Newbie Questions - Help needed.
Posted 01 April 2022 - 12:13 PM
I have stripped and painted my k member and I've now got a couple of questions that I need a hand with.
First... I brought new Monroe shock absorbers for it.. Now these come with 3 washers, but the manual only shows 2?.. Now I've figured that the 3rd one goes between a rubber Bush and against the k frame. So my question is should it go below the top rubber bush or above the lower one??
The second question is I have done up all the steering arms etc to factory torque settings, but it seems very tight.. Is that normal?
Posted 02 April 2022 - 08:13 AM
Anyone????
Common sense tells me to loosen off the top and bottom nuts...even though they are done up to torque specs. As it is that tight that I struggle to turn the arms with the discs on.
Edited by kudu, 02 April 2022 - 08:14 AM.
Posted 02 April 2022 - 08:37 AM
I always thought they only used 2 washers , 1 on shock then rubber bush , then when pin of shock wen through shock tower rubber then washer then nut , the rubbers usually had a small raised section that "located" in the hole in shock tower ?
Not sure why steering is tight with no load but they are generally firmish with new ball joints , tie rod ends etc. but not to the point where
it is a struggle to move , steering rack preload not too tight?
Posted 02 April 2022 - 08:54 AM
Posted 02 April 2022 - 09:21 AM
The steering rack was moving nice and freely before I connected it.
Posted 02 April 2022 - 10:08 AM
Posted 02 April 2022 - 11:10 AM
Have you got the column connected and tried it at the steering wheel? It’s up to torque and nothing broke. Just initial tightness in the ball joints probably.
I did wonder that.. But it just seemed overly tight. But I wondered if since its up on a stand that the ball joints just hadn't had a chance to get the grease work into them.
Posted 02 April 2022 - 11:50 AM
or in the rack/column side
Balljoints only pull in as far as the taper allows, not really effected by how
tight the nuts are done up
Posted 02 April 2022 - 03:31 PM
You could knock the tierod ends out again to see if the stiffness is the balljoints
I did that and each ball joint is really stiff. So with all 4 being really stiff that would explain why its so hard to turn. So i imagine/hope that with use, it will free up as it allows the grease into them.
Posted 02 April 2022 - 04:35 PM
Posted 02 April 2022 - 04:47 PM
Just out of interest, did you tighten everything up while up on the jack or stands etc? Or was it all tightened while on its wheels at full kerb weight..
I tightened the steering arms up while on the stands. I've left the main suspension bushes to tighten once under load... Its all still on the stand. Should I have left the steering arms loose until under load as well?
Posted 02 April 2022 - 05:57 PM
Upper and lower control arms though (aka 'A' arms or wish bones to some) need to be done up at road height.
The bushings on control arms are designed for only minimal axial rotation at full torque spec, so if done up on full droop they can end up splitting apart when suspension goes through full range of motion whilst driving.
As it is now, while its up in the air I would just drop the tie rods and check each sides suspension range of motion individually up/down and stub axle turning left to right, to see if one side is worse than the other.
If all is well I'd just put it down to everything being new and tight.
Posted 02 April 2022 - 05:58 PM
Posted 02 April 2022 - 06:14 PM
Steering arms are fine, tighten them any time you like as there's no bushing on them.
Cheers. I have left the upper and lower arms loose until its in the car under load.
It must just be because its new and tight.
Edited by kudu, 02 April 2022 - 06:17 PM.
