Posted 05 February 2022 - 08:57 AM
Posted 05 February 2022 - 09:09 AM
Welcome to the GMH Aussie 4 speed.
Posted 05 February 2022 - 11:29 AM
Rebuild/re-adjust the shifter, they are fine when in good nick but most are worn out and need a bit of attention to get them working nicely.
Posted 05 February 2022 - 02:52 PM
It still won’t ever have the shift quality of a Toyota box.
Posted 05 February 2022 - 03:05 PM
^^^ wot he said!
Posted 05 February 2022 - 03:10 PM
Make sure the clutch is set up right too. Must be fully dis-engaged when the pedal is in. Raced with one years ago and can be quite good, but not great.
Posted 05 February 2022 - 09:10 PM
You're a gurl
Posted 05 February 2022 - 10:04 PM
Or the durability.It still won’t ever have the shift quality of a Toyota box.
Posted 05 February 2022 - 11:53 PM
Or the durability.
Or the overdrive
Posted 06 February 2022 - 07:38 AM
Posted 06 February 2022 - 09:07 AM
Posted 06 February 2022 - 10:02 AM
are shifter lengths all the same in m20/m21
No,they vary in length,angle/bend to suit the floor consoles of the various model series they were fitted to. The shortest would have to be the LC/LJ shifter and the longest is the HQ -WB 1 tonner with bench seat.
Posted 06 February 2022 - 05:10 PM
A supra box is great for overdrive but if you have a really big cam they arent geared right to keep the engine up on the cam when you shift.
An M21 has good gearing but are obviously weak which is the downside.
Posted 06 February 2022 - 06:22 PM
Posted 01 May 2022 - 07:57 PM
Posted 02 May 2022 - 09:17 AM
The longer a shift handle the more mechanical advantage you have so can be easier to change gears but has a longer motion.
Unsure if you have a console in your car? The shifter could be hitting against the console. When I have first setup Aussie 4 speed shifters I take the car for a drive with no console or dust boot to see the shifter is moving well in the gate especially in neutral and moves across easily to select each gear. Also make sure it is well greased.
Posted 18 August 2022 - 06:39 AM
shifter issues again
what would make the shift jam or stick in gear
shifter seemed to have locked in 2nd gear as i was downshifting , with persistence it came good again
Posted 18 August 2022 - 08:09 AM
That happens when the stick pops out of the gates in the levers within the shifter., usually because the tang that engages the levers is worn/rounded and/or the levers themselves are sloppy allowing too big a gap between them.
Posted 18 August 2022 - 09:04 AM
These old things can be a drama.
some simple checks -
- Are the little selector levers on the side of the gearbox tight on the flat sided dogs they fit on? i.e. are the 2 nuts ( 1 on each selectors) tight. And / or
- are the little selector levers actually flogged out. Easy to see, just undo the nut and slip it off and see if the hole in the selector is flogged.
- how much slop is there in all the long rods and pins they fit on?
Then there is the gear stick / shifter itself which can have a list of issues.
I think the whole thing from shifter to gearbox can be purchased from Rares for $700?. ... or just the shifter itself for around $550. Not sure on prices.
I actually got the Rares guy to take a new shifter out of the box the other day. TBH I thought it looked and felt really good. Flashback to 1972.....a nice tight Aussie shifter!!
Posted 18 August 2022 - 07:04 PM
#21
Posted 19 August 2022 - 09:40 AM
sounds like worn shifter gate
#22
Posted 19 August 2022 - 11:51 PM
#23
Posted 30 August 2022 - 12:26 PM
I used to carry a screwdriver to lever the stuck linkages when it would end up jammed.
Shitful setup.
