Six cylinder engine mount plate differences
27 replies to this topic
#1 claysummers
claysummers
  • 3,585 posts
  • Name:Clay
Posted 21 March 2022 - 10:37 PM
Ok gurus here is one for you.
Can anyone say if straight six engine mount plates, that bolt to the block, changed geometry from EH through to VK? I am of the opinion they didn't change but Blacky on the FB EK forum reckons he has found several variations, causing him grief in installing a blown red in an EK.
I'm aware of the strengthening applied to passenger side plate at some change but this didn't affect geometry.
#2 Dr Terry
Dr Terry
  • 3,324 posts
Posted 22 March 2022 - 06:55 AM
I'm almost certain that there was no geometry change to those engine mount brackets.
The only change that effects fitting is when they introduced the wider rubber mount for HK onwards. The earlier mounts (EH/HD/HR were 1/4" in narrower, but if you centred them with an 1/8" washer each side, final position was the same.
My brother EH runs a VK EFI engine, using Commodore mounts & brackets, no problems.
Dr Terry
#3 S pack
  • 15,684 posts
Posted 22 March 2022 - 06:56 AM
Hi Clay, I thought the brackets were the same geometry for all Holden straight 6cyl engines but that said I have never directly compared EH brackets to HK or HQ etc.
#4 claysummers
claysummers
  • 3,585 posts
  • Name:Clay
Posted 22 March 2022 - 07:33 AM
Thanks Dr T and Dave for confirming my thoughts.
#5 76lxhatch
  • 7,201 posts
Posted 22 March 2022 - 01:14 PM
I've seen them with various amounts of bend which can be difficult to spot
#6 UCSLE
UCSLE
  • 704 posts
  • Name:troy
  • Car:Goggomobil
Posted 22 March 2022 - 03:23 PM
he hasn't picked up Starfire mounts ? they wouldn't fit but look kind of the same
#7 gtrboyy
gtrboyy
  • 3,208 posts
Posted 22 March 2022 - 04:59 PM
Thought lc/j brackets were different to lh/x or kingies
#8 rodomo
  • 18,031 posts
Posted 22 March 2022 - 09:36 PM
I'm pretty sure 1 plate goes in front of the mount and the other goes behind for correct fitment. Maybe this is where his trouble lies?
#9 claysummers
claysummers
  • 3,585 posts
  • Name:Clay
Posted 22 March 2022 - 09:52 PM
Don't think so Rob69eb95a792efe455521cf79e9469e6de.jpgHe reckons he found three different types in his stash.
Edited by claysummers, 22 March 2022 - 09:52 PM.
#10 S pack
  • 15,684 posts
Posted 23 March 2022 - 12:10 AM
The following mounting bracket part numbers are listed to suit the following models with 6cyl engines.
Unfortunately I don't have parts catalogues for EH, HD & HR Holden.
LC and LJ Torana (pre ADR 10B)
HK, HT, HG Holden.
HQ Holden (pre ADR 10B & excl air)
Bracket engine mounting L.H ..........................................7427365
Bracket engine mounting R.H ..........................................7427366
LJ Torana (ADR 10B)
LH & LX Torana (excl air)
HQ Holden (ADR 10B), HJ, HX, HZ (excl air)
Bracket engine mounting L.H ..........................................9929041
Bracket engine mounting R.H ..........................................9929042
All HQ, HJ, HX, HZ Holden (with air)
LH & LX Torana (with air)
Bracket engine mounting L.H ..........................................2814771
WB Holden (excl air)
Bracket engine mounting L.H .............(9929041).............7427365
Bracket engine mounting R.H .............(9929042).............7427366
WB Holden (with air)
#11 claysummers
claysummers
  • 3,585 posts
  • Name:Clay
Posted 23 March 2022 - 06:50 AM
Thanks Dave,
That may explain things.
And I’ve got the EH HD HR catalogue.
#12 Dr Terry
Dr Terry
  • 3,324 posts
Posted 23 March 2022 - 08:37 AM
EH, HD & HR use the same 7427365/366 as HK-HQ.
9929041/042 replaced them for ADR10B in HQ-WB. These mounts were strengthened with extra pieces welded on.
2814771 (LH) was for the a/cond bracket.
VB-VK Commodore went back to the 7427365/366, apparently the ADR10B mounts weren't required for compliance in the later cars.
Dr Terry
#13 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 23 March 2022 - 09:04 AM
Gents I assume LJ XU1 engine mounts were no different to standard LJ 6 cylinder?
#14 Dr Terry
Dr Terry
  • 3,324 posts
Posted 23 March 2022 - 09:30 AM
Correct.
Dr Terry
#15 claysummers
claysummers
  • 3,585 posts
  • Name:Clay
Posted 23 March 2022 - 10:44 AM
Thanks Dr Terry. I believe the geometry remained basically the same for the Torana HQ HZ, apart from maybe minor longitudinal displacement due to the welded on strengthening plates and corresponding spacer.
#16 UCSLE
UCSLE
  • 704 posts
  • Name:troy
  • Car:Goggomobil
Posted 23 March 2022 - 12:12 PM
what problems was he having ? putting each bracket on the wrong side ?
#17 claysummers
claysummers
  • 3,585 posts
  • Name:Clay
Posted 23 March 2022 - 12:39 PM
He wasn’t specific Troy but you can see from the photo above he had two quite different mounts. Geoff Black, he has been mucking around with Holdens a long time including red six speedway cars, otherwise I wouldn’t be giving it credence.
#18 UCSLE
UCSLE
  • 704 posts
  • Name:troy
  • Car:Goggomobil
Posted 23 March 2022 - 12:47 PM
the two different mounts are a pair , top is a drivers side and bottom is the passenger side .
its been awhile since i have worked on a 6 pot but i don't think you can put them on the wrong side , the bolt holes are different sizes ?
#19 RallyRed
  • 8,105 posts
Posted 23 March 2022 - 03:41 PM
Yeah, The passenger side has 1 larger bolt
#20 claysummers
claysummers
  • 3,585 posts
  • Name:Clay
Posted 23 March 2022 - 06:40 PM
That will be it Troy. I had it in my head they were sane smart from the large bolt hole. That is embarrassing. Blacky is in for it. He made a custom on the driver side to clear steering shaft. Then tried to fit the driver side bracket on passenger side. Didn't fit so he fabricated something. Doh doh doh.......
#21 Bruiser
Bruiser
  • 840 posts
  • Name:Bruce
Posted 23 March 2022 - 06:43 PM
Too easy to forget what you used to know
No matter how clever you are
#22 claysummers
claysummers
  • 3,585 posts
  • Name:Clay
Posted 23 March 2022 - 07:04 PM
I've never been able to get the dosage right with borbon myself
#23 IanC
IanC
  • 577 posts
  • Name:Ian
  • Car:LJ XU-1
Posted 17 September 2024 - 09:47 AM
would someone be able to tell me the bolt sizes for the engine mount brackets to engine please. Thanks in advance Ian.
#24 Kockum
Kockum
  • 477 posts
Posted 18 September 2024 - 10:05 AM
Here you go -   3/8" - 16 x 11/16"
                        7/16" -14 x  7/8"
#25 IanC
IanC
  • 577 posts
  • Name:Ian
  • Car:LJ XU-1
Posted 18 September 2024 - 10:17 AM
Thanks Kockum.
