A9X Electric Fan - info / pics?
56 replies to this topic
#1 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 05 June 2022 - 02:42 PM
Thought I would start a new thread to hopefully grab the attention of a few A9X owners. Continuing on from this thread - http://www.gmh-toran...wiring-diagram/ I'm looking for a little more info on the factory fitted electric fan; things like wire colours, how/where the fan motor is earthed, a couple of good pics of the relay pinouts...
Its a pretty basic setup but I just want to make sure I have the right information before I draw the schematic.
#2 Shiney005
  • 9,584 posts
  • Car:Toyota Mirai
Posted 07 June 2022 - 12:42 PM
I don't have much, but it may help a bit. (Anything for you after the work you put into the other diagrams)
Attached File  A9X 05.JPG   212.56K   13 downloads
The blue car is brand new.
Attached File  IMG_0615 small.JPG   259.96K   8 downloads
Attached File  IMG_0616 - Copy small.JPG   386.53K   8 downloads
#3 Shiney005
  • 9,584 posts
  • Car:Toyota Mirai
Posted 07 June 2022 - 12:45 PM
Attached File  9.PNG   1.38MB   7 downloads
#4 Shiney005
  • 9,584 posts
  • Car:Toyota Mirai
Posted 07 June 2022 - 12:50 PM
Attached File  14.PNG   1.75MB   8 downloads
Attached File  21.PNG   1.59MB   5 downloads
Attached File  22.PNG   1.36MB   6 downloads
#5 Dr Terry
Dr Terry
  • 3,324 posts
Posted 07 June 2022 - 12:53 PM
Do I see 2 green wires at the relay base.
As far as I can make out we have a thick red for the +ve supply wire from the alternator, a thin green wire to the temp switch on the radiator tank & what looks like a tan or pink wire to the fan itself.
If there are 2 green wires at the relay base, that would indicate that the +ve wire to drive the relay, which comes from the idle stop solenoid is also green.
Are there only 4 wires at the relay base ?
Dr Terry
#6 Shiney005
  • 9,584 posts
  • Car:Toyota Mirai
Posted 07 June 2022 - 12:57 PM
Attached File  AMCS a19.JPG   88.51K   7 downloads
Attached File  AMCS a21.JPG   113.65K   5 downloads
#7 Shiney005
  • 9,584 posts
  • Car:Toyota Mirai
Posted 07 June 2022 - 01:13 PM
Dr Terry
Looking at the black car and the blue car, I would say that tan wire was once red, or has been replaced at some stage. It was a poor example to post up.
#8 hanra
  • 10,968 posts
Posted 07 June 2022 - 02:55 PM
Is it a standalone CCT?
So the key could be out of the car but if that temp sensor in the radiator is still hot enough to supply a GND, the fan will continue to run as the relay supply comes straight from the battery?
Shame you dont have Sheet 12H-32.
Edited by hanra, 07 June 2022 - 02:54 PM.
#9 Dr Terry
Dr Terry
  • 3,324 posts
Posted 07 June 2022 - 04:33 PM
No, because the positive relay coil supply comes from the idle stop solenoid, which is ignition switched.
Ignition off = no fan operation.
Dr Terry
#10 hanra
  • 10,968 posts
Posted 07 June 2022 - 06:10 PM
Ok. Where is that situated on the engine. Carby? Where and how does the wiring route from the engine to the radiator support panel?
#11 Dr Terry
Dr Terry
  • 3,324 posts
Posted 08 June 2022 - 07:32 AM
As far as I can make out, the wire connects to the idle stop solenoid at the carby (green wire near the air cleaner in post #4) it then runs thru black plastic sleeving which is nylon tied to the earth cable & then around the battery. I believe that it connects to the pink (ign +ve) wire just under the heater hose near the water pump in the same pic.
Dr Terry
#12 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 08 June 2022 - 03:10 PM
Awesome pics Laurie, that helps a lot!
Are we going with red for the fan +12v? I think I have all the other info I need to start drawing this up.
#13 Shiney005
  • 9,584 posts
  • Car:Toyota Mirai
Posted 09 June 2022 - 10:27 AM
It is a pity the parts books drawings weren't in colour.  Looking at the black car above, I would say it hadn't been messed with because it still has the original retaining clips. If an auto electrician had replaced the fan at any stage it would have cable ties instead.  I would say red and black for sure.
