (or disguised banjo) would be good enough with just about any Holden 6 you would put in there. Sure you could still break it but should do the job. Especially if it was a nodular iron banjo centre (V8 casing) rather than the old grey iron casing.
Posted 05 June 2023 - 04:44 PM
Holden referred to them as "Large Salisbury" & "Small Salisbury" respectively.
Dr Terry
Posted 05 June 2023 - 06:21 PM
Dr Terry is correct of course. I think the 10-bolt name started in HK-HG where they had Banjo or Salisbury plus the heavy duty Salisbury (12 bolt) but I guess people knew the Salisbury by their US name where they used 10 bolt or 12 bolt monikers. And the names continued into HQ even though the Salisbury was a different design to the imported centre HK-HG. For whatever reason (cost most likely) GMH moved to the cast "banjo" or small Salisbury in UC. Why wait until UC if it was a cheaper way to do it??? Who knows what they intended for VA, WA etc.
What also doesn't make sense in this whole mish-mash of diffs in the 70's is why the LH-LX used a totally different upper arm location to the Holden and Statesman? Are the LC-LJ upper arm mounts in the same location as LH-LX?
Posted 05 June 2023 - 07:06 PM
Holden Tech →
Driveline →
Harrop or SCW TruetracStarted by salamiman , 01 Dec 2023 ![]() |
Holden Tech →
General HB-LC-TA-LJ →
LJ Torana Diff housing identificationStarted by Dickson , 01 Sep 2022 ![]() |
Holden Tech →
Driveline →
oilsStarted by _blair_ , 10 Jul 2013 ![]() |
Holden Tech →
Brakes, Wheels and Tyres →
DIFF conversion laws for NSW (Altering Track/offset)Started by _LE38OY_ , 26 Aug 2012 ![]() |
Holden Tech →
General LH-LX-UC →
Banjo Diff FlangeStarted by _Kal05_ , 03 Mar 2012 ![]() |
