LC Torana ride height
15 replies to this topic
#1 Flaming Skull 57
Flaming Skull 57
  • 130 posts
  • Name:John Harris
  • Car:LC Torana "Gilberts Stinger"
Posted 29 January 2022 - 09:25 AM
Hi All. What is the standard rear guard height from the ground on a LC Torana. Sometimes when I hit a big bump the rear guard hits the tyre. I am thinking the rear coils have sagged over the years.
On mine, from the ground, through the center of the wheel, to the bottom edge of the wheel arch is 560mm.
Any Thoughts?
Cheers John
#2 S pack
  • 15,722 posts
Posted 29 January 2022 - 05:29 PM
John, the factory measurement on LC 823 & 825 models from the underside of the sill panels just in front of the rear wheels to the ground is 8.3 inches.
Edited by S pack, 29 January 2022 - 05:30 PM.
#3 Flaming Skull 57
Flaming Skull 57
  • 130 posts
  • Name:John Harris
Posted 30 January 2022 - 10:52 AM
Thanks Dave. I will run the tape over it.
#4 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 01 February 2022 - 04:02 PM
8.3" wow you could drive up to the Cape in that. 4.5" would be a lot better.
#5 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 01 February 2022 - 04:58 PM
Any Thoughts?
Cheers John
Guessing tyre dimensions would have changed greatly from the factory specs in the 70's to now. I'm just under 8" with BF Goodrich 205/60 and no rubbing but throw a couple passengers in the back and that could change. Could be why the rear third of the inner lip on both my rear guards are tapped in.
#6 S pack
  • 15,722 posts
Posted 01 February 2022 - 06:28 PM
Mark, the measurement from underside of sill panels just in front of the rear wheels to ground for an LJ 82911 is 7.9"
#7 S pack
  • 15,722 posts
Posted 01 February 2022 - 06:35 PM
4.5" would bottom out on every stupid fcuking speed bump unless you crawl over at snail pace.
#8 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 01 February 2022 - 06:57 PM
Yep you nailed it Gary that's exactly what it is.
#9 S pack
  • 15,722 posts
Posted 01 February 2022 - 07:34 PM
:blink:  Looks like I'm off to the registry office tomorrow to change my name to Gary. :cry: :spit: :spit: :spit: :spit:
#10 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 01 February 2022 - 08:39 PM
Do it Dave ! Us Gary's are tops.
#11 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 02 February 2022 - 06:26 AM
Ha ha ha sorry Dave. brain fart
#12 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 02 February 2022 - 09:38 AM
That is the idea of speed bumps, yeah?
#13 S pack
  • 15,722 posts
Posted 02 February 2022 - 09:55 AM
Yes slowing drivers down is the reasoning behind speed bumps but why lower a vehicle to the point where it bottoms out if you go over the bump any faster than .1kmh.
#14 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 02 February 2022 - 10:26 AM
yeah over here people on a certain road pushed the local council to install speed bumps
three months later , pushed to have them removed , because of the extra noise of the cars powering away
#15 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 02 February 2022 - 06:36 PM
Just so long as tread of the tyres on the top of mine isn't seen, that's about the height I'd like.
#16 rexy
rexy
  • 3,739 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 03 February 2022 - 06:31 PM
Preferred ride height….
Attached File  08EFE142-C83B-43CB-8CA2-FBE349BAC832.jpeg   132.55K   4 downloads