This drawing shows what Dr Terry was explaining above.
Attached File  A9X Fan wiring harness 2.jpg   136.33K   9 downloads
#14 Dr Terry
Dr Terry
  • 3,324 posts
Posted 09 June 2022 - 12:16 PM
I reckon so too. Looks like:-
Thick red wire from alternator to relay (with inline fuseholder ?)
Thick red wire from relay to fan connector
Thick red wire from fan connector to fan motor
Thick black wire for fan motor earth to body bolt
Thin green wire from pink at carby/engine harness piggy back connector to relay
Thin green wire from relay to thermo switch at radiator top tank
How does that sound Garth ?
Dr Terry
#15 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 09 June 2022 - 02:46 PM
Yeah that's what I was thinking. Is there a fuse holder? - maybe just above the alternator in that last pic?
#16 Dr Terry
Dr Terry
  • 3,324 posts
Posted 09 June 2022 - 03:29 PM
Yes, there is a fuseholder, just above the alternator in that pic.
Let's face it if you're running a heavy draw item like a radiator fan directly from the alternator it has to be fused.
Dr Terry
#17 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 09 June 2022 - 03:52 PM
What size do you think - 25-30A?
#18 Shiney005
  • 9,584 posts
  • Car:Toyota Mirai
Posted 11 June 2022 - 11:02 AM
In HX Statesman it was 25 amp.
Attached File  BD1203.jpg   22.96K   6 downloads
#19 Bruiser
Bruiser
  • 861 posts
  • Name:Bruce
Posted 11 June 2022 - 11:37 AM
Is there a watt rating stamped on your fan motor?
You probably already know watts = volts x amps
Or p = vi in technobabble
#20 Dr Terry
Dr Terry
  • 3,324 posts
Posted 11 June 2022 - 12:58 PM
That fuse is for the blower fan inside the heater/a-cond housing under the dash.
For HQ-WB factory a-cond the auxiliary fan (in front of the condenser) was protected by a circuit breaker.
Having said that I think a 30A fuse would be adequate for the A9X fan.
Dr Terry
#21 Rockoz
Rockoz
  • 4,030 posts
  • Name:Rob
Posted 11 June 2022 - 03:42 PM
Fuses arent meant as protection for the equipment on the circuit.
They are solely for protecting the wire that actually supplies it.
P=EI
E=IR
Rob
#22 Dr Terry
Dr Terry
  • 3,324 posts
Posted 11 June 2022 - 04:17 PM
P=EI
E=IR
Rob
I was taught that a fuse (or circuit breaker) was to protect the entire circuit including the wiring & the device itself.
In this case if the red wire to the relay or from the relay to the fan, was shorted to earth the fuse would blow to prevent a fire. Likewise, if the fan motor ingested some water & became seized, this would cause a considerable increase in current & again possible fire, so the fuse would blow to prevent it.
Dr Terry
#23 Rockoz
Rockoz
  • 4,030 posts
  • Name:Rob
Posted 12 June 2022 - 11:01 AM
You may have been taught that, but it is fundamentally wrong.
If the fan for instance becomes a problem, and it draws excessive power, the fuse blows to protect the wiring.
The result is that the wiring should still be okay to connect a new fan.
The fan is stuffed and requires repair or replacement anyway.
The bit on the end is generally accessible for repair or replacement, whereas the wiring is usually considered fixed and not so easily replaceable.
This principle is why there are different recommended fuse sizes for different sized wires.
And it is a principle in all areas of electrical and electronic design.
Rob
#24 Dr Terry
Dr Terry
  • 3,324 posts
Posted 12 June 2022 - 04:38 PM
I think that we should agree to agree here. What you say is 100% correct, but the fuse can prevent fire damage to the wiring or the within the device itself.
When a fuse blows it can always prevent ongoing damage to any switchgear, relays or even power transistor in that circuit.
But I will agree with your basic premise that the main saving in an automotive situation is to the harness itself.
Dr Terry
#25 Rockoz
Rockoz
  • 4,030 posts
  • Name:Rob
Posted 13 June 2022 - 12:24 PM
Basic Electrical Principle in design.
Simplistically put, fuses and circuit breakers for overload and short circuit protection are to protect nothing but the wiring.
Some earth leakage devices are to protect humans/animals.
Many are solely for wiring protection only.
Rob
